Old 01-09-2013, 09:36 PM   #1
777 OP
Oddometer: 92
690 Starting issues
If my bike is cold , standing over night will start on first or second press of stater button , but if hot have to press 4 or 5 times , BUT if you turn bike off with button on handle bars and leave ignition key switch on then bike starts one time when hot , so only battle to start when hot if turn key off , but if key remains in ON position it starts fine , any ideas ??
777 is offline   Reply With Quote
Old 01-10-2013, 06:35 AM   #2
777 OP
Oddometer: 92
Wow must be a seruois problem 115 view no replies??
Old 01-10-2013, 06:36 AM   #3
Bigbugberg
Meatbucket Supreme
Bigbugberg's Avatar
Oddometer: 325
Read through the 690 Wunderfest.
Lots of good information there
Bigbugberg is offline   Reply With Quote
Old 01-10-2013, 06:43 AM   #4
777 OP
Oddometer: 92
I have searched this forum and others, lots of info, but non on my specfic issue, thanks
Old 01-10-2013, 06:47 AM   #5
Harpoonalt
Harpoonalt's Avatar
Oddometer: 299
I amost didn't look because I hate looking up words I don't know.
Harpoonalt is offline   Reply With Quote
Old 01-10-2013, 07:04 AM   #6
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
Sounds like it's having problems w/ too much fuel. If you leave the bike on the fuel pump does not cycle, but when you turn it on and off it cycles to pressurize the system.
That's all I got, sorry.
Old 01-10-2013, 07:12 AM   #7
yuu
yuu's Avatar
Oddometer: 122
How about some more info on the bike?
Year? Miles? Age of the battery? Fuel filter replaced? Fuel injector cleaned? Exhaust or intake mods?
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-10-2013, 08:11 AM   #8
777 OP
Oddometer: 92
2008 13 000km, valves check and mapping and TPS, auto decompresstion checked, battery 16 months, still strong, after market exhaust(Doma) fuel injector cleaned with injection fluid, no intake mods.
Old 01-10-2013, 08:12 AM   #9
777 OP
Oddometer: 92
Could be correct as when i try start it i smell petrol, solutions??
Old 01-10-2013, 08:22 AM   #10
yuu
yuu's Avatar
Oddometer: 122
Fuel filter?
And you've cleaned the injector with in-tank fluids - vs removing it and having it professionally cleaned?
What mappings are you using?
Old 01-10-2013, 08:25 AM   #11
yuu
yuu's Avatar
Oddometer: 122
I'm pondering that you may have a fouled injector that isn't producing a fine easy to ignite spray. Instead it's producing a harder to burn dribble
Old 01-10-2013, 09:31 AM   #12
777 OP
Oddometer: 92
Correct i have not had th einjector profesinally cleaned, i did put new filters in, i am using map 3. I agree the injecotrs could be dirty, but why would that make a diffence that it starts if i leave ignition ON, but if i turn key off an dthen on again it battles to start, and i do wait for it for it to cycle through.
Old 01-10-2013, 09:41 AM   #13
yuu
yuu's Avatar
Oddometer: 122
Map 3 meaning? Just the #3 selection on the under-seat switch?
I was referring to the alternative fuel and throttle table mappings one can upload to the bike with TuneECU or similar program. If you're running the factory installed maps, with an aftermarket exhaust it can cause some minor issues - but not always.
Honestly, I'm not sure if the state of your injector is directly related to you issue. But at much less milage mine was in a rather sad state - so it is probably not helping.
It does sound like fuel pressure may be the root cause. As noted when you turn the bike on from the key, the pump runs briefly. If you cut the ignition (at the bars) but leave the key to run then it does not. Which would lead one to conclude that too much pressure might be the problem - but that seems counter intuitive.
Is it feasible of you to test the fuel pressure?
Old 01-10-2013, 09:48 AM   #14
777 OP
Oddometer: 92
Txs for feed back, give me something to work and and to tell the workshop
Old 01-10-2013, 09:58 AM   #15
yuu
yuu's Avatar
Oddometer: 122
If you're not in a rush - I'd have the injector out and professionally serviced. I just did mine - it's about $22 US
The shop replaced the o-rings, replaced the stock plastic screen which was noted as disintegrated with a stainless steel, tested it before and after, providing a report and of course cleaned it. It looked like it had just rolled out of the factory.
It's pretty easy to remove the injector - no need for a shop to do that
Regarding fuel pressure - the tech manual has the fuel pressure and flow rate in it as well as the test procedure. A shop should have the equipment to do the testing - but you should ask them if they have it as not all might.
Times are GMT -7.   It's 07:24 AM.
