01-11-2013, 10:22 AM
#1 |
Oddometer: 840
Dowel Pin Stuck
The picture is of the bottom of the upper half of the crankcase.
(bottom half of the picture) ![]() The dowel hooks onto the bearing on the driveshaft to prevent spinnage of the outer race of the bearing. The dowel is supposed to be sticking out but it is some how lodged and flush with the case with no where to grab onto. How to take out? |
01-11-2013, 10:49 AM
#2 |
Oddometer: 21,546
If the pin is tight enough to not spin, try running a tap in there to grab it.
01-11-2013, 10:56 AM
#3 | |
Oddometer: 303
If the stuck dowel is solid, drill a smaller diameter hole from the other side and use a suitably sized drift pin to drive the dowel out from above.
2004 KLR650 |
01-11-2013, 11:59 AM
#4 |
Oddometer: 840
The dowel is hollow all the way down. Where it sets in the crankcase, there is an oil passage drilled into the crankcase itself; i.e. there's no way to build up pressure.. So, using hydraulic pressure won't work.
Drilling a hole from the other side would mean drilling through the crankcase. |
01-11-2013, 12:01 PM
#5 |
Oddometer: 184
Snap and Mac make inside/outside pliers. A little heat and a pair of those pliers might just do the trick.
01-11-2013, 12:08 PM
#6 |
Not afraid
Oddometer: 11,221
drive a self tapping screw into it, and then use a slide hammer to pull the screw out, hopefully with the dowel pin on it.
"A little inaccuracy sometimes saves a ton of explanation." - H. H. Munro (Saki) (1870-1916) |
01-11-2013, 12:09 PM
#7 | |
Anatomically Correct
Oddometer: 2,491
Searching for the immaculate contraption |
#8 |
Oddometer: 840
01-11-2013, 12:14 PM
#9 |
Oddometer: 840
It is also not possible to send something inside to hook the dowel from the bottom and pull it out because the oil passage the dowel sits on has a diameter small than the inside diameter of the dowel.
I tired drilling (deWalt bits) the dowel from the top to maybe crack and break it and fish out the pieces but it seems to be made out of really hard steel. |
01-11-2013, 12:19 PM
#10 | |
Oddometer: 303
2004 KLR650 |
01-11-2013, 12:26 PM
#11 |
Oddometer: 840
Bike engine. The first pic might have been a bit confusing so here' another:
![]() The hole in which the dowel rests is machined into the crankcase. And that hole is flow through. |
01-11-2013, 12:37 PM
#12 |
Oddometer: 840
Also JB Weld doesn't seem to stick to it very well.
01-11-2013, 12:44 PM
#13 |
Oddometer: 21,546
01-11-2013, 12:48 PM
#14 |
Oddometer: 2,491
dowel pins ARE made of stern stuff . . . . . . .drilling will be messy . . . . try to get it to turn
01-11-2013, 12:53 PM
#15 |
Oddometer: 1,389
Easy out to grab and turn the dowel, while heating the aluminum case. The case will expand faster and greater than the steel dowel therefor freeing the dowel.
I'm not saying there should be capital punishment for stupidity, but let's take the safety labels off of everything and let the problem solve itself. Current bikes: '12 WR250R, '10 F800GS, '08 Versys, '07 WR250F, '85 RZ350, Wife's bikes: '10 F650GS, '09 XT250,'03 WR250F |
