Old 01-09-2013, 01:57 PM   #1
indr OP
Oddometer: 501
Cleaning Engine Sludge
indr screwed with this post 02-22-2015 at 09:46 PM
indr is offline   Reply With Quote
Old 01-09-2013, 03:30 PM   #2
sparkymcgee
sparkymcgee's Avatar
Oddometer: 340
I've heard Pine Sol is the go to cleaner for engine parts. Haven't tried it, but I've seen pics and things come out gleaming.
2008 VFR800
2012 Super Ténéré
sparkymcgee is offline   Reply With Quote
Old 01-09-2013, 04:23 PM   #3
Beezer
Oddometer: 5,947
kerosene, diesel, mineral spirits, gasoline.... something petro
Beezer is offline   Reply With Quote
Old 01-09-2013, 05:37 PM   #4
RTCHIEF
Oddometer: 334
engine
Have it hot tanked.
RTCHIEF is offline   Reply With Quote
Old 01-09-2013, 07:33 PM   #5
CaptTeach
Oddometer: 209
Easy Off oven cleaner in the yellow can - Place in the sun to warm up the part then spray Wait twenty minutes or so and either re-coat or rinse with water
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-09-2013, 07:51 PM   #6
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,361
Originally Posted by RTCHIEF View Post
Have it hot tanked.
No - that will effectively dissolve aluminum.
Try the PineSol first.
HapHazard is offline   Reply With Quote
Old 01-09-2013, 08:19 PM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Murphy oil soap, that's to clean wooden floors, not much degreasing power.
I king of object to some of the above suggestions, Caustic Lye products such as hot tanks or oven cleaners, really bad for aluminium. But I can be patient and don't have a problem picking at stuff for a long time.
Go buy some Castrol engine cleaner/degreaser at CT.
Have tools, will travel!
Old 01-09-2013, 11:44 PM   #8
Beezer
Oddometer: 5,947
if petro products don't work try paint stripper... it has methyl chloride which one of the really good cleaners we used to have in the old days, but bear in mind there are reasons it isn't used for that anymore... like it's pretty evil on your body. I brush it on and cover it with plastic sheet to keep it from evaporating
if you buy "gasket remover" in a spray can thats all it is... paint stripper
Easyoff is ok on stainless steel but be careful on aluminum... it can eat alloy
Old 01-10-2013, 04:19 AM   #9
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,433
Spray wand at the car-wash, hot soapy water. Have WD-40 WITH YOU to stop the IMMEDIATE rusting on the steel bits.
Old 01-10-2013, 08:13 AM   #10
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
^ right here!
Murphy's oil soap? THAT is a truely novel application for this product . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 01-10-2013, 02:13 PM   #11
redprimo
Oddometer: 556
Dishwasher works great on chainsaw cases.
redprimo is offline   Reply With Quote
Old 01-10-2013, 02:30 PM   #12
ragtoplvr
Oddometer: 6,638
Vote for car wash, use lots of rinse. You are in BC so it is cold, keep case from freezing until you blow out well. When home blow out all passages real well. Bake in oven if at all possible at 225 for an hour minimum to dry all parts. Alternate put some place warm like near your wood stove or over a heat vent.
Rod
ragtoplvr is online now   Reply With Quote
Old 01-10-2013, 04:33 PM   #13
troidus
Oddometer: 16,303
And on an aluminum wheel from a salvage yard.
troidus is offline   Reply With Quote
Old 01-10-2013, 04:40 PM   #14
RTCHIEF
Oddometer: 334
How do engine rebuilders clean oil from aluminum?
Old 01-10-2013, 06:44 PM   #15
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,294
Gunk Engine cleaner.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Times are GMT -7.   It's 05:28 PM.
