Old 01-08-2013, 11:39 AM   #1
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,200
Could low octane plug help in cold starts?
I am having cold morning start problems draining the weak battery. At the moment I am grounded.
Would I help the engine to start unplugging the low octane plug?
I would think that lowers advance ignition. Isn't that what we want to help the motor ignite?
What do you think?
There is always a reason!!
Old 01-08-2013, 02:52 PM   #2
Stumpalump
Oddometer: 122
Sounds logical but it sound like you just need a battery. Thump the old one on the concrete to knock the sulfate loose if you need to stretch its life.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 01-08-2013, 10:17 PM   #3
gefr OP
Life is a trip
gefr's Avatar
Oddometer: 3,200
Thnx.
I have a 990 carbed and am messing around with its jetting, so the battery is new but cheap. I got it to die twice in a week so I don't think it has sulfate. Or is it getting sulfate everytime it dies?
Old 01-09-2013, 04:28 AM   #4
Sumi
Sumi's Avatar
Oddometer: 1,191
Doesn't the low octane map only differ from the standard map at higher RPM's ?
Old 01-09-2013, 06:07 PM   #5
Stumpalump
Oddometer: 122
Ever time it dies you are hurting it and leaving it sit while discharged is really hard on a battery.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Old 01-11-2013, 10:59 AM   #6
charlie264
charlie264's Avatar
Oddometer: 5,195
I made a jump pack out of two 12v 7ah yuasa jelly cells I got from work....they are about a £10er each. If my bike battery is lazy I just connect for five minutes and she whizzes into life. The low octane advance timing increases with revs, so not sure how advanced it will be at tick over speeds.
Times are GMT -7.   It's 06:53 AM.
