Old 01-14-2013, 01:03 PM   #16
up2nogood
Oddometer: 66
Was thinking about the thermostat. Good idea.
Where'd you get the lower temp one from?
Help out the people from the countries we love to ride through:
http://www.kiva.org/invitedto/advent...er/by/alex9291
up2nogood is offline   Reply With Quote
Old 01-14-2013, 01:21 PM   #17
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,256
http://www.advmachines.com/category_s/93.htm
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 01-15-2013, 10:02 AM   #18
AB13
Oddometer: 1,048
Bdcw kit + switch
I installed the BDCW kit with a switch so that in cooler temps I don't have the load of the second fan and can use my heated gear without taxing the charging system.
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 01-15-2013, 01:23 PM   #19
SauceSquatch
SauceSquatch's Avatar
Oddometer: 273
You can also set the temp you want your fan to kick on in TuneECU.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Old 01-15-2013, 04:17 PM   #20
BillyD
BillyD's Avatar
Oddometer: 635
Regardless of which fan switch temperature set-point you chose, high or low, the overall capacity of the cooling system doesn't change.
Said another way, if your engine is getting hot enough to blow coolant with the stock higher set-point switch, then using a lower temperature set-point switch will not, in and by itself, keep you from blowing coolant.
A higher pressure radiator cap would raise the temperature at which you start blowing coolant, but radiator surface area and air flow are still the primary determinants of how many BTUs/second can be removed from the motor. Wetting agents might improve heat transfer efficiency to yield a marginal increase in cooling capacity.
Adding a second fan significantly increases air flow at low bike speeds and, therefore, the effective cooling capacity of the system is also significantly increased when the bike is moving slowly, but switching both fans on at a lower temperature does not increase the maximum rate at which BTUs can be extracted from the engine. Similarly, using a lower temperature thermostat does nothing to increase cooling capacity and your engine oil will take longer to get up to operating temperature. Removing the thermostat altogether might increase coolant flow, which might increase cooling capacity, but then your engine oil would take even longer to come up to temperature.
With all that said, rather than controlling both fans from a single switch, it would make more sense to control one fan with a low temperature set-point switch and the other with a higher temperature switch. Sequencing the fans this way would save electrical power and only run the second fan when needed.
BTW, I'm using the AdvMachines fan kit and had no issues in Fish Canyon/49'er Escape near Ballarat/Death Valley at 100 F plus heat. 1st and 2nd gear in sections.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD screwed with this post 01-15-2013 at 04:29 PM
BillyD is offline   Reply With Quote
Old 01-15-2013, 05:17 PM   #21
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
This is unfortunately a incorrect statement. The 990 does not leverage a ECU's capability to turn the cooling fan on/off, this is only performed by the thermo switch that threads into the right radiator tank.
EDIT: Also, to my knowledge, there is not a lower temperature thermostat, the device that regulates the engine coolant temperature. The Thermo switch is the device that tells the fans to turn on/off dependent upon a set temp range. OEM temp is ~220F on. My experience with the lower temp thermo switch (~200F on) is as follows, and I almost completely agree with BillyD's statements, with deviation on that with the fans coming on sooner there is a greater potential for a period of "rest", so MAY allow for the system to catch up sooner. Granted, we are not increasing the capacity of the heat exchanger, we are increasing the exchange of heat by forcing the flow of air through the exchanger (radiator), still there are limits and in some cases the limits will still be met when the engine is producing more heat than can be rejected to the ambient air.
EDIT2: What I typically experience with the addition of the 4" fan on the right side of the radiator (my experience is with the ADVmachines fan so I cannot speak to the BDCW fan) is a reduction in fan cycle time by about 40-50%. This is unloaded and with the engine idling on the lift. The cycle time between on and off is reduced again by about another 30% when adding the lower temp thermo switch, this switch turns both fans on at the same time. During normal riding the fans will cycle more frequently and will tend to come on sooner (with 200F switch), but again will turn off sooner as well. The engine temperature is still regulated by the thermostat and most reports that I have heard back from other people who use this system say that typically the gauge rarely exceeds 4 bars (950), and almost never goes past 5 bars unless in extreme conditions and loads. Even at 6 bars of engine temperatures the cooling system should still be "stable" and not puking coolant uncontrollably.
Personally I run the ADVmachines rally fan.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind screwed with this post 01-15-2013 at 05:35 PM
Head2Wind is offline   Reply With Quote
Old 01-15-2013, 08:57 PM   #22
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 769
Wetting agents, their primary benefit is that they help keep the water in contact with all the surface in
the cylinder and head assembly, I've seen testing done and it reduces head and cylinder hotspots.
