01-04-2013, 03:36 PM
#1 |
Oddometer: 10
There is a discussion on trials central twinshock page about if you can run a tubeless rear tire on a twinshock rim with a tube. Some say it is impossible on a Yam TY as the tire will not stay seated at low psi. I am on my 2nd "hand me down" Michelin X-11's on my Ty250 twinshock and have never had any problem even psi. so low i can hardly get a reading. i normally run at 4 lbs
Anyone else have an opinion on this or am I missing something? |
01-04-2013, 04:03 PM
#2 |
Shred
Oddometer: 178
Are you running it with a tube? Or trying to convert the rim to tubeless.
With a tube I imagine it would run fine. Add a rim lock if you have trouble.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly. |
01-04-2013, 04:58 PM
#3 |
Oddometer: 10
No They were not trying to make a tubeless rim out of a tube type but do to lack of tube type availability or what ever they asked about running a tubeless with a tube. That is what I had done only because I came up with a barn find and needed tires and a club member sold me his used set. I have not had any trouble but across the pond several say it just won't work on a Yam TY wheel twinshock or mono. I must be doing something wrong to make it work. Am I right?
Michelin X-11's are tubeless radials and X-1's are bias tubetype?
01-04-2013, 05:08 PM
#4 |
The Pre-Banned Version
Oddometer: 2,729
I have a tubless trials tire on my WR450 (tube type rim) and it is working fine (I have two rimlocks and a tube)
I think if you were to put a tube type tire on a tubless rim it might slip (no rimlock and the bead wont seat correctly and hold the tire in place but this is just a guess)
you actually expect people to take responsibility for their actions in today's society?! |
01-04-2013, 05:12 PM
#5 |
Oddometer: 447
I can say I have never mounted a TY rim, but I have done modern trials bikes. That rear tire is a tight fit. Stand around the corner when the bead seats scary tight. And that is with tire lube. It would take something mighty bad to knock the bead loose on a modern rim with no pressure. With that in mind running tubless on an old rim at low pressure I do see the posibility of knocking the bead off. But adding a tube (even in a tubeless tire) changes a lot. Providing you don't spin the tire on the rim (what rim locks are for) the tube will reseat the tire if you do manage to knock it loose. When doing tire testing (car testing for work) we will sometimes put in tubes in tubeless tires to keep the tires from rolling off the rims and the rims carving nasty grooves in the ground.
So if you are running a tube and a rim lock, I don't see any issues. If the tire is a normal fit on the rim, you could have issues with just a tube when the tire spins on the rim, or if tubeless you could have issues with a bad side hit knocking the bead off. |
01-04-2013, 05:37 PM
#6 |
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 641
Mmmh ... with a tubeless tire, with a inner tube it works fairly.
At least with the Acront / Morad rims in my experience Sometimes the rear tire dipps in a partial section, around 5mm. This happends when I used very low air pressure but had no effect in riding so far. When storing the bike in the garage I always fill the tires with 1 bar. When the tire has a partial dip after a ride I fill up to 3 -4 bar and the dip disappear. I then let out the air again leaving 1 bar. When going riding again I lower to 0,6 - 0,4 bar depending the ground conditions. The aggrivation is worth the time as I'am very pleased with the grip and less weight. |
01-04-2013, 06:16 PM
#7 |
Oddometer: 770
The english guys are just saying the Yamaha does not hold a bead. If your bike works no worries. Yeah my bead moves on my cota 200 also, but who cares. If I ran over 50 mph it would be a big deal, but 25 is about it most of the time. Most of those are posts from riders riding mud and water all day long! That might make the bead hold like S - - t!
lineaway screwed with this post 01-04-2013 at 07:16 PM |
01-04-2013, 06:44 PM
#8 | ||
Oddometer: 641
![]() The area where I live is sadly also called the jerry of god ... (just for your information). And my english is surly not the best but believe it or not I can read too Quote:
this is a much younger rim, (not mine): ![]() Btw. japanese rims, especially DID rims (shown above) are prone to corrosion as the aluminium has a high amount of copper (for hardening the aluminium) which can lead to heavy corrosion in combination with the nipples of the spokes. |
01-04-2013, 07:05 PM
#9 |
Oddometer: 770
Yes, I read the other posts. Been awhile since I had to deal with a jap rim. (I do have a matching set from a TY350 that I keep thinking what to do with) Did not mean the new guy harm. ( I did try to edit it after posting, but the computer at work does not cooperate!) Interesting to hear you get along with the X-lite so well! Always liked the SWM, never had one but won a trials on one after being off a bike for five years.
01-05-2013, 08:20 AM
#10 | |
Oddometer: 35
Jay 2004 Beta Rev 3, 1972 Bultaco Sherpa T 250, 00' Kawasaki Super Sherpa 250 (Wife's) |
01-06-2013, 07:04 AM
#11 |
Oddometer: 45
01-06-2013, 06:58 PM
#12 |
Oddometer: 41
I've got a T-Lock Concept for an 18" rear rim/tire and 21" front rim/tire which makes them tubeless and eliminates the beadlock http://www.t-lock.se/index.html
I'm selling the kit for $100, has everything necessary for installation and inflation, costs over $200 in Europe and about $50 shipping from Sweden. |
01-08-2013, 08:19 AM
#13 |
Trails Evangelist
Oddometer: 963
I am NOT positive, but the difference from Tubeless tire and tube type, was almost nothing, but the "tolerances" were tightened up on tubeless MFG's processes, so that the lip/seal are closer per tire specs. Since the tires have to do holding and sealing, since we don't have rim-locks and such on tubeless rims.
I could be wrong. but MFG's have goofed. We had a run of the Chinese tires that wouldnt stay on new DID tubless rims either. so could be they have a bad batch of whatever tire they have been having problems with? I mean I have seen lots of people before, try the same thing over and over, with same exact results, without really ever trying a "different part" (aka batch). I have newstyle used tubeless tires on my honda tl's, Suzuki rl, and yamaha TY's, soon to have one on the 2 Fantics. So far, Not seeing a problem, running them with tubes. but we're only "play" riding with them, not trying to ride the same lines as we do modern bikes either. |
