Thread Tools Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Old 03-09-2013, 11:28 AM   #121
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Any particular reason for those speeds? Still learning, and there seems to be a huge range of speeds people use. I tried cranking mine up a bit- 120mm/s for the spool although the cylinder part is all boundary's so it only printed at 60. Seems like others with my printer are running at 130 without problems.
Finished spool holder installed. One screw down through the center. Still need to make and instal a tensioner to keep the spool from unwinding itself but I have an idea for that.
Spool on.
And why I think its WELL worth the extra $$$ to buy the plastic on a spool.
Thought I could adapt that wire feed welder spool to the plastic, and it would probably be okay but I've been using the plastic and its got itself snarled up pretty good. Not looking forward to untangling that mess.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 03-09-2013, 11:34 AM   #122
nulluser
Oddometer: 145
The small parts don't seem to work well with the higher speeds. I just experimented until I was happy with the printing time and finish. Still learning to diagnose issues by looking at the print result. I don't think these things are an exact science.
nulluser screwed with this post 03-09-2013 at 02:27 PM
nulluser is offline   Reply With Quote
Old 03-10-2013, 09:09 PM   #123
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Wow, that's pretty cool!
Playing around with cooling fans... Had an idea. It's rather pointless, but thats kinda how my mind works anyways.
Most printers, if they use a cooling fan, just hang it off to the side so it blows on everything. I'm wondering how it would affect prints to just cool the fresh extrusion, so I designed and printed a duct for the fan, and piped it in by the nozzle.
Eventually, I want to build a cooling jacket around the nozzle itself so the cool air goes straight down, all around the nozzle. For now, if you can't tell by the tape and zip ties, this was a test.
The test piece. Its teeny- about 1/2 an inch cube.
Test results.
Cooled piece on the left, uncooled on the right. Not much air is moving out of the tube, but enough to make a difference!
Next step, design a cooling jacket to go around the nozzle...
-Charles De Mar.
Old 03-10-2013, 09:45 PM   #124
troidus
Oddometer: 15,791
Dyson makes a room fan. You might look at that for inspiration.
troidus is offline   Reply With Quote
Old 03-11-2013, 06:29 AM   #125
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
A fan isn't a good choice for a directed jet of air. They move volumes of low pressure air. Your shop doesn't have a compressed air line you can use?
I am a conservative, not a Republican. There is a difference.
JamesG is offline   Reply With Quote
Old 03-11-2013, 09:05 AM   #126
garandman
Wandering Minstrel
Oddometer: 6,282
Some of the Stratasys FDM machines have a plastic air plenum which directs thermostatically controlled cooling air to both sides of the tips (they have two).
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 03-11-2013, 03:12 PM   #127
nulluser
Oddometer: 145
I have read that it's a good idea to insulate the nozzle if you are going to have a cooler. Helps with temperature stability, and keeps the controller from working too hard.
Old 03-11-2013, 05:51 PM   #128
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
My extruder has two layers of "insulation" over it already...
Here's my nozzle idea.
Tried printing the nozzle part earlier but the stupid program froze.
-Charles De Mar.
Old 03-12-2013, 05:34 PM   #129
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Made some changes and reprinted. Got most of the way done and one of rods popped out and the extruder knocked it off before it was done, but its close enough that I'll give it a try. Might even be better this way- more air flow...
Betting it melts on the very first print. We'll give it a try later this evening.
-Charles De Mar.
Old 03-12-2013, 09:30 PM   #130
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Well it didn't melt...
-Charles De Mar.
Old 03-12-2013, 09:32 PM   #131
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,899
Nice!
c.vestal is offline   Reply With Quote
Old 03-15-2013, 04:05 PM   #132
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Nothin new to report... Havent been able to touch the printer all week. I *DID* finally get the updated z-axis parts from the beta 2 kit, so I'll probably be swapping parts around next week or over spring break. SOoooooo many things to do, so little time!
-Charles De Mar.
Old 03-17-2013, 01:56 AM   #133
Shadow10
Oddometer: 602
Ok so I have finally caught up on this thread. Great stuff dorkpunch. Very comprehensive.
I have also been reading all sorts of other stuff. Theres more than a few people stating that this technology is going to be the biggest thing since the industrial revolution itself.
So my question to all and sundry - With some knowledge and experience under your belt, is there a machine you would recommend for someone starting out, as a good device to learn on?
Knowing what you know now, what if anything, would you do differently if you were starting over?
Shadow10 is offline   Reply With Quote
Old 03-17-2013, 05:09 AM   #134
garandman
Wandering Minstrel
Oddometer: 6,282
What's your goal and your budget?
Are you a designer or engineer or is this a hobby project?
Do you want to assemble a system or buy one ready to run?
Do you want to be able to use the parts in the real world or just make shapes for fun?
Do you have CAD software?
Press references to "3D Printing" have increased two orders of magnitude in the last year, culminating in President Obama's discovery of the technology [first introduced in 1988] in his Inaugural Address. The upside is that more people are becoming familiar with the technology and exploring ways to use it. The downside is there are a lot of ridiculous claims. One industry estimate is that 40% of all kits sold are never completed.
IMHO the best thing about the Maker Movement in general and 3D printers in particular is that it is helping interest kids in math, science and engineering.
Old 03-17-2013, 12:40 PM   #135
dorkpunch OP
Oops...
dorkpunch's Avatar
Oddometer: 5,361
Tough question, one I don't really know if I can give you good answers to.
I looked around at a few different printers when I first was wanting one... I did what I thought was a fair bit of research and comparisons. There are hundreds of different kits out there, with new versions continually coming out of the woodwork. It seems a useable desktop version will run you anywhere from $700 to $2,500, and they can be fully assemble or a total kit. You can choose whatever you want that will meet your needs- the hard part is knowing what your needs are.
I don't feel like I can recommend one printer over another, because this printer is literrally the only one I have ever seen / used in person. That said, from my research I think the Mendelmax 2.0 is a great kit. WAY less parts to put together, good quality prints, EXCELLENT support from makerstoolworks.com, and overall a well thoughtout product with the ability to be modified and expanded very easily. Price isn't too bad either... Its definitely not the cheapest kit out there but its far from the most expensive too. I do also like the use of aluminum for the frame instead of printed parts- I know that means its not really a "reprap", but in my opinion the ability of a printer to reproduce itself is more of a novelty. As more materials become easily printable (like metal) the "reprap" end of it will be more... Usefull?
So my answer, I guess, is that if I were to start over I would probably still get the Mendelmax 2.0. I really lucked into getting it, and I'm glad I did. My next choice was the Mendelmax 1.5m which also seems like a good kit, cheaper, and does good prints. The wiring / electronics are basically identical, but there are way more parts in the frame.
I also agree with what garandman said- From what I have seen lots of people buy the kit, and either loose interest or get frustrated and quit. It was a HUGE learning curve, and to this date I estimate I have about 30 hours invested in building the kit and then learning how to use it. If its something you want to do, DO IT! Just realize that a kit is NOT plug and play- there are alllllllllll kinds of things to fiddle with and adjust- frame (squaring, leveling, etc.), electronics (wiring, correct ports, etc.), programming (firmware installation / setup, print control software, etc.), operating the stupid thing, and then of course we haven't even touched on the question of what are you making your 3D drawings with and how are you converting them to a format the printer can understand...
I would hazard a guess that in the next 5 years you WILL see plug and play printers, probably at your local Walmart. Until then, buy a kit, experiment, and HAVE FUN!
-Charles De Mar.
Thread Tools
Times are GMT -7.   It's 04:44 AM.
