Old 01-08-2013, 02:07 PM   #16
P B G
Oddometer: 10,001
May sound silly, but did you undo the nut first before trying to reinstall with impact?
If you dont' undo it you have all that static friction to start with.
Old 01-08-2013, 06:53 PM   #17
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,264
take it apart, chase the threads in the damper rod. clean thread boss.
make sure the bolt screws easily into the damper rod base outside of the fork assembly, and make sure the bolt goes in far enough.....
lightly lube the damper rod threads. reassemble. use flashlight to check and see damper rod threads are lined up with hole in fork lower. sometimes sealing washer gets in the way (if there is one - don't know what forks you're working on...) hand screw bolt in a bit - it should go easy and all the way in by hand almost.... then compress and impact it a bit.
current bikes
stainlesscycle is offline   Reply With Quote
Old 01-10-2013, 02:47 AM   #18
Shadow 9er
renegade
Shadow 9er's Avatar
Oddometer: 509
I recently had this problem on one of the fork legs from my old GL-1100 project. I ended up using a manual impact driver (the kind you whack with a mallet) to tighten it up, and that worked very well.
Shadow 9er is offline   Reply With Quote
Old 01-10-2013, 05:45 AM   #19
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,010
I had this problem once, it turned out I didn't have the internal parts assembled correctly. Double check that.
I've also used the broomstick trick. Cut one to just the right length and insert it and screw on the cap, it allows you to get some pretty good torque on it. Once it's started you SHOULD be able to tighten it up.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Times are GMT -7.   It's 04:23 AM.
