01-08-2013, 05:26 PM
#1 |
anarchocapitalist
Oddometer: 972
Have tried to several times but the double blip not working for me when logs are wet and at an angle. I know it should not work. The front tire goes over but when the rear tire touches to log, the bike slides....what's the trick? I know the rear tire should jump over the rear log....help! Thanks!
Government is the negation of liberty--Ludwig von Mises Road Reports by ejtv click here |
01-08-2013, 08:02 PM
#2 |
Oddometer: 774
The trick is hours and hours of practice. How much air are in the tires? 6 in front and 4 in the back. How big of logs? Are you trail riding or trials riding? It is all about timing. The main thing with wet logs is to make sure you are unloading your own weight. You might quit the double blip and just bunny hop or jump over. The splatter would be more correct when wet, but might bring a fast fall !
01-09-2013, 12:28 AM
#3 |
Oddometer: 815
Try
3Rd Gear.................
01-09-2013, 04:30 AM
#4 |
gooligan
Oddometer: 4,327
ice screws
01-09-2013, 04:43 AM
#5 |
Oddometer: 774
Actually the worst are the small 2 inch ones. They catch you off guard !
01-09-2013, 05:45 AM
#6 | |
Buffoonery, Inc.
Oddometer: 2,273
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. |
01-09-2013, 08:34 AM
#7 |
Trails Evangelist
Oddometer: 967
The trick is you haven't learned how to hop the rear wheel up over or almost over the log. it's called "unloading the rear wheel". It's something that you might want to practice when it's not slippery, but the idea is to get all your weight off of the rear wheel before it hits the log, and actually do a bunnyhop over the log as much as you possibly can. It still may slip so what I usually do is pull clutch in some, at the same time I'm jumpin ( in the act of it) so that it doesn't have full power to the rear wheel, then it ( the rear tire ) can kind of grip.
Sent from my SCH-I535 using Tapatalk 2 |
01-09-2013, 12:52 PM
#8 | |
Oddometer: 33
Unloading or un-weighting the rear wheel is the way to go... not easy though. |
01-09-2013, 01:05 PM
#9 |
Professional Idiot
Oddometer: 927
As others have said, it's all in the unweight and the timing. I wouldn't worry about any other techniques at this point if you are a noob to trials. The little double-blip unweight will work when you get it right and the basic technique will eventually come easy for you. I'm a relative noob myself, just having finished my second year of riding. I'm amazed at the things that are now easy for me compared to when I started. I'm also amazed at how much better many riders are.
![]() In the video below, you can see the steps for a basic rear wheel unweight to cross a small log. It doesn't take much - you just need to remove your own weight from the bike so that it effortlessly rolls over the log. When you do this, the rear wheel is much more likely to track straight over a wet/angled log. Note how when the rear wheel does hit the log, the knees are bending and allowing the bike to continue to come up instead of pushing downward on the pegs. As the logs get bigger, the technique is the same - just bigger. motojunky screwed with this post 01-09-2013 at 01:23 PM |
01-10-2013, 05:52 AM
#10 |
Oddometer: 45
Great video. Thanks.
I can see it helps to have a lot of room between your butt and the bike, as well as a bendable rear fender. I like to practice like that with my twin shock but have hit the rear frame loop, seat and/or fender more than once.
01-10-2013, 08:28 AM
#11 |
anarchocapitalist
Oddometer: 972
Thanks! Will practice unloading the rear wheel this weekend! Video was a huge help!
01-10-2013, 10:16 AM
#12 |
Oddometer: 246
Search for some of 2-plys log crossing video's - he really breaks down the sequence (in slow motion) and also shows/talks about the important 2nd phase of the unload.
In general. the greasier the conditions, the more important the clean technique and exaggerated body motion. You can get away with alot in dry, high traction conditions - so practice in the wet is really a great way to learn. When you do it right, its amazing how much difference it makes. (on all levels) |
01-10-2013, 10:18 AM
#13 |
Oddometer: 246
heres a link to the thread (on TT) with lots of good log crossing info.
http://www.thumpertalk.com/topic/964...ing-technique/ |
01-10-2013, 10:32 AM
#14 | |
Professional Idiot
Oddometer: 927
01-10-2013, 01:40 PM
#15 |
Oddometer: 993
The single most important thing that doesnt seem to have been mentioned, is that pretty much all trials riding is directly related to good throttle control. Without this, even if your basic technique for different obstacles is pretty close to perfect, you are likely to fail an awful lot.
