Old 01-10-2013, 02:08 AM   #1
Burra Boy OP
Oddometer: 54
Vapor mode button doesn't work
Hey out there
As the title suggests, my vapor speedo/ tacho has failed to proceed. I cannot change mode so can't reset trip, check odometer, etc etc.
Emailed Vapor who suggested I buy a new one coz mine is 3 years old...
I may end up doing that but I'm hopeful that someone has had a similar problem and found how to fix it. I'm a poor old pensioner, after all
I've sprayed it with cleaners, lubricants and high pressure air with no luck. I'm assuming there's a bad contact under the button but don't want to rip it apart without some guidance.
Anyone?
Cheers
Burra Boy is offline   Reply With Quote
Old 01-10-2013, 07:53 PM   #2
Burra Boy OP
Oddometer: 54
Anyone?????
Old 01-11-2013, 06:40 AM   #3
bracky72
Oddometer: 973
Dip the portion with the button in isopropyl alcohol. Work the button while submerged. Allow it to completely dry.
bracky72 is offline   Reply With Quote
Old 01-11-2013, 08:57 AM   #4
G19Tony
G19Tony's Avatar
Oddometer: 418
If you might have to get a new one anyway... The alcohol trick is worth a shot.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 01-12-2013, 03:30 PM   #5
Burra Boy OP
Oddometer: 54
Thanks guys. I'll give that a shot and see what happens. I'll let you know if it worked
Times are GMT -7.   It's 07:31 AM.
