Old 10-21-2014, 08:37 PM   #1
skeelo221 OP
Oddometer: 107
2013 KTM 350 EXC - Electrical Questions
Hello,
I just picked up a KTM 350 EXC-F that had the horn and rear blinkers removed.
I am attempting to re-install the stock horn.
I just wanted to confirm that these wires are the correct ones for the horn? The horn does not fire and I do not get continuity to the wires when I press the horn button... All I have checked is fuse 4 and it's in working order (and the front blinkers work which run off the same fuse).
Can someone please confirm the blue/yellow lead runs to the horn?
skeelo221 is offline   Reply With Quote
Old 10-21-2014, 08:39 PM   #2
skeelo221 OP
Oddometer: 107
I am also trying to install some Sicass flush mount rear blinkers. The wiring has been removed and I wanted to confirm I need a new harness (with the square connectors to connect the blinkers) to plug into this plug?
Old 10-21-2014, 08:40 PM   #3
skeelo221 OP
Oddometer: 107
And finally! What is this connect for? I found it unplugged under the headlight mask.
Old 10-27-2014, 10:09 AM   #4
skeelo221 OP
Oddometer: 107
Yup. Issue was a bad connection in the horn button itself. I had to disassemble the entire thing and upon cleaning/re-assemble all is good.
Times are GMT -7.   It's 01:48 PM.
