Old 01-07-2013, 01:22 PM   #1
motorat OP
nOOb
motorat's Avatar
Oddometer: 543
toes freeze
what do you use to keep your toes from freezing.
my vest keeps my core warm, heated grips for my hands, and lining in my pants for my legs.
i have oxtar boots but after about 30 minutes my toes really get cold.
what boots do you use?
should i go with some rain coverings for the boots
or create some kind of wind deflector from the crash bars to the skid plate.
i have ruled out electric insoles and electric/battery sox.
thanks
Joe
08 Vstrom 650 abs
motorat is offline   Reply With Quote
Old 01-07-2013, 01:25 PM   #2
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 2,499
I picked up some neoprene toe protectors for just this task . . . . . sadly, I've no idea from where . . .
here's one source:
http://www.amazon.com/Gator-Tip-Toes.../dp/B00341N6CG
made a big difference for me!
Searching for the immaculate contraption
Old 01-07-2013, 01:26 PM   #3
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,137
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
Chemical warmers, on top of the toes.
Old 01-07-2013, 01:26 PM   #4
motorat OP
nOOb
motorat's Avatar
Oddometer: 543
thanks!!!
Joe
08 Vstrom 650 abs
Old 01-07-2013, 02:24 PM   #5
duck
PsyKotic Waterfowl
duck's Avatar
Oddometer: 9,969
I know you ruled them out but they really are worth using.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR
IBA #17739 (SS1K, BBG, 50CC)
http://home.comcast.net/~smithduck/BMW_Tours.htm
duck is offline   Reply With Quote
Old 01-07-2013, 02:59 PM   #6
JTT
JTT's Avatar
Oddometer: 1,376
Send a message via Skype™ to JTT
Toe warmers
Great solution. Used to use these ice racing...brilliant.
JTT is offline   Reply With Quote
Old 01-07-2013, 03:03 PM   #7
motorat OP
nOOb
motorat's Avatar
Oddometer: 543
thanks again for all the suggestions.
Joe
08 Vstrom 650 abs
Old 01-07-2013, 03:14 PM   #8
Snarky
Blargh!
Snarky's Avatar
Oddometer: 1,179
Send a message via ICQ to Snarky Send a message via AIM to Snarky Send a message via MSN to Snarky Send a message via Yahoo to Snarky Send a message via Skype™ to Snarky
My boots are cheap 100$ MX Boots. They are not good in the cold, nor rain.
I wear decent wool socks, if I find my feet cold, I put rain protectors over my boots, to add another layer against the cold wind.
ALL ADDERS ARE PUFFS!
2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold)
PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims!
Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks.
Snarky is offline   Reply With Quote
Old 01-07-2013, 03:38 PM   #9
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 577
Why rule out electric socks? Warm n Safe electric socks are awesome! And with the Forum discount, they're only something like 60 bucks.
- Stu
'09 R12GS, '05 GSX-R1000 (x3), '05 KTM 525EXC (plated)
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 01-07-2013, 03:51 PM   #10
motorat OP
nOOb
motorat's Avatar
Oddometer: 543
i rule them out because i am lazy.
my commute is about 1 hour and when it gets below 35degF my toes freeze.
i was thinking that rain covers would work, i am going to drop by a bike shop and see about those
rubber toe thingies.
Joe
08 Vstrom 650 abs
Old 01-07-2013, 05:22 PM   #11
LI LT Owner
Wrong Island, NY
LI LT Owner's Avatar
Oddometer: 1,237
I had the Gerbing insoles and switched to their Socks. Much better!!!!! It's the only way to keep my tooties warm!
Rob VB
2003 BMW K1200LT
2002 BMW R1150R
My Blog- Kickin' Tires and Telling Lies
LI LT Owner is offline   Reply With Quote
Old 01-07-2013, 06:57 PM   #12
la's
Oddometer: 76
Smart wool socks with neoprene socks over them followed by boots with gortex. I don't really need anything past the smart wool socks anymore in the southwest.
la's is offline   Reply With Quote
Old 01-07-2013, 07:13 PM   #13
Boatman
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,409
These are the NUTS!. Got a pair of W&S socks also but these insoles work the best for me. Leave the insoles in your riding boots and the harness in your riding pants, takes 1 second to plug each insole in as you put on the boots and another 2 seconds the plug into the pigtail on the bike. I find the socks have hot spots and are a bit too bulky. My only regret is not buying a lifetime supply when Sportmans Guide was blowing them out for $12 a few years ago.
I tried the toe warmer things a couple times but found as soon as the heating effect wore off the iron contents got cold and made my toes even colder.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 01-08-2013, 04:37 AM   #14
jbhawley
WTF- Gus?
jbhawley's Avatar
Oddometer: 372
Why rule out the heated socks? You say you rule these out cause you are lazy???? WTF? I surmise that it will take more time, effort (nee aggravation) to put on regular socks, neoprene covers, boots, rain covers, etc, etc than it does to put on regular socks, heated/electric socks and then plug them in. If you go with the heated insoles then its really no extra effort other than plugging in two wires. Just a observation.
It is quite the chore to plug in a couple wires, but I do seriously digress.
I too tried nearly every conceivable method to keep my feet from freezing on my morning commutes. Before I went to the heated gear side (full jacket liner, pants liner and socks) the only thing I found that was even close was to add a pair of heavy 100% wool socks over my normal socks. This was usually only good for 30-45 minutes and then only if the temps were no colder than 35F. I have ridden in temps in the 20F with the heated socks and my feet were toasty warm and even too warm at times.
Rain covers, rubber boots, neoprene covers, etc are just that --- Covers. Ever sleep in a tent in the freezing cold? You are doing basically the same thing by putting covers over your boots as in sleeping in a tent with no sleeping bag in the freezing cold. Rip stop nylon is not known to be the best insulator. True these over-items may knock off some of the wind chill but cold is cold.
Stand in your yard with no wind while wearing the rain covers, I bet your feet will eventually become freezing too. You gotta add insulation or heat.
Using the chemical warmers such as Toasty-Toes or the like may become expensive in the long run.
It is your dime, but don't rule out the heated socks. I too "ruled out" heated gear prior to actually trying it. The couple minutes it takes to don all the stuff is well worth the effort, to me, to stay comfortable on my morning commutes.
YMMV drastically! .
---John
Lemmings non sumus
"All the inconvenience and sweat and discomfort of body armor suddenly pales when you're sliding comfortably down the highway on all fours." -ghostdncr
jbhawley is offline   Reply With Quote
Old 01-08-2013, 05:05 AM   #15
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 1,753
Wouldn't putting heated socks on when you gear up at home be quicker and easier than putting the rain covers on? I find them onerous to install/remove when geared up.
"turn it on man, turn it on-whatever, whoever you are-TURN THE FAWKER ON!" -Herbert Foster Gunnison
01 Girlie
09 TE450
bobnoxious67 is offline   Reply With Quote
Times are GMT -7.   It's 05:09 AM.
