Old 01-06-2013, 08:54 AM   #1
troyslegacy OP
PigGS Feet
troyslegacy's Avatar
Oddometer: 134
Shipping my GS in a Penske
I am moving a few states away in a couple of days and I am looking for a good way to ship my GS in a 26" Penske. I have checked a few websites out. I have heard everything from drilling into the truck floor to place eye bolts, removing the bolts that are already there and replacing with eyebolts, strapping it to the side, and using an original crate to mount it in.
I however had another idea. Why can't I just ride it up into the truck and knock it over on it's side, strap it down to something, and toss some heavy shit next to it? I mean, it's a GS with scuffed up crash bars, I think it would be fine. I know 98% of people wouldn't dream of doing this, but my bike is a machine that carries me from point A to B, albeit a bad ass one. My only concern would be fuel leaking, which I can mitigate by running the tank low.
Thoughts? Dumb idea, or GS shipping innovation?
troyslegacy is offline   Reply With Quote
Old 01-06-2013, 08:59 AM   #2
JustKip
JustKip's Avatar
Oddometer: 4,542
I don't know about your plan, but mine spent an hour leaning on its side in my garage on a rolled up inflatable raft and my left leg with no ill affects.
JustKip is online now   Reply With Quote
Old 01-06-2013, 09:01 AM   #3
LaurelPerryOnLand
Oddometer: 3,478
100 THREADS all GS/GSA owners should read.
http://advrider.com/forums/showthread.php?t=836736
#15 HOW DO I TIE DOWN MY BIKE FOR TRANSPORTING?
http://www.grassrootsbmw.com/uploads/Tiedown2.pdf
LaurelPerryOnLand is offline   Reply With Quote
Old 01-06-2013, 09:05 AM   #4
troyslegacy OP
PigGS Feet
Oddometer: 134
I've seen that tie-down procedure before, followed the directions, and trailered it cross country. However, this time I don't have a trailer with tie down points, but a Box truck with no tie downs whatsoever.
Old 01-06-2013, 09:15 AM   #5
LaurelPerryOnLand
Oddometer: 3,478
I used a 10' UHaul that had 3? horizontal braces running on the outside walls.
You can loop tie downs behind them as a anchor point.
Perhaps not the best...but you won't have to take a 2 x 4...cut it into 10" pieces and screw them to the floor as anchor points.
Or..if you're going to be frequently transporting...you might consider these:
http://www.guardianfall.com/performa...nchor-1-d-ring
or the cheaper HD version:
http://www.homedepot.com/webapp/wcs/...1#.UOmm4m99LNk
LaurelPerryOnLand screwed with this post 01-06-2013 at 09:32 AM
Old 01-06-2013, 09:40 AM   #6
troyslegacy OP
PigGS Feet
Oddometer: 134
Looks like an option. I'm picking the truck up Thursday and leaving Friday so I have a few days to figure something out.
Old 01-06-2013, 10:33 AM   #7
KsFolly
KsFolly's Avatar
Oddometer: 64
I'd suggest a piece of 3/4 ply 4x8 sheet.
Install your eyebolts to that with large washers.
Put a non slip mat (maybe that black mesh tool drawer liner stuff) down in the truck. Then put the ply down. Then ride the bike in and anchor to the eyebolts.
It shouldn't be able to tip over at that point. Center stand with a tie down to the front wheel so it can't come off.
Compress suspension with ratcheting tiedowns.
Brace the ply to the corners of the truck or to any available wall clamp points.
K
KsFolly is offline   Reply With Quote
Old 01-06-2013, 11:11 AM   #8
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,277
I simply tied mine to the rub rails??? You have to tie front tire to rail as well or the set up will turn, allowing it all to get loose..damhik...
moved from Vegas to Vancouver to Kansas and back this way..no problems.
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 01-06-2013, 11:18 AM   #9
troyslegacy OP
PigGS Feet
Oddometer: 134
K
That's a great idea! I really didn't want to screw around with drilling into the truck or anything. The plywood will come in useful after the move Thanks!
Old 01-06-2013, 12:11 PM   #10
FLARider1
FLARider1's Avatar
Oddometer: 1,300
K
I was thinking to look around and find some heavy oak pallets, like at a place the makes things out of rolled or square stock steel. Then knock out a center board, to make a space for a wheel and then eyebolts into the main beams of the pallet for the straps. One for each wheel. But the plywood is the same idea (big wide base to stap down to) and easier to find.
FLARider1 is offline   Reply With Quote
Old 01-06-2013, 12:21 PM   #11
JRP
Old guy
JRP's Avatar
Oddometer: 1,490
I would first suggest going with a truck longer than 26"
I have seen these used in trucks that brought materials to our place. See if the rental place has them. If they do, with the bike on the center stand and two of these bars [over handle bars and rear rack] should give you the tie down points you need.
http://www.cargoequipmentcorp.com/Lo...rs-p/10085.htm
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 01-06-2013, 01:38 PM   #12
rdwalker
Oddometer: 2,540
Yeah, but it's hard to drive the truck that way, no?
I am glad your leg did not mess up the bike.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 01-06-2013, 01:59 PM   #13
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Have the wife, a buddy, or even a college student looking for a ride home drive the truck while you ride....alternative idea
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-06-2013, 02:46 PM   #14
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 212
Center Stand?
IIRC, transporting the bike on the center stand can lead to cracked cases:
http://www.advrider.com/forums/showp...2&postcount=30
I'm not an expert, but I'd hate to see the OP get a crack because I failed to say something...
Ride4Coffee is offline   Reply With Quote
Old 01-06-2013, 02:55 PM   #15
LaurelPerryOnLand
Oddometer: 3,478
Hopefully, the OP will read the PDF of the BMW recommendation that states:
"Do not place the motorcycle on the center or side stands", (Page 2)
Good to reiterate the point, though! Thanks.
Your conscience is now clear...breathe.
Times are GMT -7.   It's 12:27 PM.
