Old 01-05-2013, 05:26 AM   #1
wfopete OP
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 485
Cleaning a seat cover
Bought a 2001 XR Honda the other day. It's in good shape but was stored in a barn. The seat has black spots/stains on it from mold or ???. I attempted to clean it with a brush and soapy water with little success. My next step was Bleach White which worked a little better but the stains are clearly still there. Other than the stains the seat is in great shape so I don't really want to replace the cover.
Suggestions?
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 01-05-2013, 07:15 AM   #2
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,476
Hydrogen peroxide is the active ingredient in the 'oxy-clean' type products. It works well for blood and some other protein stains. Not sure how it would work on what you are describing, but H2O2 is the 'powdered bleach' active ingredient so it may. It will be obvious within 10 minutes if the hydrogen peroxide works. Acetone is another good stain remover. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 01-05-2013, 07:59 AM   #3
vfxdog
Oddometer: 617
Methyl Ethyl Ketone (MEK) was the magic solution back in the day when it was my job to clean bike seats.
vfxdog is offline   Reply With Quote
Old 01-05-2013, 08:03 AM   #4
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Auto parts stores stock a vinyl cleaner but if it looks moldy or has been there for a very long time it may well never come out. Stuff leaches into the vinyl and becomes permanent sometimes. Maybe find a seat cover on ebay?
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 01-05-2013, 08:28 AM   #5
ragtoplvr
Oddometer: 6,420
It is common for the mold to get into the foam under the seat and show thru. At a minimum you may need to remove the cover to clean under it.
Rod
ragtoplvr is offline   Reply With Quote
Old 01-05-2013, 09:13 AM   #6
mcma111
mcma111's Avatar
Oddometer: 12,410
I've used lacquer thinner on the XR's that stay parked outside.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-05-2013, 01:31 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Sodium Percarbonate to be exact.May work but I was looking at the uses lately and no mention of cleaning Vinyls. Sure gets the food stains/greases out of my work whites.
I have to do a seat that is kind of moldy for a friend, looks like it may clean up but if not.....wash with Ammonia and dye it will be the quick way.And then I get to change the color of my Scorbin at the same time.
Have tools, will travel!
Old 01-06-2013, 06:49 PM   #8
wfopete OP
wfopete's Avatar
Oddometer: 485
What is this stuff and where do you get it?
I tried the Hydrogen peroxide, bleach white and carb cleaner. The carb cleaner seemed to work but I was afraid it was going to eat the seat up so I quit using it. Next will be WD40 and paint thinner.
Old 01-06-2013, 07:29 PM   #9
okem
Bogsider
okem's Avatar
Oddometer: 240
MEK can usually be found at builders supply yards. We use it to clean tools after caulking.
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.
okem is offline   Reply With Quote
Old 01-07-2013, 03:53 PM   #10
wfopete OP
wfopete's Avatar
Oddometer: 485
Well after trying a few more chemicals with no positive results I went and bought some MEK.
Whoa! If this stuff doesn't take off the stain nothing will becuase it will melt through the seat cover before you can try anything else.
Yes it works...maybe too well. Glad I tried it with just a Q-tip! Had to dilute it WD 40 after getting the stain spot off. I guess the next step beyond MEK would be muriatic acid!
Now I have to figure out how to apply it without ruining the seat.
Old 01-07-2013, 05:24 PM   #11
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Don't forget to Amour All the seat after you clean it. You know.... "to protect the vinyl"
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 01-07-2013, 05:32 PM   #12
Tourbus
Location: Pleasant Hope Mo. Escapee from the Tax Nightmare
Oddometer: 129
Westley's Bleach White
This works on most Vinyl trim, have head it is not as strong as it used to be.
Must be NEW and IMPROVED like everything else.
Tourbus is offline   Reply With Quote
Old 01-08-2013, 08:06 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Good thing you are spot testing first....always a good thing when strong chemicals are suggested without the proper safety warnings or procedures. Understand that even a small amount of that may dry out the vinyl, may not look bad at first but a few months down the road and it may just fail. If you can snip a little piece from under the seat and dip it in the MEK you'll see.
Funny I sometimes have to teach staff proper uses of strong chemicals. Good thing as most can't, or won't, read a label or MSDS. One of them used Muriatic Acid instead of floor cleaner on our tile deck once, good thing I walked in after smelling the fumes and could kick him out for some fresh air. Etched the shit out of the stainless, that created way too many hours of repolishing, did not make me happy and also caused a lot of the tile grout to fail not long after. A very expensive mistake for the taxpayers.
Old 01-08-2013, 10:07 AM   #14
jon_l
jon_l's Avatar
Oddometer: 3,291
MEK is powerful stuff, and may weaken the already aging material. I'd reconsider, else you may need a new seat cover.
I haven't tried it but I read on ADV about spray painting seat covers using (I think) the Krylon paint made for plastics. I was skeptical, but there were positive results reported.
Here is a how-to:
http://www.4strokes.com/tech/seat_paint/
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 01-08-2013, 01:11 PM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
^^^ Vinyl dye, not only Krylon I think just about every paint manufacturer has some. So the price range varies. Autoparts had some from $8.00 to 20somethinhg a can. I settled for the $12.00 one. Haven't done it yet stuff is pretty fumey and my shop too cold. I am sure I can get the Scorbin from grey to black and keep the blue piping, I have small paint brushes.
Nothing I haven't done before, GM used to sell the Vinyl dye by the quart to the dealers and color changing an interior nothing new there, but that nowadays we may have better masks....like MEK none of them fumes are very good for them lungs/brain cells.
But having said that, my friend is a cobbler and does a lot of vinyl dyeing, ladies like to change the color of their shoes/accessories sometimes..... I did set him with a proper exhaust fan, once again watch them fumes.
Times are GMT -7.   It's 05:54 AM.
