02-21-2013, 09:02 PM
#61 |
Oops...
FRUSTRATED.
Spent about 3 hours trying to figure out how to install the firmware / software / whatever... Nuthin. Still just sits there and wiggles. I'm lost at this point, hoping the support group will have something for me in the morning. Time for some enlightening Castle. Or Bones. Or New Girl. Or The Middle. (Yeah, I know...)
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
02-22-2013, 04:31 AM
#62 |
Oddometer: 4,753
We're looking at buying one of the maker-grade machines, then replacing all the parts with ones made on one of our big machines, so we can fulfill the RepRap vision.
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R |
02-22-2013, 04:35 PM
#63 |
Oops...
Cool beans. Turned out to be just a stupid little thing- a bad USB cable.
![]() One step closer! Will post some steps on how to get it to this point in a bit.
02-22-2013, 05:36 PM
#64 |
Oops...
Alright... so here's the how to get drivers / firmware uploaded... After spending 3 frickin hours last night trying to get this to work only to discover a bad usb cable this morning. Not going to count that 3 hours in the overall time either.
First step: Download the RUMBA drivers from here: http://reprap.org/wiki/File:RRD-RUMBA_USB_DRIVER.zip This part isn't required, but by switching this jumper you don't have to have the printer plugged into power- the RUMBA board is powered by the USB. You can just barely see the pin over the red wire, next to the x axis stepper driver. It's pretty clearly labeled- one side says stand alone, the other usb power. Switch it to usb power so you don't have to have the printer plugged in. ![]() Plug the usb cable in, and you should get a nice blue light on the board! ![]() Time to install the drivers. Remember were you saved them to! If when you plugged in the usb you got a message saying unrecognized device, click it and choose either properties or update drivers. If you missed it, open the "Device Manager" in Windows, and you should see on the list something like this: ![]() See the RUMBA xxxxxxxxxxx with the yellow mark under Other Devices? Right click and select either properties or update driver. ![]() Go through the prompts and show it where you saved the drivers to install. ![]() ![]() There it is! MAKE A NOTE OF WHICH COM IT SAYS IT'S USING!!!! In my case, it is set to COM 3. ![]() Next step. Download and install the latest arduino IDE- here is the most current version at the moment: http://code.google.com/p/arduino/downloads/detail?name=arduino-1.0.3-windows.zip When you run it it looks like this: ![]() Next, download and install the Repetier FIRMWARE, not the software (yet). BOTH are available here: http://www.repetier.com/download/ When you unzip it it gives you a folder full of weird files like this: ![]() Go back to the Arduino software, and using it, open the repetier.ino file in the firmware folder you just unzipped. ![]() This is what you get. A buncha Greek. Or is that Geek? ![]() ![]() We need to change a couple of settings. First, click on the Configuration.h tab. Scroll down and find the "#define MOTHERBOARD XXX" and change the number where the X's are (mine defaulted to 33) to 80. ![]() Now scroll way down and find the Communication configuration section, and set the baudrate. I changed it from "#define BAUDRATE 250000" to "#define BAUDRATE 56000", cause it was recommended SOMEWHERE in the all the reading I did... ![]() Now for the big step. You have to go to the RUMBA wiki and copy the pins.h information. Find it here: http://reprap.org/wiki/RUMBA#RUMBA_F..._Configuration Copy the entire section under Rumba Pin Configuration. Now go back to the Arduino software, and click the pins.h tab. You may have to use the down arrow at the upper right hand corner of the screen to find it on the list. The pins.h seems to have a crap load of different option for different boards. I just scrolled down until I found the numerical order of things (remember, we set the motherboard to 80?) so the stuff I copied I pasted between option 70 and 331. ![]() ![]() Are we TOTALLY LOST YET!? Cause I sure am! ![]() Gets a bit easier now. Once all those changes are made, with the printer hooked up just click upload. It'll take a minute or two but when it says its done, you're ready for the next step. Download and install the Repetier SOFTWARE. Open the software- looks somethin like this. ![]() Now we need to set the software up to communicate with the printer. Click configure, choose printer, and this menu pops up. ![]() You will need to change the COM to the correct one (mine was COM 3) and change the baud rate to match whatever you set it to. Apply the settings, and you should be ready! Plug the printer in to power, and click connect. It should connect and the connect button changes to "disconnect. Scootch over to the manual control tab, and try moving axis around!!! May seem like a lot, but now that I've done it it really wasn't that bad. There is a TON of info on the Repetier website on installing and the hows and whys of printer software, available here: http://www.repetier.com/documentatio...-installation/ Careful with that link though, my brain almost exploded... The sad part? I still am going to have to modify the firmware to set up the thermistors (thermometers on the extruder and heated bed) AND figure out how to set it up so that BOTH z axis stepper motors work at the same time. Ug. Marching forward... Time Spent on this step: Lets call it 1 hr. Total time so far: 14 hrs. 15 min.
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. dorkpunch screwed with this post 02-22-2013 at 05:43 PM |
02-22-2013, 06:27 PM
#65 |
Oops...
One other thing- the guys at Makers Tool Works have been awesome at helping me out with this... They have a webchat channel that anytime so far I've logged in, someone was right there to help me out. Great customer service!
02-23-2013, 10:50 AM
#66 | |
Archvillain
Oddometer: 30,426
![]() You've got to be kidding. Glad that's all it was. Been eagerly following your updates.
Every saint has a past and every sinner has a future. If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl. |
02-23-2013, 11:09 AM
#67 |
Oops...
Still dinkin around with the firmware... I can get it to move but its still not right. Might be another day or two, headed out for a family thing on the snowy roads right now. Hopefully next week.
02-23-2013, 11:15 AM
#68 |
Smellin' da cow poop
Oddometer: 5,151
We have one.
We can make spiders out of Inconel 718. ![]() Have fun.
02-24-2013, 10:23 PM
#69 |
Oops...
Fixed a bad connector, now I have heat! Top one is the extruder, bottom is the heated bed.
02-24-2013, 10:57 PM
#70 |
Oddometer: 6,931
02-25-2013, 06:07 PM
#71 |
Oops...
suhWEET!!!
The software even draws it out for you while it goes. Dry run successful!
02-25-2013, 09:41 PM
#72 |
Oops...
BAM.
02-25-2013, 09:52 PM
#73 |
Oops...
In progress.
![]() ![]() Finished and cooling. ![]() The real first print on the left... had the nozzle too close to the glass. Second one turned out pretty good! ![]() ![]() Looonnng ways to go still, but at least its functional!
02-26-2013, 04:12 AM
#74 |
Oddometer: 4,753
Great work.
I find a lot of useful "stuff" on grabcad.
02-26-2013, 05:54 PM
#75 |
Oops...
Workin some bugs out...
![]() ![]() ![]() ![]() Some rough math means each of them key chains cost about $250. Cost will drop substantially the more parts I make.Still lots to do- need to level the bed, figure out limit switches, figure out why after about 5 minutes of printing it suddenly goes from a normal feedrate to almost non-existant...
| Thread Tools | |
