Old 01-12-2013, 09:45 AM   #31
indr OP
Oddometer: 1,197
Originally Posted by H96669 View Post
How about the bearing shells, could they be also mated to the case/crank? BMW does stuff like that.Someone somewhere found out how time consuming and expensive it can be sorting that out of 2-3 engines and boxes of parts.
No bearing shells. One side of the shaft has bearing that takes the set pin/dowel. The other has a bearing that takes a set ring.
So...if we ignore the case damages for now would just pulling that pin out and installing a new one suffice to keep the oil where it belongs?
Yes.
How big is that hole and is there a lip on the bottom, as in the pin not pushed down far enough to contact the case? Then maybe rig some kind of hammer puller, a small one and carefully bang it out.
~ 3.3 mm without the pin. There is a lip at the bottom that prevents it from going all the way the way down. It is contacting the case at the bottom. I don't know HOW that happened because the pin on the other shaft doesn't do that. There is about 2 mm of it sticking out. IE. the lip is high enough to have the pin not go in as much as it has in my case.
Depending on how tight that pin is, can't be very tight if it walked in there? How did that happen anyway? If you pushed it in by mistake, then you'd know how tight it is.
Very tight. It'd be hard for me to take it out without cutting up more of the case.
Maybe just roughening up the inside with the proper dremel bit and then installing a bolt/anchor in that hole could be enough to provide some pull.The proper bit probably wouldn't be in the accessories that usually come with them dremels.
The steel is apparently very hard. Even the spiral extractors can't get a hold.
Now that you have that engine all apart, did you ever find out why it was knocking? Starting to look expensive, is that high milleage bike worth all that expense of time and money?
This is the bottom half of the crankcase.
During the valve change (about a year ago), the cam chain got hooked onto parts of this thing and broke off chunks.
A crankcase found fairly cheap on eBay is inbound.
indr is offline   Reply With Quote
Old 01-12-2013, 02:27 PM   #32
gsweave
Yinz, blinkers are on.
Oddometer: 11,435
Its a little late.
could of tapped threads, inserted corresponding bolt and used a slide hammer and heat.
maybe on the next one.
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-12-2013, 04:22 PM   #33
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,543
Is it just me or is anyone else saying why the fuck would you grind a journal away to get a dowel pin out when there are a half dozen solutions mentioned in this thread that would have worked?
First off get some real penetrant, tap it and insert bolt with slide hammer and yank out.
I'd be looking for a used engine at this point.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 01-12-2013, 07:44 PM   #34
Ratski
Ratski's Avatar
Oddometer: 747
I gotta say, all the reccomendations of tapping the dowel, while a good idea, will not work. Dowels like this one are hardened steel, they are too hard to be tapped. That is why the bolt extractors aren't working, they are softer than the dowel. Trust me, I know. Not long after starting in my current position at work, i was chasing a 1/4 pipe tap hole in a block of hardened steel, before any thread cutting occurred I broke the tap clean off and we had to EDM it out.
If you try to tap that dowel, all you will succeed in doing is having to deal with a stuck dowel with a broken tap in it.
You said that the outside diameter of the dowel is ~3.3mm right, that means the ID is about 1.5 or so? Any tap this small is REALLY easy to break!!
Ratski is offline   Reply With Quote
Old 01-12-2013, 08:26 PM   #35
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,543
He doesnt need to thread it, just get something in there with enough purchase to grab with a vise grip slide hammer. It's barely in there.
I would have welded it first, but thats me and I have a tig welder. I def would not have gone at it with a dremel and wrecked the journal
Nessmuk
Old 01-12-2013, 09:10 PM   #36
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Wow talk about ham-fisted.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 01-12-2013, 10:06 PM   #37
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,551
Wow this got expensive fast.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 01-12-2013, 11:12 PM   #38
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 948
Even I feel decidedly unsettled.
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 01-13-2013, 12:37 PM   #39
docsherlock
docsherlock's Avatar
Oddometer: 462
Well and truly fucked now - at least you got a second hand set of cases.
Blob of weld and pull or spark erosion would have solved this problem - for next time.
Or try an ezee out or tap and if that broke it's just easier to blob the weld on.....
docsherlock is offline   Reply With Quote
Old 01-13-2013, 07:47 PM   #40
CaptTeach
Oddometer: 209
OOOOppppppssssss!!!!!
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-14-2013, 12:42 PM   #41
ohgood
ohgood's Avatar
Oddometer: 2,629
Originally Posted by indr View Post
Here's my hasty fuck up with a Dremel.
The extractors are turning out to be too soft themselves to get a hold of the thing. Even with the sides heated up.
Tons of WD-40 was sprayed to seep into the sides to get it to even slide but it's not working.
I'll try again tomorrow.
Assuming that dowel is staying in there, I'm thinking:
1. Grind down whatever little bit it protruding.
2. Make a similar sized hole to the left of the saddle and put the dowel in there.
Something I want to re-itterate. All the dowel is doing is holding the outer race of the shaft bearing in place so the OUTER RACE doesn't spin. I don't know what the pressure is like when the crank case is rejoined, what if I used some gasket material on the saddle just before installing the shaft. Clamped down with the case shut, would that be enough to provide a force to hold the outer bearing from moving?
3mm or so hole in the dowel you say ?
i've made extractors (smalllll bearing pullers) that work great for small things:
imagine 1/2 of a nail, slip it down the hole, and move one way so the nail head catches the back edge of the dowel/bearing/whatever.
then another 1/2 nail, also slipped down in, allowed to catch on the opposite side of the back edge of the dowel/bearing/whatever.
drive a small (piano wire sometimes, yikes this is small!) down between them. this not only forces a LOT of pressure on the 'nail' heads, but also keep them from slipping and turning while you...
glue the assembly to a regular puller bolt. weld works too, but for tiny stuff weld can kill the elasticity of the metals. then, with plastic pads against the machined surfaces that matter, put a regular puller against the face of the case and begin turning (pulling) the screw. a little head, a little penetrating oil, and even 20 year old dowels will come free. patience is a virture.
i hope someone aritistly inclined can draw a picture, cause my explainations suck.
oh, just saw your picture. good lord, find a machinist, quick, and put down the tools ! (not an insult, a helpful suggestion) :)
scrolling through the words to get to the pictures is cool, but i'm really just here for the tracks and waypoints... post some ok ?
ohgood is offline   Reply With Quote
Old 01-14-2013, 06:47 PM   #42
troidus
Oddometer: 13,659
Too late for that. I dont' see any way to unFUBAR that bearing support.
troidus is online now   Reply With Quote
Old 01-15-2013, 02:57 AM   #43
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,636
Find a good welding shop, add the lost material back with filler and re-machine to spec.
This, of course, will cost more than a full case in good condition.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 01-15-2013, 10:57 AM   #44
ohgood
ohgood's Avatar
Oddometer: 2,629
i'm not so sure that piece is toast, looking again. that's barely half of five degrees of material. so long as the rest of it is round, it should wear just fine for a long time. is that portion directly in line with the stroke of the piston ? if not, it wouldn't bother me to run it as is.
you could even fill it and file it however you liked, to prevent stuff from getting in the gap and swarfing up the crankshaft.
Times are GMT -7.   It's 11:58 PM.
