Old 01-05-2013, 01:18 PM   #1
MC_Collector OP
Riding Again!
MC_Collector's Avatar
Oddometer: 89
R1100GS Stranded in Southern Mexico --HELP!!!
I got a call from my friend Donnie, (dwj- Donnie here), this morning looking for help diagnosing his bike:
1995 R1100GS ~100,000 miles running fine until he stopped for fuel. Went ~ 1 mile after refueling and it shut off as if the key had turned off! f
It would occasionally fire when he tried to start it, but nothing resembling running right. He advised there was spark at a plug that was checked
The first thing that came to my mind was bad fuel or water in the fuel. I suggested draining the fuel and checking for water and maybe replacing the fuel it for good measure. He advised there was a little water in it and several mechanics have been trying to help, but what I suggested made no or little difference. He advised there is spark and the injectors spray when turning it over. They have checking and cleaned electrical connectors including the kill switch and have been able to get it to run for a few seconds seemingly OK, but it is unknown whether this was on it's own or after fuel got poured into the intake.
He asked me to put this out there and see if anyone had similar symptoms with a hall effect sensor failure on one of these? Maybe some other related gremlin? I haven't investigated the boxer EFI and ignition systems at all, but it would be much appreciated if someone who has could chime in with some advice for Donnie. He said there is some Internet access where he will stay and should be able to fill in the gaps I have probably left here tonight
FWIW the RH head gasket and cam chain guides were replaced ~2,000 miles ago, but it has run perfectly since (until now!).
Thanks,
Dusty Evans
MC_Collector screwed with this post 01-05-2013 at 01:26 PM
MC_Collector is offline   Reply With Quote
Old 01-05-2013, 02:20 PM   #2
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,535
Diesel?
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 01-05-2013, 02:36 PM   #3
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,602
I agree that the first and easiest look see would be to swap out the fuel. That it was running fine before fueling says something to me.
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is offline   Reply With Quote
Old 01-05-2013, 02:38 PM   #4
strsout
Banned Camp
strsout's Avatar
Oddometer: 1,039
When the bike dies, there is still electrical functionality? (lighs, RID, breaks, etc). When push the start, it turns the engine right?
I'm experiencing similar issues (vide post on this forum) and looks like the problem will end up being the Hall Sensor.
Motorcycle Trips, Photos and Maps
2002 BMW K1200LTe - 2004 BMW R1150GSAdventure
2005 BMW R1200GS - 1998 BMW R1100GS
Loma Linda - CA - IBA#14,458 - AMA
strsout is offline   Reply With Quote
Old 01-05-2013, 02:53 PM   #5
Warin
Retired
Oddometer: 2,340
Question Details
It is getting
Spark
Fuel - from the injectors.
Then it needs air in and out ...
compression
Valves opening and closing at the right time
free inlet and outlet.
Unless the information lacks detail about the spark and fuel then it is NOT the HES.... I suspect the information is lacking detail ... making it impossible to tell what is wrong.
So tell us more?
Warin is offline   Reply With Quote
Old 01-05-2013, 03:33 PM   #6
MC_Collector OP
Riding Again!
Oddometer: 89
Thanks to all for the replies.
That was done and It didn't change anything
As I understand everything electrical functions except the engine doesn't start when the starter turns it over
Originally Posted by Warin View Post
It is getting
Spark
compression
So tell us more?
I spoke to him some more this afternoon and I actually heard the bike running over the cell phone. They had gone into the front and looked at the hall effect sensor and found the wires had been nicked by the belt but not broken they got taped up. Later it was learned it would crank up and run with the throttle position sensor disconnected. I heard that over the phone too, but don't know how well. Apparently the pulley didn't get put back tight enough and it came loose and may have damaged the hall effect sensor and it doesn't run now.
Not good.... Ideas??
Dusty Evans
Old 01-05-2013, 05:44 PM   #7
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 5,007
Sounds familiar - The "$2000 and bike still not running" thread from a couple of months back turned out to be due to the pulley not being reassembled properly. Sounds like sending a new/rebuilt hall sensor plate and a used TPS might be the best solution (will be one on eBay right now I'm sure) - and make damned sure the lower pulley is put back on properly.
