Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 01-20-2013, 05:23 AM   #31
wilfred
juvenile delinquent
wilfred's Avatar
Oddometer: 919
Originally Posted by natedog39 View Post
Got to some serious work on the new rig last night.
My man Steve and I got the rear end dropped down and this morning I finished getting it out from under the frame.
Man,,,everything about this thing is much bigger than the Ghetto Bus and a size bigger than the school buses I'm used to working on.
The rear end is moving exactly 67 inches forward, which is the length of the driveshaft section being removed.
This will also allow the slip joint and it's carrier bearing to bolt up to the existing crossmember one position forward.
I found and cleaned off the axle tag to figure out the ratio, 3.90.
Highways here I come.
3:90 is pretty low. 3:55 would give you lower engine speed . What is the overdrive % of the transmission?
“The pessimist complains about the wind; the optimist expects the wind to change; the realist adjusts the sails.”
semper-fi
wilfred is offline   Reply With Quote
Old 01-20-2013, 05:27 AM   #32
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 01-20-2013, 09:45 AM   #33
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,562
Shit!
Now your gonna make me go crawl under that thing and find the ID tag.
2014 FE 501
2012 990Adv
Team Ghetto does a hot lap of America
natedog39 is offline   Reply With Quote
Old 01-21-2013, 05:00 AM   #34
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,562
Well, I went and looked and the tag is missing.
As a comparison our school buses have a top speed of about 65mph.
They have comparibly sized tires and no overdrive, rear axle ratio of 5.56.
This thing should fly with this gearing even if it dosen't have overdrive.
2014 FE 501
2012 990Adv
Old 01-21-2013, 05:36 AM   #35
wilfred
juvenile delinquent
wilfred's Avatar
Oddometer: 919
Just making an observation, it probably has a .74 od or .85 I followed your other build, you have skills.
semper-fi
Old 01-21-2013, 06:06 AM   #36
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,562
I just found a manual, it looks like most of the Super 10's have either .74 or .76 OD in 10th. 9th being direct.
2014 FE 501
2012 990Adv
Old 01-21-2013, 06:12 AM   #37
wilfred
juvenile delinquent
wilfred's Avatar
Oddometer: 919
Cool
semper-fi
Old 01-27-2013, 09:09 AM   #38
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,488
Thankfully the P/O removed the box before I got it , saving me quite a bit of work.
Last spring, I had to remove a 16 ft box at home and then drop the chassis at the upfitters. Anyhow, what the upfitter said was the easiest was hire a rollback.
Process:
1) The box was only secured to the chassis via 4 u-bolts, so cut those
2) The rollback will back up to the rear of your chassis (tail to tail)
3) Winch the box onto the roll-back
4) We moved the box to another part of the property and set it back down on railroad ties for use as a storage shed.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 01-27-2013, 02:30 PM   #39
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Which mean's,,,,,,,,,,,,,,,I have to chip in less gas money!!
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 03-24-2013, 05:41 PM   #40
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,562
The big truck is mobile once again.
Everything worked out as planned, the driveline bolted right back up like it was made this wheelbase.
New used brake chambers installed, pinion seal,new air hoses.
I still have to figure exactly where I'll cut the framerails but I plan to have about 4 feet of overhang from the centerline of the axle.
I may dovetail the end of the bed so I'll leave a little extra.
2014 FE 501
2012 990Adv
Old 03-24-2013, 05:55 PM   #41
pvangel
Team AARP
Oddometer: 2,610
Nice!!!!
pvangel is offline   Reply With Quote
Old 03-25-2013, 09:43 AM   #42
c.herman126
c.herman126's Avatar
Oddometer: 529
Nice work Nate! Gotta love it when a plan comes together!
"Dream as if you'll live forever. Live as if you'll die today" James Dean
1993 XR650L
2008 530 EXC-R
c.herman126 is offline   Reply With Quote
Old 03-25-2013, 04:35 PM   #43
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,192
$5000? Holy crap. You got connections?
Carlo Muro is offline   Reply With Quote
Old 03-25-2013, 04:54 PM   #44
natedog39 OP
Borderline Beefcake
natedog39's Avatar
Oddometer: 6,562
It was just luck.
When I first saw it with the box on the P/O wanted $8,000 but I had just purchased the 8.3 for the bus so I was committed to that.
When I realized things weren't going to work as planned with the bus I remembered the truck but it wasn't listed anymore.
I thought I was screwed but then remembered taking pictures and was lucky enough to make out the phone # and the guy still had it after 8 months of trying to get rid of it.
He had sold the box and only wanted 5K, the rest is history.
2014 FE 501
2012 990Adv
Old 03-25-2013, 05:30 PM   #45
klp
Oddometer: 259
Did you sell the old rig?
Lots of old Hondas, 2 Yamahas, 2 Kawi's.
klp is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:54 PM.
