Old 01-04-2013, 05:25 AM   #1
Michelangelo OP
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,761
How to hold damper rod when putting forks back together?
Just installed new seals in a set of right side up Bandit GSF1200 forks. Now I can't get the bolt in the bottom of the fork legs to lighten up, even when using an airgun. The dang damper rod inside the fork just wants to spin and spin. I tried stuff a small metal rod down in there with an old sock attached to the end (how I took it apart) to keep it from spinning but not having any luck.
Any ideas or a homemade tool I can use (correctly, lol)?
Dirt and offroad motorcycle tours...
ALL MOTO ADVENTURE,LLC.
www.AllMotoAdventure.com
Michelangelo is offline   Reply With Quote
Old 01-04-2013, 05:38 AM   #2
manic mechanic
manic mechanic's Avatar
Oddometer: 162
Put the spring back in with the top on, then use the impact gun.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador
RA WI Regional Rep
manic mechanic is offline   Reply With Quote
Old 01-04-2013, 09:22 AM   #3
Michelangelo OP
Oddometer: 1,761
So putting spring in, screw back on the cap onto the damper rod, then tighten?
Old 01-04-2013, 09:52 AM   #4
troidus
Oddometer: 16,260
See if the top of the damper rod is socketed. On '86-'06 Kawasaki Concours forks, a 5/8" (I'm pretty sure that's the size) nut fits in the top of the damper rods. Lock two nuts together on each end of a length of allthread, then hold the assembly with a wrench. You might be able to do something similar with yours.
troidus is online now   Reply With Quote
Old 01-04-2013, 10:10 AM   #5
fast4d
Oddometer: 2,476
on 'standard' (not USD) forks I have to use an impact to loose the bolt BEFORE I remove from the bike.
I can usually get the bolt tight enough to not leak before I do the final tightening with forks installed on the bike.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 01-04-2013, 01:12 PM   #6
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,300
on conventional forks, i reinstall spring, and cap. flip it over so i can impact the retaining bolt. compress the fork leg while doing so, for more pressure on the damper rod. i'm assuming the bottom of this damper rod is smooth and not notched to keep it in any position...
current bikes
stainlesscycle is online now   Reply With Quote
Old 01-04-2013, 01:51 PM   #7
Michelangelo OP
Oddometer: 1,761
Great ideas, thanks guys. Will let you know how it goes.
Old 01-07-2013, 08:21 PM   #8
Michelangelo OP
Oddometer: 1,761
No luck with either of these methods. I even put a 1 inch extra spacer preload spacer on top of the stock spacer to get more tension and put pressure on the fork after assembled (upside down) with the impact tool and still spins.
Old 01-07-2013, 08:25 PM   #9
troidus
Oddometer: 16,260
Did you look at the top of the damper rod to see if it will accept a nut?
Old 01-07-2013, 09:33 PM   #10
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
i've used square aluminum stock that just fit in the top holder for obstinate bolts on the damper.
i think i may have peened the sharp side edges a touch so it'd make a good fit.
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 01-08-2013, 01:24 AM   #11
PeterW
Oddometer: 2,792
I've used a broom handle, cut a cone in the top with a rasp and hammer it into place to lock the damper rod.
The catch is the obvious one, possible wood chips, but they come out if you wash it with kero.
Pete
PeterW is offline   Reply With Quote
Old 01-08-2013, 10:14 AM   #12
Tim McKittrick
Oddometer: 1,773
I would pull the damper rod and make very sure the threads are clean and the bolt easily spins all of the way into it before going any further. Also check that you are not missing any washers or whatnot that might affect the spacing of the fixing bolt- if it bottoms onto a shoulder before it is getting tight then something is wrong.
As stated by other posters the effort required to thread in the bolt and snug it down should be far less than the effort needed to spin the damper rod when it is being compressed by the spring.
Tim McKittrick is offline   Reply With Quote
Old 01-08-2013, 11:59 AM   #13
dmn0507
dmn0507's Avatar
Oddometer: 353
I've had luck with an old bicycle tube pushed down in the fork leg, after fre turns it started to grip and let me tighten the bolt
dmn0507 is offline   Reply With Quote
Old 01-08-2013, 12:27 PM   #14
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,199
May have already been said, but most of the old style damper rod forks have a 12 point (?) socket type top to them. The correct size nut, bought from a hardware store, will fit in this socket. All that needs to be done is to hillbilly engineer that nut so you can get a rachet wrench with a long extension on it, put down the fork tube from the top.
I've got the most recent one of these hillbilly devices at home and can post a pic if you want.
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 01-08-2013, 12:48 PM   #15
troidus
Oddometer: 16,260
As I mentioned earlier in this thread, mine is a length of allthread with two nuts jammed together on each end. One end fits in the top of the damper rod and the other end sticks out of the top of the fork to be grabbed by a wrench or socket.
Times are GMT -7.   It's 01:07 PM.
