Old 01-06-2013, 07:25 AM   #1
tunp OP
tunp's Avatar
Oddometer: 288
Flasher button light
11 990 adv. Did valves/oil change. after placing all componets back on bike i noticed the flasher buttom light says on (little red glow each crn of triangle) Never noticed this before so checked manual and it shows lights out on switch and only on and flashing w/ flashers.
I have rechecked connections involved during work, all is ok, Bike runs fine, turn signals and flasher work as normal.
Any thoughts? seems to effect nothing except i am sure it will drain battery
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 01-06-2013, 11:23 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,672
Do you mean the ABS light?
The flasher light is in the speedo,
ABS light is triangle shape in middle of dash.
Peanuts is offline   Reply With Quote
Old 01-06-2013, 01:04 PM   #3
KTMSAM
KTMSAM's Avatar
Oddometer: 124
I have a '12 Adventure and there is a red glow around the hazard button while the key is on and for about 20 seconds or so after the key is shut off. It gets much brighter when the hazards are actually flashing. If the glow is really bright then something might be wrong, if there is a dim red glow around it while the key is on, that's normal operation.
Hope that helps!
KTMSAM
"KTM? Who makes that?"
KTMSAM is offline   Reply With Quote
Old 01-06-2013, 01:09 PM   #4
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
^^^^ same here on my '11 990.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 01-06-2013, 08:42 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,091
My 2010 does the same, dim glow for 20 sec after the ign is off.
It's a feature, not a bug.
"Son, you can't do both"
Old 01-07-2013, 05:05 PM   #6
tunp OP
tunp's Avatar
Oddometer: 288
Thanks Gents
But yes something is up. It will not go out. It has a constant glow.
ok so i went back out to shop and plugged it in and the glow is gone. I had it unplugged for a few days. So maybe moisture was causing something.. Don't know
thanks again
Ridin w/ a smile
Tony A
tunp screwed with this post 01-07-2013 at 05:51 PM
Times are GMT -7.   It's 04:18 PM.
