01-27-2013, 09:11 PM
#76 | |
Oddometer: 46
Is this something I can defer to after my 20-minute break in? I'll be checking the oil screen at that point too. (I think I already know the answer to this...) rectangular screwed with this post 01-27-2013 at 09:19 PM |
01-27-2013, 09:53 PM
#77 | ||
Lust for dust...
Oddometer: 6,047
... grease, grit, and mud are runnin' in my blood. |
01-27-2013, 10:51 PM
#78 | |
Oddometer: 46
01-28-2013, 07:26 AM
#79 | |
Oddometer: 3,814
If you used silicon or such on the gasket, I'd leave it. The bike only has 12k on the clock and you found the reason for the oil starvation. You didn't note excessive metal, which would have trashed the oil pump. Gummy worms won't. If you just used the OEM gasket, then it wouldn't be a bad idea, but not really necessary. Personally, I'd run it.
"Deeply flawed people make deeply flawed decisions." |
01-28-2013, 08:04 AM
#80 | |
Paint it black.
Oddometer: 12,870
I wouldn't risk it, if the top end was starved of oil, so was the pump. The bottom is splash lubed, the pump is a metal on metal type of pump, it has to have oil to lube itself. It's one wasted gasket, take it apart and check it. |
01-28-2013, 08:50 AM
#81 | |
'tard bike restos
Oddometer: 438
OEM/Kawa
EDIT: no slam meant on DirtyDog, BTW.
08 KLR, 06 KLR w/Sputnik sidecar, 72 CB350F ADW screwed with this post 01-28-2013 at 09:18 AM |
01-28-2013, 08:56 AM
#82 |
Oddometer: 46
Will do. It shouldn't take very long anyways. I'm getting pretty familiar with both sides under the engine covers.
01-28-2013, 09:12 AM
#83 | |
Paint it black.
Oddometer: 12,870
If you're careful you might be able to save the gasket. The oil pump surface should have a mirror surface, use a hand impact driver to get the screws out. |
01-28-2013, 09:20 AM
#84 |
'tard bike restos
Oddometer: 438
A tip I learned a while ago is when you're putting on a new gasket, coat one side of the gasket with a light film of grease. Just a light apply, not much. That will be enough to prevent it from sticking to the metal when you remove the cover again someday but won't hinder it sealing.
I tend to grease the side than goes toward the engine, not the case. This is because it's easier to scrape the gasket off a case that you can take to the bench or whatever than the engine itself.
08 KLR, 06 KLR w/Sputnik sidecar, 72 CB350F |
01-28-2013, 10:06 AM
#85 | ||
Oddometer: 46
Also, I haven't found a definitive answer if the side cases on the KLR should have silicone gasket maker (rtv bond/hondabond/etc) applied to the paper gaskets or not. Are the paper gaskets just applied as is? Seems strange to me. |
01-28-2013, 10:18 AM
#86 | |
Paint it black.
Oddometer: 12,870
Then use your biggest fattest phillips head and tap on the handle with a hammer while turning. Impact driver is about $10, can be found everywhere. The only place a KLR engine needs sealant is the center cases, no paper gasket there, you found the result of using too much goo on the center cases. A dab of RTV on a new valve cover gasket will help hold it to the cover when you install it, don't go crazy, apply long before you want to put it back on. Awesome tip on the grease idea, ADW!!
01-28-2013, 10:58 AM
#87 | |
Oddometer: 46
Also, I'm probably going to be going in and checking on the oil pump tonight. Anything specific that I should look for once I remove it? rectangular screwed with this post 01-28-2013 at 11:08 AM |
01-28-2013, 11:06 AM
#88 |
Paint it black.
Oddometer: 12,870
01-28-2013, 11:20 AM
#89 |
Oddometer: 46
01-28-2013, 11:43 AM
#90 |
Oddometer: 3,814
Don't forget to prime the oil pump after disassembly.
