01-08-2013, 01:15 PM
#1 |
Oddometer: 1,008
Linear Actuator Ride Height Adjuster Recommendations
Hello friends,
It’s time I finally install an electric ride height adjuster on Thing One’s and Thing Two’s VStrom outfit. I installed one when I originally built the rig but that linear actuator proved to be a piece of junk; it would go up and down but would not maintain altitude so I returned it. Would ya’ll mind sharing what makes and models you are using? Which ones work? Which ones to avoid? I found this thread with posts from our good friends Ace and Karl. Ace/Karl, is this model still working successfully? http://www.advrider.com/forums/showt...php?p=12234480 Warner Linear B-Track K2XG20 It would also be great help if you remember where you purchased them and the going rate if you remember. Thanks for your help and Happy New Year. |
01-08-2013, 02:46 PM
#2 |
Oddometer: 630
We get ours from progressive automation. They do not come cheap, over $500 but do not fail, hold up to the weather and do not have play in them which would cause a "clunk" in the suspension.
Jay G DMC sidecars www.dmcsidecars.com jay@dmcsidecars.com |
01-08-2013, 03:24 PM
#3 |
Oddometer: 1,008
Thanks Jay! Hope all is well with you.
01-09-2013, 05:25 AM
#4 |
Stossel for POTUS
Location: Where the stupidest people on earth run things
Oddometer: 23,818
Mine's still working great. It stays put. No creep.
Equal to all of you of roads and good luck! - krokodil al-kashi “We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003 |
01-09-2013, 12:58 PM
#6 |
Oddometer: 1,008
Drone,
Does it wind itself until it's compressed all the way? Clunks: Is it clunking internally or does it have slop in the bolt connections or pivot? |
01-09-2013, 05:39 PM
#7 |
Dog Chauffeur
Oddometer: 2,690
I don't know. I'm not mechanical like you. I just know that all day long I have to keep pushing up, up, up, up on my switch. So it must be going down on its own.
As for the clunking, it seems to be internal. There used to be a tiny bit of play in the mounting points but I went and got some new bushings made to eliminate the slop but I still got the clunking. I had Barry at DMC look at it, and there's nothing that can be seen to be causing the clunk anywhere on the sidecar suspension. Clunking is worse when the actuator is down. In fact, often when I hear the clunk its a reminder that its time to push "up" again. I've never heard of anybody else with this complaint. |
01-09-2013, 07:55 PM
#8 |
Oddometer: 1,008
The actuator that I bought when I first assembled the rig was a cheap Chinese knockoff of a cheap Chinese knockoff.
It would lose all it's altitude in about 2 minutes. Made me mad as hell. I imagine there's only two ways it can lose altitude; either it's 'winding' or it's slipping. Why don't you bring it on by and we will look at it together? I've got good Rye and Cognac on the shelf. |
01-09-2013, 08:06 PM
#9 |
What are we waiting for?
Oddometer: 3,339
That sure sounds strange DRONE. I don't have any known issues with mine at this point. Fingers Crossed...
After what you have said DRONE, I will take a closer eye/ear to that possible issue in the future. I had a friend come over when I first brought it home, and he said that what DMC puts in is very good. He also told me the thing that effects them the most is to not use them. Said I should at least once a month run it full stop up and down to keep the shaft lubed. He knew waaay more about them than I do, thats for sure! I have no problem using it, as I use it ALL the time! Makes it so much easier to drive when I do. If it ever goes out I am going to be in big trouble!
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay I tell it what it wants to hear, and it does what I want it to do. I made that Motronic my bitch. Poolside Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6 |
01-09-2013, 10:04 PM
#10 |
Stossel for POTUS
Oddometer: 23,818
Mine does clunk when the hack wheel gets unloaded. There's a bit of internal play in the device. Nothing new. It's always done that.
01-24-2013, 08:34 AM
#11 |
Mad Scientist
Oddometer: 3,005
What determines the load rating? The force of the shock would be more than the weight of the sidecar.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
01-24-2013, 09:06 AM
#12 |
Oddometer: 1,008
As I've been told from a couple of the distributors, the same models with different load ratings are the same price. What changes is the gearing and speed. The higher load rating, the slower the speed. So, if you don't need it to move fast you could go with a higher load rated unit. Also, I think it has been mentioned already above, the load is significantly affected by the length of the arms on the bell crank (if you are using one).
All that and I still didn't answer your question, BMWEURO. Because I don't know what the load is when the sidecar is loaded, under way, and takes a hit. No idea here. |
03-08-2013, 12:17 PM
#13 |
Mad Scientist
Oddometer: 3,005
I spoke with Jay at DMC and he was kind enough to help with correct actuator, so I ordered and this is what we ended up with. 2000lb and 4" travel.
Taped up so it does not get scratched and figuring where to mount it. ![]() Making a smingarm out of box tubing makes it easier. I made the pivot out of bronze. ![]() ...and this is what it looks like installed. ![]() All the way up. ![]() ...and all the way down.
03-09-2013, 02:56 PM
#14 |
comprador bourgeois
Oddometer: 1,259
Mine crept, clunked, and eventually died. Same with the replacement.
Electric trim is undoubtedly the one mod I would not bother with again. I plan to replace mine with a simple mechanical screw adjuster when I get around to it.
'95 R1100GS '01 R1150GS/Ural '03 Ural Wolf '05 Kawasaki ZZR 1200 '03 Bajaj Legend 150 |
03-09-2013, 05:49 PM
#15 | |
Howling "Mad", Adventurer
Oddometer: 8,801
I have one of those ride height adjusters on my rig that was built by Jay, this is just "MY" opinion but I would strongly suggest mounting the actuator the the reverse of what you now have it. The way you have it mounted all the water and crude will work its way into the guts of the drive motor and up-down mechanizum, you will NOT be happy when that happens. Here is a photo of how Jay mounted the actuator on my rig and all of the rigs he has built the last few years.
Dave, aka "Mr. Cob" Want a STEEL SKID PLATE for your Ural, contact me for details. My photos, http://mr-cob.smugmug.com/ Help a CHEAP bastard keep his Smugmug, use this coupon ( geyYbNZwLLrl6 ) thank you. Mr. Cob screwed with this post 03-09-2013 at 05:59 PM |
