Old 01-05-2013, 02:17 PM   #1
Joevano OP
Oddometer: 130
Is my engine repairable? Adventure from Alaska
Hi guys, long time no post. My Alaska trip ended badly last year so I've been hiding from my DR and the disappointment of it. Long story short, on my way back from Alaska, with the throttle pegged in fourth gear, passing a truck, my master link let go and the chain jammed up against the back of the case. The engine died immediately and I coasted to the shoulder. I was able to get a ride home (2200 miles) in the back of a trailer.
I finally pulled the DR into the shop today to assess the situation. Attached are a couple pics of the damage. I'm hoping the case can be gently coaxed back into correct alignment, and the cracked rib welded. I will take it to a local engine shop to get their opinion on Monday. Anyone care to comment?
The other problem might be fourth gear itself. I drained the oil and found no abnormal chunks on the magnetic drain plug. With the oil and spark plugs out, I spun the rear wheel through all the gears and it seems like there is a slight catch or clunk in fourth.
Really, really, really depressed about this :sad:
Well I can't figure out how to post pictures so here's a link.
http://joevanorsdol.smugmug.com/Othe...2918&k=DbFDsgm
Well I can't figure out how to post pictures. I'll keep working on it.
Joevano screwed with this post 01-05-2013 at 02:25 PM
Joevano is offline   Reply With Quote
Old 01-05-2013, 02:21 PM   #2
strongbad
Oddometer: 485
Can't see any pics so no comment about whether it can be repaired. Clip-on master link give out? That happened to me once and it does knock the gumption right out of you. You have my sympathy if that helps.
strongbad is offline   Reply With Quote
Old 01-05-2013, 03:08 PM   #3
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,941
Hurricane Bob is offline   Reply With Quote
Old 01-05-2013, 03:11 PM   #4
jkm
Oddometer: 204
I'd be surprised if you can't fix that. I know guys who would use JB weld for the cracked case, and if they couldn't straighten the 'bend', get in there with a dremel to make some room to keep that gear from rubbing. It looks like it has rubbed, but can't tell if it's touching now. If that gear spun around a couple times, it would probably grind away any of the case it's touching. There's a 'white area' just under that one gear and it looks like it may have already ground away some of the case right there. You didn't mention if you'd tried to start the bike since the damage. Anyway, good luck, and let us know how you make out.....jkm
jkm is offline   Reply With Quote
Old 01-05-2013, 03:20 PM   #5
Hurricane Bob
Oddometer: 2,941
http://www.advrider.com/forums/showthread.php?t=633159
Old 01-05-2013, 04:10 PM   #6
Switchblade315
Switchblade315's Avatar
Oddometer: 5,690
worst case you'll have to find a use case half on E-bay. but that looks fixable with a little work.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 01-05-2013, 04:30 PM   #7
NJ-Brett
Brett
Oddometer: 6,496
I think I would have put a new chain on it and rode it home.
If its not leaking oil. you are good to go.
If it is, JB weld.
NJ-Brett is offline   Reply With Quote
Old 01-05-2013, 04:35 PM   #8
G600
Oddometer: 461
Sorry to see that. Bummer.
I would at least get a good welder to take a look before doing anything else. It surely needs to be welded with the side cover on, or the bolt holes wont line up. That also might take care of the sprocket clearance problem.
I have had a few engine side covers welded, all were aluminum and all the repairs were fine. I once had a magnesium crankcase welded, that also turned out fine.
Good luck.
G600 is offline   Reply With Quote
Old 01-05-2013, 04:50 PM   #9
Rot Box
Oddometer: 214
Bevel the crack a little with a file or dremel, sand it down, clean it with acetone and add some JB weld. Based off what I see in the pics (not load supporting/critical to integrity etc..) I'm confident that it would hold for as long as you own the bike.
EDIT: Or have it tig welded that's your best bet. I would not replace the case.
94 ATK 605DSES - 84 Honda CR500R - 81 Honda XL500S
Rot Box is offline   Reply With Quote
Old 01-05-2013, 05:16 PM   #10
Joevano OP
Oddometer: 130
Thanks for the optimism guys, I need all I can get right now. I have started the bike since then and it did dribble.
I've been told (by a professional mech) that you cannot replace half a case. The cases are drilled for the crank as one case and then cut in half. If you replace half, things will not line up and it will leak. That's why they are sold as a set.
Joevano screwed with this post 01-05-2013 at 05:25 PM
Old 01-05-2013, 05:39 PM   #11
kickstand
Oddometer: 66
Sorry to hear about the bad luck bet you can get that straighten and welded with out much issue. Take your time and ask the welder lots of questions. I think my biggest concern would be if the weld is going to take with oil in and around the crack. Looking fwd to see how this comes out. Best of luck PS. did you do a ride report?
kickstand is offline   Reply With Quote
Old 01-05-2013, 05:56 PM   #12
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
It doesnt look to be in that crucial of a spot,I would tap it back in alignment till the outer case will screw back on,then weld or epoxy it till it doesnt leak. Easy to say from here with a beer in hand but its worth a try. Epoxy done right is very tough stuff and has held back leaks for years on my trail bikes.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 01-05-2013, 06:08 PM   #13
fallingoff
Oddometer: 3,677
Hi
I have had 2 cases welded, same reason.
the oil will sometimes work its way out onto the chain.
therefore on the rear tire.
there is a product that you paint on the inside of the case to stop this.
but with age and other things i can not remember the name.
Hope that some other inmate can chime in with the product name.
cheers
qqq
fallingoff is offline   Reply With Quote
Old 01-05-2013, 06:50 PM   #14
Joevano OP
Oddometer: 130
Let me clarify something. The leak dod NOT come from the crack. The crack is only in the rib.
The leak came from the slight misalignment between the bent crankcase and the cover.
Old 01-05-2013, 08:05 PM   #15
sieg
sieg's Avatar
Oddometer: 2,846
Then you should have rode it home.
But anyway it's an easy fix, weld it or epoxy it, grind out for gear clearance, true the gasket fit, no worries.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Times are GMT -7.   It's 04:40 AM.