If your buddy is sure the HS or HS wiring is damaged, then there's nothing to lose by pulling it all apart again - If the sensor itself is not hosed, a bit of careful repair work might bodge it up well enough to get him moving again.
Don't rule out bad fuel (water in fuel?) - as a failure within a mile of leaving a gas station is a pretty big coincidence - and it's not unheard of in that part of the world.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-05-2013, 06:02 PM   #8
MC_Collector OP
Riding Again!
Oddometer: 89
Thanks for the reply
I think they patched the hall sensor, but the thing still won't run above idle. They're going to replace the fuel filter tomorrow.. He stated some brown muck came out of the tank when they dumped the tank out. If that doesn't help I'm sure he'll be figuring how to get a used TPS to him in MX. I also found one at another place. Maybe one will still be around if needed. The new parts prices are appalling!
Dusty Evans
Old 01-05-2013, 06:29 PM   #9
Shango
Hi
Shango's Avatar
Oddometer: 52
Just in case, have him check for a rag in the tailpipe... Someone at the gas station may have had a thing against bikers and shoved one in there. This was done to my Buell once, my exhaust pissed of my neighbors a bit and it had very similar symptoms.
Don't sweat the petty things, pet the sweaty things...
Shango is offline   Reply With Quote
Old 01-05-2013, 07:12 PM   #10
BluByU
BluByU's Avatar
Oddometer: 498
Sorry in advance, but Dam that is funny
My neighbor has a straight pipe screaming chicken exhaust on his hardly able-son and believes that makes him a safer rider than me on my GSA (Ok he may be right as he rides much slower than I). But I would never in my wildest dreams consider capping his noise maker, but dam funny none the less.
BluByU is offline   Reply With Quote
Old 01-05-2013, 07:43 PM   #11
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Hi Dusty, Donnie returned my call.
Spoke with him and he said tomorrow around 10am they are going to go at it again and change the filter.
It appears he is in the northeast of Oaxaca in Maria Lombardo de Casso on #147 just over the Veracruz state line on the Rio Trinidad and is southwest of Acayucan, Veracruz.
I hope to reach Raphael Lago of Motopits here in Veracruz and get his take on things tomorrow in the morning.
If Raphael has parts I might be able to send them via Multipack unless I can find someone heading in that direction.
The earliest I can ride the parts over to him, if what he needs can be sourced here, would be Tuesday in the late AM as I have been looking after my folks who are visiting.
I know that Raphael has some Bosch part numbers for fuel pumps that supposedly cross reference for some BMW pumps and he might be able to source that nearby.
Old 01-05-2013, 08:33 PM   #12
MC_Collector OP
Riding Again!
Oddometer: 89
Thanks! I needed a laugh and some good news in this....
FOTFL !!!I'd have never thought of that. Donnie's bike IS too loud when it runs....
+1 FOTFL !!!
Good news Mike
Maybe it will just be a pluggged filter...
Dusty Evans
Old 01-06-2013, 07:38 AM   #13
dwj - Donnie
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 15,274
Thanks for all the help and comments! The plastic coating was skinned off a small piece on two or three wires when the pulley come off, the actual wires were not damages. The valves have clearance have been checked, they do no have feeler gages, but the correct amount of gap was felt, mas o menos! We will change the fuel filter in a little while and check the operation of the fuel pump. If the fuel filter gives proper pressure, it would seem unlikely that it and the Throttle Position Sensor would fail at the same time. But, I am certainly no mechanic. One thing we all agreeded on when it would have trouble starting, it seem to not be getting enough gas. I will we know a bit more later. Thanks again!
Donnie - Retired & Riding - 2010 990ADV - 54,750 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 01-06-2013, 10:21 AM   #14
dwj - Donnie
Oddometer: 15,274
It is running!!! It seems that the problem all along wast the water in the gas, but before the gas was replaced a couple of problems were created in searching for the problem! I should be leaving town within the hour!
Old 01-06-2013, 10:49 AM   #15
Gezerbike
Gezerbike's Avatar
Oddometer: 3,602
That's great Donnie. Did I win anything ?
Mike
Times are GMT -7.   It's 08:12 PM.
