Old 01-04-2013, 08:07 PM   #16
jdiaz
Oddometer: 32,222
Didn't Chevy trucks used to have an issue with the turn signal/CC stalk smelling like smoke or burning up?
You probably don't notice since truck owners never use a turn signal.
jdiaz is offline   Reply With Quote
Old 01-04-2013, 08:15 PM   #17
Grainbelt
marginal adventurer
Grainbelt's Avatar
Oddometer: 26,982
My dad's Blazer had the everyfuckingthingintheworldonitstalk die, it was fucking expensive to replace, I still remember him bitching about it.
He bought a Tundra about a month later.
Grainbelt is offline   Reply With Quote
Old 01-04-2013, 08:19 PM   #18
jdiaz
Oddometer: 32,222
And then his marriage collapsed. Lesson #42 of why Toyotas are bad.
Old 01-04-2013, 08:22 PM   #19
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
Can I replace the motor mounts in a Focus in a parking lot?
Sure, depending on skill level and tools available. I've gutted both front wheel drive and rear wheel drive powertrains without a lift. Very doable if you know what you are doing. A quick google search yielded about 10 billion hits, complete with video. Hmm, I wonder if it's a common problem
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 01-04-2013, 08:37 PM   #20
Grainbelt
marginal adventurer
Grainbelt's Avatar
Oddometer: 26,982
That wasn't until they sold Mom's Passat for a RAV4. Must have been one Toyota too far.
Old 01-04-2013, 08:42 PM   #21
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
Originally Posted by adam_c_eckhardt View Post
What would Bueller do?
Bueller would buy another Jeep and make a big fuss about it.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 01-04-2013, 08:53 PM   #22
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
Originally Posted by Guano11 View Post
I think I have a valve guide question! 1996 Toyota Rav4, 190K, 2.0L, 5spd, FWD -- losing a bit of oil between changes (maybe 1/2 qt over 1000 miles or so, when before it didn't lose any). Telltale puff of tailpipe smoke on startup now, so I'm thinking valve guides. But I'm not a mechanic so not sure if I'm barking up the wrong tree here. Anyway....
Questions:
1. Can the oil loss be solely attributed to valve guides, or should I assume rings are going as well? No apparent oil burning while driving, but I've never followed the car myself....
2. How "invasive" (aka expensive) is a typical valve guide job on the 4cyl? I there anything that should be done while we're in there? (Timing belt, water pump, cam seals, etc are all recent).
3. What if I don't do anything at all? Vehicle is otherwise stone-ax reliable and a worry-free runabout, as in I don't care who parks next to it. At all. Ever. Can I run it as-is for another 25K? 50K?
Here's to the thread getting some legs.....
1) A compression and leakdown test will tell you the source of the oil consumption. At that mileage it could be either (rings or valve seals, not necessarily valve guides)
2 & 3) With oil usage of a quart every 2000 miles, I wouldn't spend any money trying to fix it. The biggest risk is probably the ultimate poisoning of the catalytic converter if the engine starts burning considerably more oil
Old 01-04-2013, 08:56 PM   #23
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
The other day my truck smelled like an electrical fire. Pulled over, opened hood and found nothing. Could still smell it, but saw no smoke and no evidence of excess heat.
Yesterday morning (which was below zero) I started the truck and all the warning lights on the dash came on. The display cycled through all the warnings like "service stabilitrack" etc... Oil pressure gauge was fine and truck seemed to be running fine so I drove it 2 miles to work.
At lunch time I started the truck and it was down to just the "Service stabilitrack" warning.
At quitting time all the warnings were gone.
This is the second time it's happened and both dealers I've been to say they could find nothing wrong with it. Truck is still under warranty.
Old 01-04-2013, 08:59 PM   #24
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
I'm the skinny one on the left, which makes you the fat one on the right.
http://advrider.com/forums/showthread.php?t=840044
Old 01-04-2013, 09:26 PM   #25
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
Lol huh? I guess I've been lax on mentioning it in every thread I can find. I've dropped this into a bunch of threads, though. My garage where I live.
Old 01-04-2013, 09:27 PM   #26
Squelch
Everyday People
Squelch's Avatar
Oddometer: 1,103
I drove the Z to work today and cleaned the engine out good...
I also found out that the tires are quite slippery when they're cold! The traction control is nice - it feels like it gives me just enough yaw to feel fun, but not so much that it's dangerous.
Squelch is offline   Reply With Quote
Old 01-04-2013, 09:29 PM   #27
Bueller OP
Cashin?
Bueller's Avatar
Oddometer: 17,266
You need two in order to have a fighting chance that one will actually run at any particular moment.
Old 01-04-2013, 09:37 PM   #28
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,100
Big car guy. Been in the industry in one capacity or another for most of my life.
Here is a pic of my current vintage car.
I'm considering putting it on the market so I can use the funds to build a Lakester (Lakes Modified Roadster, A.K.A. old hot rod). I have most of the drive train, just need chassis and body.
Also, I'm not typically a Ford guy, but am completely anthralled with the Ecoboost F-150. I live at 7200+ ft. elevation and the turbos really even the playing field.
Also, I am really wanting a Hyundia Genesis Coupe with the 2.0 Turbo. Again, I drove one a while back and it has not left the pleasure center of my brain... Want...
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 01-04-2013, 10:40 PM   #29
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,789
Not true with the very high end British cars but there are all sort of weird ways they did things on the pre VW models like the 1999 Azure on the left, though. The brake system is an excellent example. A high pressure system that uses green mineral oil with two calipers on each front wheel. The brake pedal is just a valve which controls pressure to the wheels. The system has a couple spherical accumulators stamped with a chevron indicating the Citroen origin.
If both brake warning lights come on, stop NOW. You have enough pressure for about a couple dozen brake applications and the you have NO brakes, except the parking brake. I'm serious, pretend all the fluid leaked out of the brakes on your car. No brakes.
To r&r the rear brake rotors is billed at 5.2 hours. Here is what the assembly looks like. Have you ever seen what looks like a full floating hub on an independent rear suspension.
The one on the right is a 2007. From the underside, it looks German.
Old 01-05-2013, 03:47 PM   #30
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,390
Questions:
Guides are probably good, change the valve seals. It can be done without removing the head.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 01:51 AM.
