Old 01-09-2013, 11:08 PM   #1
jordan325ic OP
Oddometer: 255
Perfect easy to maintain bike?
My rain or shine daily rider is a 1979 Kawasaki KZ400 that is as UJM as can be. I love the seating position, the luggage capacity, the aesthetics, the reliability, the fuel economy, the affordability of consumables.
But what I love most of all is the ease of maintenance. I enjoy getting my hands dirty and I love working on a simple, old-school design with minimal electronics. I love that I can disassemble the entire bike down to the frame with the 10 piece toolkit under the seat. I love that the sparkplugs hang right out there in the air. I love the centerstand. This is a motorcycle that was designed to be maintained regularly and easily by the home mechanic. Mechanical purity I guess you could call it.
What I do not like is the exhaust note, could use a little more power for big Texas highways, and almost every bike I've owned up until this point has been a parallel twin and I want something different.
I am happy with my bike now, but I want a bike that will be my daily rider for the next decade. I am looking for my perfect bike.
I want my next bike to have:
Minimal electronics
Straightforward and pleasurable to maintain (frequently is fine),
No plastic fairings.
40+hp at the rear wheel
45+ mpg
Air cooled
No more than 2 carbs
Cheap, available parts
Durable (50k+ miles) engine
I know this is subjective, but a decent exhaust note.
I know this list seems very picky but if anybody has any ideas of any bike that meets these criteria I would love to hear them. I've thought of many bikes that almost make it but I've yet to find my winner (sportsters can't have centerstands, cb750s have too many carbs).
jordan325ic screwed with this post 01-10-2013 at 08:56 AM
jordan325ic is offline   Reply With Quote
Old 01-10-2013, 04:14 AM   #2
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
V-strom
Old 01-10-2013, 05:34 AM   #3
hugemoth
hugemoth's Avatar
Oddometer: 3,033
The CX/GL Hondas are my favorite for everyday transportation. Yes, they're liquid cooled but that's my preference. Shaft drive, tubeless tires, good storage, standard seating position, large gas tank, legendary longevity, very low maintenance that's easy for a DIYer, 50 hp, and a really nice exhaust note.
Old 01-10-2013, 05:50 AM   #4
Growl
Oddometer: 77
883 Sportster
a fairly modern Harley Sportster would satisfy all of your requirements
Growl is offline   Reply With Quote
Old 01-10-2013, 06:26 AM   #5
zataomm
zataomm's Avatar
Oddometer: 360
You'd have to give up your centerstand requirement but a Sportster would do it for you, especially an "R" model with mid-controls. I have an XL1200R and have changed the stock seat to a Harley Sundowner (way more comfortable), added saddlebags and a small National Cycle windshield and couldn't be happier. Hydraulic valves, belt drive, single carb --- very low maintenance. Had to swap out the starter, but other than that it hasn't needed anything other than regular service.
Very easy bike to own.
2004 XL1200R
zataomm is offline   Reply With Quote
Old 01-10-2013, 06:49 AM   #6
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,577
airhead?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-10-2013, 07:46 AM   #7
mitchxout
mitchxout's Avatar
Oddometer: 542
Isn't this the Old's Cool forum? Are you guys lost? V-Strom, sheesh.
mitchxout is offline   Reply With Quote
Old 01-10-2013, 08:12 AM   #8
davevv
One more old rider
Oddometer: 2,369
Check Moto Guzzi, they are all pretty easy maintenance wise. They do require occasional valve adjustments, but most are 5k mile or greater intervals and they are screw and locknut adjustments on heads that stick out right in front of your face while you're doing the work. Otherwise, it's pretty much a change fluids and ride proposition. They have been made in sport, sport tourer, standard, and cruiser configurations and from 650 to 1200cc. If you want no valve adjustments the 2003-5 Californias have hydraulic lifters, but make sure all the recalls have been done on the bike.
The new Triumph Bonneville series would also be a good fit. Valve adjustment intervals are 12k IIRC, but they are shim and bucket type. Otherwise, maintenance is dead simple and they are very reliable bikes. If the Bonnies feel a little small ergonomics wise, try the Scrambler as it feels quite a bit different.
"Fast is fine, but accuracy is everything"--Wyatt Earp
'13 Yamaha Super Tenere.
'04 Sportster XL1200R
davevv is offline   Reply With Quote
Old 01-10-2013, 08:50 AM   #9
jordan325ic OP
Oddometer: 255
I actually like doing maintenance, so I don't mind short valve adjustment intervals or anything like that. When I say "easy to maintain" I don't mean that as a function of time. I'm sure the V-stroms/PC800s/KLR650s are quite reliable and would require very little of my time overall. What I mean is that doing maintenance is a straightforward and pleasurable experience, even if I am doing it every weekend.
For example, I've got an old ninja 500 I'm putting together. Relatively simple bike, but every time I have to unscrew the fairing, take off my gas tank to put my specially-purchased 18mm thin-wall into a deep crevasse just to pull out a spark plug, it makes me certain that this bike is not for me.
Old 01-10-2013, 09:12 AM   #10
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,545
how many miles per year?
