Old 01-05-2013, 01:19 AM   #1
TrappedAtWork OP
No Longer Trapped!
TrappedAtWork's Avatar
Oddometer: 254
Question Front Sprocket & Loctite
Righto, purchased my DRZ second hand about 8 months ago, 6000 km of happy riding and things have been going great.
Time for a new chain and sprockets... the bike has about 17,000 km. So I assume that the factory chain and sprockets are on the bike.
I have come to remove the front sprocket and found that the sprocket itself has been loctited on to the drive shaft!
We have attempted to:
A) remove the sprocket by hand
B) lever the sprocket off using screw drivers
C) spray with WD-40 and lever the sprocket off with screw drivers
D) shock the sprocket with a hammer and socket then lever off
E) combine loud swearing with A through D
Is this normal for a DRZ?
Does anyone have anymore ideas?
Heat Pistol?
Steering Wheel Puller?
Any help would be greatly appreciated....
No longer trapped: Riding the Pan American Highway right now! https://transcendenttravel.wordpress.com/
TrappedAtWork is offline   Reply With Quote
Old 01-05-2013, 01:23 AM   #2
Navin
Navin's Avatar
Oddometer: 8,480
I'd try the heat gun next followed by a torch on the sprocket, don't let too much soak into the shaft if you can help it.
Navin is offline   Reply With Quote
Old 01-05-2013, 01:42 AM   #3
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,871
I'd use a 3 jaw puller and an impact wrench, 1st gear, a leather glove and wrap some of the old chain around there to give it enough mass for the impact to work against.
katbeanz is offline   Reply With Quote
Old 01-05-2013, 03:52 AM   #4
gsweave
Yinz, blinkers are on.
Oddometer: 12,499
Heat and ya sure it isn't lefthanded threads?
If not add more torque, my 650 took a three foot extension to break free
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-05-2013, 04:32 AM   #5
dmn0507
dmn0507's Avatar
Oddometer: 353
Did you try to rotate the cs backwards (engine in gear, tap the sprocket teeth clockwise)? it might lock itself there if there is some wear on the splines + loctite.
To remove the loctite I'd try to use a little propane torch and apply localized heat just near the splines, anyways i think that a gear puller would greatly help.
dmn0507 is offline   Reply With Quote
Old 01-05-2013, 04:35 AM   #6
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,661
Is the nut off?
First the Earth cooled. Next came rats, cockroaches and KLR's... and life was good.
Unstable Rider is offline   Reply With Quote
Old 01-05-2013, 05:21 AM   #7
Hennepinboy
Have battery will travel.
Hennepinboy's Avatar
Oddometer: 458
Heat
Heat the sprocket not the shaft with a torch, tap on the edges of the sprocket with a hammer. It will break free. Be careful that you do not get it hot enough to damage the seal.
The Minnesota Airmarshal
Hennepinboy is offline   Reply With Quote
Old 01-05-2013, 06:06 AM   #8
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,025
[QUOTE=dmn0507;20400239
To remove the loctite I'd try to use a little propane torch and apply localized heat just near the splines, anyways i think that a gear puller would greatly help.[/QUOTE]
Ding Ding Ding!
Situate yourself so that you can apply equal amounts of prying pressure on opposite sides of the sprocket without the risk of damaging the engine case, bike frame, fingers...OR a suitably sized mechanical puller of some sort.
Set up the puller with some gentle pulling force and turn on the heat.
Get one of those small tipped propane torches, the kind crackheads use, and heat the sprocket NOT the shaft. Heat the sprocket until you see that first whisp of smoke coming from the suspect anaerobic product and apply a bit more pulling force if it didn't already come off.
PM me with your number and I'll talk it through with you if you like.
If you didn't know, I am a factory rep for Loctite and chief purveyor of new age hocus pokus.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 01-05-2013, 01:47 PM   #9
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
Thanks, but the nut is already off. I am attempting to slide the front sprocket off the main shaft. There are small splines that hold the sprocket in place.
I did use a three foot extention to "break" the nut.
Old 01-05-2013, 01:48 PM   #10
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
This is my fear with heating. I do not want to damage the seal behind the sprocket.
Old 01-05-2013, 01:57 PM   #11
TrappedAtWork OP
No Longer Trapped!
Oddometer: 254
Originally Posted by dirty_sanchez View Post
Ding Ding Ding!
Dirty
I have found a gear puller at Supercheap. I will be down there this morning to pick one up.
http://www.supercheapauto.com.au/onl...41#Description
Since a few people have mentioned heat, I will try heat in combination with the puller.
And thanks for the offer of a chat. I am in Brisbane Australia, and will take you up on that if things get desperate (Skype? ).
Old 01-05-2013, 02:36 PM   #12
timsgs
timsgs's Avatar
Oddometer: 56
A small 3 jaw puller is all you need, should come right off, it's common practice to put red loctite on the sprocket itself. If not done the sprocket rocks and gets even looser on the splines , after a while it takes out the seal. the nut has nothing to do with this known problem. Go over to thumper talk for more info. Good luck
2007 DRZ400s, 1995 Nighthawk 750
Son, don't force that , get a bigger hammer....
timsgs is offline   Reply With Quote
Old 01-05-2013, 02:58 PM   #13
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 979
This is why it was loctited.
http://www.thumpertalk.com/topic/540...t-loctite-fix/
whisperquiet screwed with this post 01-05-2013 at 06:54 PM
whisperquiet is offline   Reply With Quote
Old 01-05-2013, 04:13 PM   #14
WayneJ
City Slicker
WayneJ's Avatar
Oddometer: 6,205
You should be asking your DRZ questions here:
ADV Drz400 Thread
or here:
Thumper Talk DRZ-400 forum
I highly recommend reading the FAQ that is linked at the top of the TT page.
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 01-05-2013, 04:33 PM   #15
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,662
This... it takes about 600f to break down loctite.
If the seal lip feels hard, replace it.
OldPete is offline   Reply With Quote
Times are GMT -7.   It's 09:33 PM.
