Old 01-11-2013, 03:56 PM   #16
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,401
Duh
Just turn it upside down and let it fall out...duh
OK. my real vote is to follow CONCOURS' endorsement of Sieg's idea.
SilkMoneyLove is offline   Reply With Quote
Old 01-11-2013, 07:33 PM   #17
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Correct me if I am wrong, but doesn't it also bring oil under pressure to the bearings????
Have tools, will travel!
Old 01-11-2013, 08:29 PM   #18
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,934
Uh, that don't look right.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-11-2013, 09:25 PM   #19
Maoule
Maoule's Avatar
Oddometer: 608
That crankcase was prolly wore out anyway...the good news is you prolly don't need to fuck with that dowel any further
Maoule is online now   Reply With Quote
Old 01-11-2013, 10:03 PM   #20
Beezer
Oddometer: 5,946
very important. the case is bored on size with it's mating half... any other half is not in alignment... each case is unique by a few thou
Beezer is online now   Reply With Quote
Old 01-12-2013, 07:56 AM   #21
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
How about the bearing shells, could they be also mated to the case/crank? BMW does stuff like that.Someone somewhere found out how time consuming and expensive it can be sorting that out of 2-3 engines and boxes of parts.
So...if we ignore the case damages for now would just pulling that pin out and installing a new one suffice to keep the oil where it belongs?
How big is that hole and is there a lip on the bottom, as in the pin not pushed down far enough to contact the case? Then maybe rig some kind of hammer puller, a small one and carefully bang it out.
Depending on how tight that pin is, can't be very tight if it walked in there? How did that happen anyway? If you pushed it in by mistake, then you'd know how tight it is.
Maybe just roughening up the inside with the proper dremel bit and then installing a bolt/anchor in that hole could be enough to provide some pull.The proper bit probably wouldn't be in the accessories that usually come with them dremels.
Now that you have that engine all apart, did you ever find out why it was knocking? Starting to look expensive, is that high milleage bike worth all that expense of time and money?
Old 01-12-2013, 01:27 PM   #22
gsweave
Yinz, blinkers are on.
Oddometer: 12,499
Its a little late.
could of tapped threads, inserted corresponding bolt and used a slide hammer and heat.
maybe on the next one.
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-12-2013, 03:22 PM   #23
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
Is it just me or is anyone else saying why the fuck would you grind a journal away to get a dowel pin out when there are a half dozen solutions mentioned in this thread that would have worked?
First off get some real penetrant, tap it and insert bolt with slide hammer and yank out.
I'd be looking for a used engine at this point.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-12-2013, 06:44 PM   #24
Ratski
Ratski's Avatar
Oddometer: 764
I gotta say, all the reccomendations of tapping the dowel, while a good idea, will not work. Dowels like this one are hardened steel, they are too hard to be tapped. That is why the bolt extractors aren't working, they are softer than the dowel. Trust me, I know. Not long after starting in my current position at work, i was chasing a 1/4 pipe tap hole in a block of hardened steel, before any thread cutting occurred I broke the tap clean off and we had to EDM it out.
If you try to tap that dowel, all you will succeed in doing is having to deal with a stuck dowel with a broken tap in it.
You said that the outside diameter of the dowel is ~3.3mm right, that means the ID is about 1.5 or so? Any tap this small is REALLY easy to break!!
Ratski is online now   Reply With Quote
Old 01-12-2013, 07:26 PM   #25
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
He doesnt need to thread it, just get something in there with enough purchase to grab with a vise grip slide hammer. It's barely in there.
I would have welded it first, but thats me and I have a tig welder. I def would not have gone at it with a dremel and wrecked the journal
Nessmuk
Old 01-12-2013, 08:10 PM   #26
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Wow talk about ham-fisted.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 01-12-2013, 09:06 PM   #27
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,744
Wow this got expensive fast.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 01-12-2013, 10:12 PM   #28
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
Even I feel decidedly unsettled.
Yes I am quite serious.
Mike Ryder is online now   Reply With Quote
Old 01-13-2013, 11:37 AM   #29
docsherlock
docsherlock's Avatar
Oddometer: 484
Well and truly fucked now - at least you got a second hand set of cases.
Blob of weld and pull or spark erosion would have solved this problem - for next time.
Or try an ezee out or tap and if that broke it's just easier to blob the weld on.....
docsherlock is offline   Reply With Quote
Old 01-13-2013, 06:47 PM   #30
CaptTeach
Oddometer: 209
OOOOppppppssssss!!!!!
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Times are GMT -7.   It's 11:19 AM.
