01-10-2013, 05:01 PM
#16 |
Not Dirty Yet
Oddometer: 26
Goose, Goose ... Duck?
Probably a bit too pricey and perhaps a tad less reliable than some, but an early '80's Ducati Darmah is a fabulous machine.
01-10-2013, 05:02 PM
#17 | |
Oddometer: 120
Mabey convert a 4cyl UJM to 2 carbs? Wouldent be easy or cheap though. I'm not sure what bikes exist that fit your wants other than Jap' Parralel twins and a few Vtwins. I'm not sure if guzzi's fit the bill on parts availabilty.
Kyle. 1980 Suzuki GS450 Confused bitsabike.
01-10-2013, 05:05 PM
#18 |
Not Dirty Yet
Oddometer: 26
Great thought
The VT500 Ascot is a GREAT bike!!!
Possibly a Suzuki VX800 as well? |
01-10-2013, 05:40 PM
#19 |
bikaholic
Oddometer: 1,540
It seems that what you're looking for is barely more than what you have now.Run the wheels off the Kawasaki.
01-10-2013, 06:07 PM
#20 | |
Kickstart Enthusiast
Oddometer: 1,818
+1. Keep what you have, it's exactly what you're looking for. But a Suzuki VX800 is an intriguing choice. Just old enough (in my opinion) to qualify as old's school, and they have a 45 degree cylinder alignment, so with the right exhaust system, they'd sound just like a Harley, yet they're built along more sportbike lines. |
01-10-2013, 06:18 PM
#21 |
Oddometer: 303
Simple
DR650
Enough said.
01-10-2013, 09:49 PM
#22 |
Chordate
Oddometer: 3,536
I'd second the Suzuki GS500 twin. We bought one as Skowinski-wife's first street bike. It turned out to be a great machine, very capable - much more so than I expected, and easy to maintain.
"I would rather sit on a pumpkin and have it all to myself, than be crowded on a velvet cushion." - Thoreau |
01-10-2013, 10:17 PM
#23 |
Oddometer: 90
My 1978 Yamaha XS650 SE meets all of your requirements. Its about 48 HP and gets 55 mpg. It has kick and electric start. Valve adjustments/camchain adjustment are very simple to do. I use a Pamco electronic ignition, which is very reliable.
It might be hard to find one in good condition. |
01-10-2013, 10:56 PM
#24 |
Oddometer: 35
I'll second third and fourth the XS650. Throw in a 750cc kit for a bucketload of torque. The sky's the limit with mods on an XS.
An early Virago before they went all choppery might be a good bet. Yes, there are horror stories about the starter and carbs, but they are all solve-able, and you get a genuine simple and rugged motor in a standard-ish configuration. Very smooth running too, unlike the XS. You can always throw in a later motor if you want, and there are kits to mod them to a single carb setup like a Harley. Even a 500 Virago would be a significant step up from your 400 I think. Not a lot of choice with an aircooled motor and two carbs that's not a twin, but the 83-86 GS550's only had 2 carbs, albeit, dual-throated. Really though, I think you are worrying way to much about the carb thing. Balancing 4 carbs is easy and needs doing pretty infrequently. You might consider the big brother to the bike you already have, a KZ750 twin, but I think your 400 has a better motor, frankly. If it was me, I think I would try to find a low mileage Suzuki 650 Tempter in blue and silver. They are pretty simple and never seem to command much money, unlike the XS. Hell of a lot newer, more modern and, in my opinion, better looking then the KZ750. Ducati Monster, Cagiva Alazzurra, Cagiva Elephant, Honda TransAlp, Honda Hawk GT, Honda GB500, Yamaha SRX, Kawasaki W650...... MacMcMacmac screwed with this post 01-10-2013 at 11:16 PM |
01-11-2013, 03:35 AM
#25 |
WFO for 41 years
Oddometer: 4,015
Oh, yeah, right then. Norton Commando.
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
01-11-2013, 03:38 AM
#26 |
Bantam Fever
Oddometer: 304
You can look for a 2000 Triumph scrambler (lot's of parts, 2 carbs's, fun, ...)
![]() It has a lot of the same you have now just a bit more hp & reliable... Still i do like an old guzzy too! ![]() But these bike's are a bit more heavy than your easy to live with KZ400 |
01-11-2013, 03:46 AM
#27 | |
Forever N00b
Oddometer: 1,609
Mine came with a burnt stator which can be caused by low crankcase oil -- and stator replacement is an engine-out procedure. The ignition timing signal coils can also degrade and it's another engine-out procedure. The ignition module for pre-'82 bikes is unique and is unavailable. These built their reputation for reliability before the electronic components were 30 years old. I have, however, had no trouble finding gaskets and seals. Other bikes share ignition modules with several other models from the era so they're still available from the manufacturer or from aftermarket. My '75 CB750 seems durable enough and uses those simple points. . .
Motorcycles are magical. |
01-11-2013, 06:23 AM
#28 |
Oddometer: 6
XS650. I owned and commuted on one a few years ago and Mike's XS650 was a great source for cheap parts. I have been riding a Norton Commando since I had the XS and after some initial teething problems, it has been quite reliable, has excellent and relatively cheap parts availability, and a huge owner network.
Brendan
Brendan 68 Norton Commando 67 Triumph Daytona 71 BSA B50MX 01 Honda XR400 (plated). 04 Ducati Multistrada |
01-11-2013, 07:06 AM
#29 |
Interesting topic.. Since I'm also looking for my next bike and I kinda like the o.p.'s KZ400 and motorcycling ideas, I'll toss my ideas into this thread also.
I had a '75 Kawasaki KZ400D before I bought my current '89 Ninja 250 in 2006. I've got my eye on the Ninja 500, Suzuki GS500, and the '98+ Suzuki Katana 600 for my next bikes. I've also looked at a '81 Suzuki GS450 and a '81 CX500 but again like the KZ400, being that old parts availability might be an issue. However a BMW or a Triumph as posted above would be interesting also. Tony
1989 Kawasaki Ninja 250 - mostly stock with a scottoiler system, Oxford Heaterz heated grips, Works Performance rear shock, Traxxion Dynamics front forks, and a pair of Oxford Muffs for when its really cold. My Mileage Tracker Page. Ninja 250 Riders Club TonyKZ1 screwed with this post 01-11-2013 at 07:28 AM |
01-11-2013, 07:28 AM
#30 |
Oddometer: 4,660
Mid '80's Honda 700 Nighhawk S.
Good style, plenty of power, and the simplest maintenance of practically any bike. Everything hydraulic, including the valves, and a drive shaft.
'01 Kawasaki W650 '05 Yamaha XT225 |
