Old 01-04-2013, 08:36 AM   #1
indr OP
Oddometer: 1,197
Shift Drum Positioning Bolt
What exactly does this do? The first four things in the pic from the top that make it up (bolt, washer, spring, tube thing).
indr is offline   Reply With Quote
Old 01-04-2013, 08:56 AM   #2
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 952
First, it's not the drain plug. As it's name indicates it locates the shift drum in each gear. the spring loaded plunger seats in the cutouts of part #13145 which is pined or otherwise locked to the shift drum. Without it the bike would shift around at will.
Have I been trolled?
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 01-04-2013, 09:00 AM   #3
kioti
Cruzinonline
Oddometer: 184
Spring loaded plunger rides on the 13145 detent plate and is what locates and keeps the shift drum/shift forks in position for the gear selected.
kioti is online now   Reply With Quote
Old 01-04-2013, 09:25 AM   #4
indr OP
Oddometer: 1,197
Not a troll. Just not knowledgable.
Old 01-04-2013, 09:55 AM   #5
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 952
This sort of looks like an cb175 honda. My first twin cylinder in the 70s.
Do i win?
Old 01-04-2013, 09:58 AM   #6
indr OP
Oddometer: 1,197
250 ninja.
Old 01-04-2013, 10:05 AM   #7
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 952
ah. what's wrong with it?
Old 01-04-2013, 10:10 AM   #8
indr OP
Oddometer: 1,197
Sort of a rebuild. First time with an engine opened up. Don't know what does what.
Old 01-06-2013, 12:36 PM   #9
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,152
It holds the shift drum in position.
I had a 1980 Maico 440 that had a weak spring there. Occasionally while landing from jumps the weight of the shift lever pulling down would down shift another gear. I would pull the spring out and stretch it to put more tension on the spring. The auto downshifts would stop.
rufus is offline   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
