Old 01-04-2013, 05:49 AM   #1
CloudchaserSakonige OP
CloudchaserSakonige's Avatar
Oddometer: 54
Can someone please recommend a good motorbike battery?
My Kymco GV 250 takes a 12-BS battery. About three years ago, the battery it came with went bad and had to be replaced. I got an Autocraft battery. When that battery went bad two years ago, I replaced it with another Autocraft. When that one went bad a year ago, I replaced it with another Autocraft and made a habit of putting it on my Schumacher SE-1-12S 1.5 Amp Slow Charge/Maintainer once a month until the "charged" light comes on to make sure it stayed charged.
Usually, the "charged" light comes on almost right away and stays on, indicating that the bike's system is doing a good job of keeping the battery charged. This time, the "charged" light was coming on for 5 seconds, out for one second, repeat. I left the charger on for several hours. No change. To rule out a problem with the charger, I plugged the charger into my car (it also needs it once a month as it's only driven 2-3 times a month) to rule out a problem with the charger. Once that battery was fully charged, the "charged" light stayed on. I connected it to my bike and got the same on/off pattern as before.
The instructions that came with the charger say that the "charged" light being on means voltage is approximately 14 volts and charging has stopped. Off means battery voltage has dropped one volt and charging has resumed. That can only mean that my battery is going bad again.
Being as Autocraft has had such a poor record of going bad about once a year, I don't want to get that brand again. So I need to know what's a good brand that's not terribly expensive that can be had from my local Autozone or Advance Auto? I want to go ahead and get one and have it on hand for when the present battery does give out. Increase in quality being proportional to increase in price is important. For example, Autocraft costs me about $60, so if I were to pay $90 for a battery, I'd expect a life of at least 18 months, minimum.
Photo taken at Mountain Motorsports Kodak on February 12 2013 http://tinyurl.com/cvgn4tc
On the Dragon on April 13 2013 by killboy.com http://tinyurl.com/clnor2z
My other ride is a Kymco Grand Vista 250 http://tinyurl.com/c9acaph
CloudchaserSakonige is offline   Reply With Quote
Old 01-04-2013, 06:51 AM   #2
GlassAnkles
Chip to Queso Ratio
GlassAnkles's Avatar
Oddometer: 923
Yuasa or nothing. cant you order from amazon?
GlassAnkles is offline   Reply With Quote
Old 01-04-2013, 07:34 AM   #3
local1
Oddometer: 459
this..big boar battery puts their sticker over them and sell them for a $100.00 mark up . great product
look up big boar products and see what they sell their batteries for..LOL they use yuasa
See rule #3
local1 is offline   Reply With Quote
Old 01-04-2013, 08:04 AM   #4
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 2,570
Yuasa is the only motorcycle battery I will spend my money on. The original Yuasa battery in my wifes 2004 ATV is still going and it gets used very rarely.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-04-2013, 02:59 PM   #5
timsgs
timsgs's Avatar
Oddometer: 44
Try here..........http://www.batterystuff.com/batterie...FUxxQgod2lEANg
2007 DRZ400s, 1995 Nighthawk 750
Son, don't force that , get a bigger hammer....
timsgs is offline   Reply With Quote
Old 01-04-2013, 05:40 PM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 4,021
VERY high quality AGM battery, US made, reasonably priced. http://www.dekabatteries.com/default.aspx?pageid=510
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 01-04-2013, 11:57 PM   #7
Oddometer: 54
Good idea, thanx for the suggestion! I was thinking buy from a local store to avoid shipping, but looking on Amazon, I found a Yuasa for a price plus shipping that's about what I'd pay buying locally.
Old 01-05-2013, 12:02 AM   #8
Jazz62
Oddometer: 692
If the price is the same, buy local. If you need added incentive just consider the hassle of returning the mail order battery if for any reason it fails during the warranty period.
Jazz62 is offline   Reply With Quote
Old 01-05-2013, 01:09 AM   #9
Oddometer: 54
I thought of that too, but noplace in my area sells Yuasa.
Old 01-05-2013, 02:44 AM   #10
vfxdog
Oddometer: 549
Westco
www.westcobattery.com
Have several and they've been every bit as good as any Yuasa.
vfxdog is offline   Reply With Quote
Old 01-05-2013, 03:17 AM   #11
greer
Oddometer: 3,510
Our local O'Reilly Auto Parts sells re-badged Deka batteries.
Sarah
'08 DR650
greer is online now   Reply With Quote
Old 01-05-2013, 05:29 AM   #12
anotherguy
anotherguy's Avatar
Oddometer: 4,360
Deka batteries are the only ones that I use to start big inch Harley engines consistently. When I say big I don't mean piddley little 103" C.I. things either.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 01-05-2013, 06:58 AM   #13
Oddometer: 54
Will keep that in mind, thanx!
I'm curious, how big?
Old 01-05-2013, 07:48 AM   #14
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,426
Yes!
and they are available from Advance Auto as the "magna power" powersports batteries.
retailmenot.com for advance auto coupons even, usually gets $30 or so off the price
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 01-05-2013, 07:53 AM   #15
mouthfulloflake
Not afraid
Oddometer: 11,426
I even did the cross reference work for you.
order an etx12L instead if you want the pos/neg terminals on opposite sides.
take a meter with you, make sure the battery is charged when purchased
Times are GMT -7.   It's 04:05 AM.
