Old 01-04-2013, 12:34 PM   #1
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 475
swingarm / center of wheel
Is the swingarm (990 adventure) symmetrical? Thus the center of the rear wheel/rim should be exactly in the middle between the swingarm or the hub with the spacers?
Been riding for +3 years now with an off center rear wheel, going to get it fixed but need to be sure
Gracias!
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Endurofun
Roeligan is online now   Reply With Quote
Old 01-04-2013, 03:34 PM   #2
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 581
i dont think so. Every hub I've laced has a off set to one side, face of hub to edge of rim measurement
dogsslober is online now   Reply With Quote
Old 01-04-2013, 03:52 PM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,230
Ask woody in the vendors section, he does a brazilian of those a week, he can probably even tell you the offset
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 01-04-2013, 04:24 PM   #4
spafxer
spafxer's Avatar
Oddometer: 2,334
I'm not sure what you are measuring for center, but I went out and checked the rim centering on the swingarm and it appears to be about 1.5 inches on both sides. Of course the left side has the plastic chain guard on it so the measurements are approximate. That's the rim to the inside of the swingarm.
950 Adventure no wheel work ever done 'cept for tires of course.
Hope this helps
spafxer is offline   Reply With Quote
Old 01-06-2013, 09:05 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,019
Measuring from the bearing/seal flange on the center of the hub to the side of the rim. The flange is the part of the hub very near the seal on the brake side and near the bearing on the cush side, it sticks out about 2mm past the seal/bearing.
The rear wheel, without the cush drive, sticks 5mm further out on the left side.
The front wheel is the same on both sides.
If you build wheels, you need a dish gauge to check this.
"Son, you can't do both"
Old 01-07-2013, 12:12 AM   #6
Roeligan OP
Belgium power!!!
Roeligan's Avatar
Oddometer: 475
I discovered that for the original rim (4,25") the offset should be 19mm. Measured from the outside of the disc to the side of the rim.
Based on that I can do the math for my 2,5" rim
www.roeligan.net
Endurofun
Times are GMT -7.   It's 05:27 PM.
