Old 01-03-2013, 08:18 PM   #1
Snowbound OP
Oddometer: 877
Army axel trailer wheels
I have a single axel trailer that I built using a surplus axel. It has the same bolt pattern and hub opening as the CJ-5 Jeep . I am looking for an aluminum wheel that will be a direct fit without an adaptor . Are there any sources for the aluminum wheels that came later on ? Or any other aluminum wheels?
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 01-04-2013, 03:00 PM   #2
mefadv
mefadv's Avatar
Oddometer: 845
The CJ's had a 5 bolt on 5" centers. Do a search on the internet and see what other vehicle pop's up.
Many times etrailer.com has smok'n deals on new wheels & mounted tires. Just catch them when they offer free shipping.
Mark, a Misplaced Farm Boy....
XR400, plated
TL250, plated
mefadv is offline   Reply With Quote
Old 01-04-2013, 04:24 PM   #3
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,735
actually Jeep CJs ( 70s-1986) had 5 on 5.5" pattern
same as ford 1/2 ton 2wheel drive, dodges, suzuki samuris, sidekicks, IH scouts...
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 01-05-2013, 08:42 AM   #4
mefadv
mefadv's Avatar
Oddometer: 845
Ooops my typo... 5 on 5.5 is the correct spacing
XR400, plated
TL250, plated
Old 01-05-2013, 11:30 AM   #5
Jon
Jon's Avatar
Oddometer: 1,296
Correct. I am running a set of Cragar soft 8's on my M416 military trailer that uses this axle.
Jon is offline   Reply With Quote
Old 01-05-2013, 02:04 PM   #6
Snowbound OP
Oddometer: 877
I have white spoked wheels on the axle now . Looking for something plain . Bolt patterns on the Jeep CJ and 1/2 ton trucks were the 5x5.5 at least back to the late 40 s .
Checked etrailer . Only steel .
BMWMOA
ABC
Old 01-05-2013, 02:45 PM   #7
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Yup, Jeep CJ, Scout, Ford 1/2 ton all interchange. NOT Dodge. Don't know about Suzuki.
Old 01-05-2013, 03:38 PM   #8
mouthfulloflake
Not afraid
Oddometer: 17,735
my google search shows LOTS of dodges from 1994 on up use 5x5.5 ?
1500 series? is google wrong?
google shows Dakotas and Durangos having 5x5.5 too.
and yes Suzuki Samuris are the same as CJs
Old 01-05-2013, 05:40 PM   #9
wos
Oddometer: 1,701
found this while digging around for info for my oddball dakota 6 bolt nightmare
http://www.rustynutscarclub.com/Lug_nuts.htm
wos is offline   Reply With Quote
Old 01-05-2013, 06:59 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Sorry, lol, I quit paying attention to Dodges back in the 80's, they had small, car-like 5 lug patterns, even on the 4x4's. I should have known, my yard is LITTERED with three Dodge PU's from my redneck son.
Old 01-05-2013, 07:49 PM   #11
Snowbound OP
Oddometer: 877
The bolt pattern is the same , but the center hub opening is larger on the Jeep. So a jeep wheel will fit the others , but a lot of the others will not go on a Jeep axle .
BMWMOA
ABC
Old 01-06-2013, 10:22 PM   #12
mouthfulloflake
Not afraid
Oddometer: 17,735
I have encountered that in the past as well.
I used a plasma cutter to make center hole larger.
a grinder would work too.
the wheel is centered by the tapered nuts on the lug bolts, so its pretty easy to enlarge the center hole.
it is a PITA though, steel wheels are thick.
Old 01-07-2013, 04:52 PM   #13
Jon
Jon's Avatar
Oddometer: 1,296
Mine are for a Ford 4x4. Not sure if I can find the part number but I live close to Summit Racing and went in to pick them up and checked the hub opening.
Old 04-14-2013, 11:22 PM   #14
tazshido
tazshido's Avatar
Location: Usually Cheyenne, WY. Currently the middle east.
Oddometer: 2
Military hubs are big.
The smallish trailers used by the Army and Marine corps to haul around tent heaters and small compressors and generators have large hub holes. Jeep wheels will fit and maybe the Suzuki Samurai wheels. Regular trailer wheels like you can find at home depot and the farm and ranch places will have to be modified. If you find some mags that have the proper bolt pattern a machine shop may be able to turn out the hub holes to make them fit.
2006 Triumph Tiger 955i, radiator & cooler guards, full panniers & top box, heated grips. I haven't taken delivery yet.
Est non aevum, est loginquitas!
Semper Fidelis
tazshido is offline   Reply With Quote
Times are GMT -7.   It's 10:34 PM.
