Old 01-08-2013, 06:34 AM   #1
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 4,089
Repair a Ceramic Umbrella Stand?
As everyone was leaving our New Year's Party, my wife's umbrella stand was knocked over and it broke into several large pieces (6 or 7). The stand is nothing special yet it belonged to her mother (who passed away almost a year ago). So, it has sentimental value and I would like to repair it for her.
As I mentioned, it's in several large pieces which are easily reassembled (there are no chips or thumbnail sized bits). The inside of the stand does not have any glaze on it. Is there some type of adhesive I can use or, given the lack glaze on the inside, can I use fiberglass to hold it together?
Any thoughts/suggestions/ideas are much appreciated.
TIA, Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 01-08-2013, 06:57 AM   #2
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,924
Locktite makes a pretty good superglue, but I wouldn't put an umbrella in it after that.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 01-08-2013, 07:16 AM   #3
P B G
Oddometer: 10,001
zap-a-gap
Try zap-a-gap adhesives.
It is a super glue, but it is good at filling gaps/bridging imperfections, which is great because your ceramic surface probably will have some.
Try to preassemble/trial fit so that you will know there won't be problems getting things to align.
Old 01-08-2013, 07:16 AM   #4
ragtoplvr
Oddometer: 6,529
A professional restorer can usually do a pretty good job for a few hundred.
Call a local museum for recommendations.
Super glue works well on ceramic. The thing to remember is you have one shot to get it right, and you can not fix it later. If it is pretty porus then they make some thickened or toughed ones that are better.
Rod
ragtoplvr is offline   Reply With Quote
Old 01-08-2013, 07:36 AM   #5
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,150
two part epoxy works well. If you use a superglue, you'll need to use a thick one, like zap-a-gap, but I recommend a 5 minute epoxy, and clean off the excess with a razor blade before it's totally hardened. I have a couple handmade ceramic plates that have been repaired this way, and get daily use, it's worked fine for the last 8 years.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 01-08-2013, 07:39 AM   #6
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,437
LocTite 454 once again as it will fill gaps up to .010".
It is a gel and if used in the cool of the evening offers plenty of work time.
Look up the specs. I used it to repair fiberglass faring breaks. Shit's good.
OldPete is offline   Reply With Quote
Old 01-08-2013, 09:27 AM   #7
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,715
I've had good luck with a similar repair with Duco Contact Cement.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-08-2013, 10:47 AM   #8
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,556
Sodium silicate may work. It is a clear liquid composed of quartz dissolved in sodium hydroxide and used as a high temperature adhesive for ceramics (among many other things). See if it would meet your needs - a fixture would be needed to hold the parts together while it dries.
Here is a art hobby shop link describing the product: http://www.dickblick.com/products/artmolds-liquid-sodium-silicate/
Amazon also sells sodium silicate liquid. Wear gloves, apply only a very small amount, don't drink it, etc.
Edit: Here is a link which is more appropriate: http://www.pottery-magic.com/pottery...repair_pot.htm
Good Luck!
Stan_R80/7 screwed with this post 01-08-2013 at 11:08 AM
Stan_R80/7 is offline   Reply With Quote
Old 01-08-2013, 09:21 PM   #9
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
Slow setting 2 part epoxy, thin (adding thickeners) or non-flowing if you can get it. You want a long working time so that you can assemble it without worrying about time (8 hour cure would be fine).
Before mixing the epoxy, do a full assembly and plan out all your clamping methods for each area. Masking tape, rubberbands and other small clamping methods will hold it in place as everything sets up.
Use denatured alcohol to clean up any errant epoxy.
Flashmo is offline   Reply With Quote
Old 01-09-2013, 06:28 AM   #10
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 4,089
Thanks everyone. It looks like I have some research to do and test some (re)assembly methods. I appreciate the responses.
Old 01-09-2013, 07:57 PM   #11
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,324
I've used both CA (super glues) and 2 part epoxies for ceramics repairs, and the slow setting epoxy is the easier to work with and gives the best result.
HapHazard is online now   Reply With Quote
Old 01-10-2013, 09:33 AM   #12
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,850
china weld
http://lepageproducts.com/ProductDetail.aspx?pid=129
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Times are GMT -7.   It's 11:29 AM.