Honestly, my Triumphs are a marvel of simplicity and have been stone reliable. I've added oil filters to them and with proper maintenance they will go the 50k you state. You can hardly get any easier to adjust valves (just look at them, no need to remove the tank), and it's a single carb. If you went as far as putting a belt drive primary it would be even easier but not necessary.
You will be hard pressed to find even a modern bike where you can get parts as easy as a nice old 60's or 70's Triumph.
My 70 Tiger or 71 Trophy hits every single thing on your list in spades (although the HP will be close depending on what reports you read and assuming you want an 'old school' bike).
I'd also include my Norton, which has been just as reliable but is a bit more of a challenge to start than the 650 Triumphs. Takes a healthy leg to be sure. They Triumphs are a piece of cake by comparison.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is offline   Reply With Quote
Old 01-10-2013, 09:13 AM   #11
Tim_Tom
Oddometer: 556
Easy maintenance, everything accessible and easy to reach, no special tools, a centerstand!
45+ mpg
Air cooled
How about a Suzuki GS500. Not the original 4 cylinder motor, but the 89 and up model twin cylinder. Makes about 50 hp, great mileage, dirt cheap to run, and only has two carbs. Not to mention it's lightweight and can be ridden quite sportingly. Seems to meet all of your criteria. Get the standard naked model with no fairings to get in the way and everything is easily accessible. It has been built largely unchanged for 20+ years so parts are aplenty.
I would also recommend a bigger Suzuki GS shaft drive. While they do have 4 carbs, they are incredibly simple, and easy to maintain. I can have the airbox and carbs off of my 850G in about 10 minutes. Simple. Another plus is shaft drive meaning no chain to mess with, and they handle excellently. No shaft jacking or similar problems. Plenty of power to comfortably cruise on the highway, it will run 85 mph all day without breaking a sweat. If you are looking for a bike that could be capable of touring for longer distances the Suzuki is great. Very comfortable for one, or two people.
I know you said you wanted something with two carbs, but the GS's CV type carbs really are a set and forget thing. They work just as well at sea level as they do at 11,000 ft. A good clean, and sync (very easy to do) and the GS will run like the dickens. It's an overbuilt engine that has been proven to run 100K+ miles easily, provided the owner keeps up on the scheduled oil changes and valve adjusts. Both are simple and rewarding to do, and easily handled yourself.
My GS850G. I took this bike on an 8,000 mile cross country ride this past summer, and it performed fantastically for a 30 year old machine.
Hope you found my post helpful.
Tim_Tom is offline   Reply With Quote
Old 01-10-2013, 09:26 AM   #12
Martian
Oddometer: 1,104
May I suggest a 90's era BMW airhead like this one.
It is available, too.
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 01-10-2013, 09:31 AM   #13
Eddy Alvarez
Addicited to ALL bikes!
Eddy Alvarez's Avatar
Oddometer: 2,330
I vote for any 80's 650 Nighthawk with hydraulic valves, hydraulic front brake/clutch, shaft drive and centerstand. Give it one day of love in the garage every six months and it will give you 20+ years of faithful, quiet service.
650 V-Strom, 2005 or newer Sportsters/XR1200, KLR, Suzuki GS500, Moto Guzzi V7, late 80's/early 90's Shadows or any 90's air cooled BMW are good choices as well.
Me: Honda CB1100 BMW R1200GS KTM 525EXC. Gabriel: KTM 50. Elena: Honda CRF70. Lynn: Sugar Momma and Gatorade/snack girl!
Eddy Alvarez is offline   Reply With Quote
Old 01-10-2013, 04:29 PM   #14
jordan325ic OP
Oddometer: 255
Guzzi's - The 80s V50s and V65s definitely look like they could be the bike for me, but what about parts availability? I can't even find a used V50/V65 for sale. Are all the necessary parts available?
Oh man, and they can even come with a kickstarter... I want one! Too bad there isn't a single V50 for sale anywhere.
The GS500 looks good on paper but having worked on one... no thanks. I hate the double petcock system and the shim-and-bucket valve adjustments.
CX500's are definitely pretty cool bikes, but I seem to recall there are a few pretty major internal seals/gaskets that tend to go bad and are now unavailable?
Old BMWs... I don't know enough about them really. I've read about high technology, paralever problems, and they're expensive. Plus I don't think they sound good. Isn't the fuel economy not that great either?
There are a ton of great, reliable, old-school UJM 4 cylinder bikes, but the complexity of a 4 cylinder/4 carb motor just doesn't appeal to me, bulletproof though they may be.
A sportster 883 ticks all the boxes and this country is overflowing with bikes, parts and dealers. Character, old-school design, fuel economy, longevity... if only I could add a centerstand...
Does anybody know what exactly the problem is with adding a centerstand to a solid-mount evo sportster? I think most Harley guys don't care about a centerstand so I haven't found too much information about it, just that it can't be done.
Old 01-10-2013, 04:49 PM   #15
Gham
Gham's Avatar
Oddometer: 1,319
Minimal electronics
45+ mpg
Air cooled
I like the looks!I guess I never thought about a 70's Kawasaki being all that reliable though.Shame on me.
Something about a mid-displacement twin always makes me think Honda.
Member 6204
Society Historicus Revisioniscus
Gham is offline   Reply With Quote
Times are GMT -7.   It's 08:16 AM.
