Old 01-12-2013, 09:04 AM   #1
ShadySmurf OP
Does Own Stunts
ShadySmurf's Avatar
Oddometer: 540
Oil Leak Help
Anyone have a leak from here before? If do what did you do? About to get in the fische to figure out what it is, guessing the neutral indicator switch. Thanks fellas.
ShadySmurf is offline   Reply With Quote
Old 01-12-2013, 09:29 AM   #2
ShadySmurf OP
Does Own Stunts
ShadySmurf's Avatar
Oddometer: 540
Answered my own questions, gear position sensor, has a 39 cent o-ring behind it. Aft bolt was a bit loose as well so hopefully that will fix it in itself. Carry on.
Old 01-12-2013, 09:49 AM   #3
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,411
I've seen that problem before on here. Easy fix.
Bgunn is offline   Reply With Quote
Old 01-12-2013, 09:55 AM   #4
Deepc
Oddometer: 299
This just happened to me. One of my bolts was stripped out. I taped the holes and put in slightly longer bolts.
Deepc is offline   Reply With Quote
Old 01-12-2013, 01:35 PM   #5
DADODIRT
DADODIRT's Avatar
Oddometer: 3,457
Don't over tighten those small bolts. Like 6nm.
I find your lack of faith in the force disturbing.
DADODIRT is offline   Reply With Quote
Old 01-13-2013, 07:59 PM   #6
Black Hills
Oddometer: 1,183
Had the same problem. Overfilled oil level seems to be the culprit.
Black Hills is offline   Reply With Quote
Old 01-18-2013, 08:57 AM   #7
booger1
booger1's Avatar
Oddometer: 845
Just discovered mine leaking as well. Can I pull it out with out having to drain the oil first?
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is online now   Reply With Quote
Old 01-18-2013, 09:04 AM   #8
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,789
Another idea, replace those bolts with studs, less likely hood of stripping if they are not going in and out too often.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 01-18-2013, 10:26 AM   #9
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,630
Just lay the bike on the side. No problem, other than pickin' it back up.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 01-18-2013, 12:26 PM   #10
booger1
booger1's Avatar
Oddometer: 845
Went ahead and pulled it out while on center stand, leaked some oil but not bad. Soaked o-ring in some ATF for about 20 min. and reinstalled verifing no nicks in the o-ring. Been sitting for about 2 hours and see no more oil leaking, the real test will be getting it up to operating temp and riding it. Somtime this weekend I'll do that, but so far so good.
Old 01-19-2013, 03:27 AM   #11
Peanuts
Peanuts's Avatar
Oddometer: 1,598
Its a dry sump setup. Oil tank level has no bearing on the oil level in the engine.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
