Old 01-07-2013, 11:01 AM   #16
norton73
drinkin'
norton73's Avatar
Oddometer: 8,320
you rang?
My '73 850 about to head out;
typical Norton scene;
Important Norton Accessory;
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is online now   Reply With Quote
Old 01-07-2013, 07:41 PM   #17
Doug Matson
Doug Matson's Avatar
Oddometer: 2,059
Here is my 75' MKIII after about 10 months of work all done my self. When I got this it was a mess, nothing but dirt, rust, and oil mixed up in the form of a motorcycle but I new it had potential.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 01-07-2013, 08:45 PM   #18
roadholder
roadholder's Avatar
Oddometer: 2,524
roadholder is offline   Reply With Quote
Old 01-08-2013, 04:26 AM   #19
Speedo66
Transient
Oddometer: 6,852
[QUOTE=bill h;20409257]1967 650SS
[/QUOTE
Police in the LI town of Port Washington, NY used to ride those as patrol bikes in the '60s. There was a dealer in town, Ghost Motorcycles, which sold them.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-08-2013, 08:11 AM   #20
Rathlindri
Guinness fan
Rathlindri's Avatar
Oddometer: 350
Beautiful machine....single carb conversion?
You meet the weirdest people on a Guzzi
Rathlindri is offline   Reply With Quote
Old 01-08-2013, 10:40 AM   #21
Doug Matson
Oddometer: 2,059
Yes I went to the single Mikuni because the Amals were just hanging on the bike when I got it. I am in the process of rebuilding the motor right now and will go back to dual carbs but they will be flat slide PWK's. The complete motor except for the crank and cylinder will be changed. This is whats going inside; FullAuto head, JS light weight pistons, JS designed Carrillo rods, JS stage one cam with light weight lifters, JS custom valve springs and push rods, Comstock breather, and a bunch of little things that just make things better!
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 01-08-2013, 10:46 AM   #22
Doug Matson
Oddometer: 2,059
The FullAuto head is a work of art
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 01-08-2013, 11:02 AM   #23
theturtleshead OP
Tits on a fish
theturtleshead's Avatar
Oddometer: 805
Damn
You are a very cruel man posting all that gear I want for my bike!
One day soon it shall be mine
Al
theturtleshead is offline   Reply With Quote
Old 01-08-2013, 11:10 AM   #24
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
My mates had a lot of issues with his Mikuni. It keeps flooding for no apparent reason. Take it apart clean it out, put it back together and it'll be ok for a short period of time and then start flooding again. All I can attribute it too is small parts of grit in the fuel. Nothing ever appears when it's cleaned out though.
Rob Farmer is offline   Reply With Quote
Old 01-08-2013, 11:32 AM   #25
theturtleshead OP
Tits on a fish
Oddometer: 805
Money pit
I can see more and more ways to spend money!
http://www.stevemaney.com/products.html
Old 01-08-2013, 12:29 PM   #26
Doug Matson
Oddometer: 2,059
Lower the float, mine was very sensitive to this also. I got mine from Sudco and it was supposed to be all ready to bolt on, no way! I had to change everything, the slide, needle, main jet and slow jet. It turned my pipes bright blue right away. A friend's bike leaked also, we found the bowl didn't have an overflow drain so the gas would fill the bowl then run back into the air cleaner soak it and then drip off the air cleaner. Good luck.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 01-08-2013, 02:27 PM   #27
ricochetrider
a certain something
ricochetrider's Avatar
Oddometer: 1,913
Easy enough to put in-line filters on.
Could it be the enricher O-rings, maybe not seating properly? If that is a Mikuni MKIII knock-off, with an enricher lever, take a look down there to see if the o-rings are seating properly. I had a T140E with the MKIIIs on, and it ran rich forever, until I finally replaced those O-rings. Just a thought.
ricochetrider is offline   Reply With Quote
Old 01-08-2013, 07:07 PM   #28
theturtleshead OP
Tits on a fish
Oddometer: 805
Medellin
Out for a spin with some ADV guys on the outskirts of Medellin
My modern Austrian Nortons
Al
Old 01-08-2013, 07:08 PM   #29
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,318
Okay, my turn: tell us about the brakes, please?
Oh yes, and the wheels, too.
Beautiful bike!
HapHazard is online now   Reply With Quote
Old 01-08-2013, 07:10 PM   #30
theturtleshead OP
Tits on a fish
Oddometer: 805
Brembos from Colorado
http://www.coloradonortonworks.com/catalog/brakes.asp
Times are GMT -7.   It's 07:52 AM.
