Old 01-03-2013, 09:06 PM   #1
zgfiredude OP
Oddometer: 864
HDB top clamp and hand guards-question
Ok, I'm going to go with one of Paul's set ups, but have a specific question.
Paul offers a top clamp with a spot for an ignition switch. I was thinking of having the ignition and a powerlet on the top row.
Paul tells me that the opening for the ignition fits either a Baja Designs or Sicass Racing switch, not the stocker.
1. Who has done this and which switch did you use?
2. How do you like the set up?
3. What did you do to or with the stock switch?
I hope I've explained it clearly.....
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is offline   Reply With Quote
Old 01-04-2013, 12:01 AM   #2
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,637
On my KLX450R I used a Baja Designs switch that I bought from Paul- no issues & a great fit.
I did paint the letters though-
The KLX450R didn't have a keyed switch to begin with, so I used to control both the electrical & the ignition.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 01-04-2013, 07:44 AM   #3
zgfiredude OP
Oddometer: 864
Hondo, that's beautiful!
I'm thinking Keyed Ignition (same location as yours), Powerlet (where your fan/reserved switches are), and hopefully some on/off switches across the bottom row for "stuff".
I am wondering what if any "issues" I'll have by deleting the stock ignition switch, if I do........
Old 01-04-2013, 06:26 PM   #4
Hondo
Hondo's Avatar
Oddometer: 9,637
The biggest drawback might be security of the switch & wiring vs the stock setup.
When I installed the Scotts/BRP upper triple tree I had to drill out the fasteners holding the switch in place. So you can expect having to remove the upper triple if you will be removing the switch.
If you can leave it, you could tie into the wiring after disconnecting the stock switch connector.
Times are GMT -7.   It's 09:08 AM.