Even if your heating the overall engine up this reduces the chances of a area fatiguing and giving up on you.
Like between the spark plug and valve guides...
I'm still interested in trying waterless coolant in my 950. I like the idea of zero pressure in the cooling system..
Cheers.
Dave
pdxmotorhead is offline   Reply With Quote
Old 01-15-2013, 09:29 PM   #23
Maoule
Maoule's Avatar
Oddometer: 490
WTF? I think I'd like to know more, please expand.
Maoule is online now   Reply With Quote
Old 01-15-2013, 10:13 PM   #24
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,988
Originally Posted by mikeegee View Post
I found replacing the stock temp switch didn't allow the radiator and thermostat to do their jobs, and the fans actually ran longer than when I switch back to stock.
Love the 2 fans though.
My fan bearings are a bit gritty since I ran the lower temp switch. In off-road the fans were always on and when I was behind other riders their dust gritted up the fan bearings over a season of riding.
I put the stock temp switch back in, made sure the system was burped properly (which is a royal pain) and I never had overheating issues since then. The only time I came close was a 10 minute mountain climb in first gear and high revs the whole way up.
I have the ADVMachines bracket and I like it, but had to add a fan shroud to the right side fan to keep the gas in the right tank from boiling/pressurizing.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 01-16-2013, 12:31 PM   #25
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
BillyD the lower temp (200f) fan switch works by beginning to shed heat sooner than the 220f switch.
In heat exchangers the temperature difference (delta) of the source (our radiator in this case) & the sink (atmospheric air) does indeed change the time required to shed heat to come down to (whatever) target temperature. By not allowing the coolant to reach that higher temp you're already 20 degrees closer to your target temp.
Wattman did extensive testing on cooling systems & found that having a fan on at 60+mph lowered the coolant temp 11f- albeit on a "lowly" KLR. Seems our bikes would fare better as the back area of the radiator is quite cramped
I've turned fans on before I rode into deep sand to pre-cool, which will allow you a few more minutes of run time before the bike heats up- sometimes it's all you need in a tight section before you can make some speed to bleed heat off. I'm talking about the +90f/80% humidity of America's South, don't know how it would work in the dry Southwest
Are you referring to Evans Coolant? That stuff is strange. Some dirtbike racers swear by it, others have destroyed their top ends because it doesn't "boil off" and give the rider a visual clue to overheating. It's expensive (+$40/gallon) & your system must be flushed with Evans Coolant & discarded to remove all old fluid which would be pricey on our bikes. If you are on a trip you can't add anything other than Evans to your radiator/coolant tank should you develop a leak. It's also VERY slippery and can create water pump & head gasket leaks- and our LC8's already have a tough time keeping their coolant behind the water pump seal. It stinks & is difficult to wash off your hands & clothing...YMMV Not sure about "zero pressure"- if you heat a closed system you are going to increase its pressure- one of those pesky ThermoDynamic Laws
Stick to a wetting agent with standard coolant- I used Redline concentrate
someone ask for the part number for the 2nd fan shroud... here's the link
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician screwed with this post 01-16-2013 at 12:42 PM Reason: added 2nd shroud link
geometrician is offline   Reply With Quote
Old 01-16-2013, 01:27 PM   #26
el queso
toda su base
el queso's Avatar
Oddometer: 693
One minor note. You can add water to Evans Coolant in an emergency, but if you exceed 5% they recommend you refill with Evans ASAP. That said, I considered it for my dirtbike, but decided to stick with a water based coolant.
el queso is offline   Reply With Quote
Old 01-16-2013, 02:55 PM   #27
BillyD
BillyD's Avatar
Oddometer: 635
Agreed. Pre-cooling (by switching on the fan) might help make it through a transitory situation without boiling over.
My comments assumed a more steady state situation, such as when I'm usually stuck in those tight technical sections for extended periods of time...alone...dying of thirst...crying for mama.
Here's a somewhat relevant graph. Switching on a fan increases air flow (MPH) and resulting in increased rate of heat rejection.
Per geometrician's comment, increasing the differential between air and coolant temperatures, would also increase available cooling, albeit temporarily in his example.
Alternately, if you were to substitute inlet-outlet temperature differentials (delta degrees C) for coolant flow (GPM) and air flow (MPH) rates on the graph, the graph would look largely the same. In other words, the higher the coolant temperature drop through the radiator or air temperature increase across the radiator, the better heat transfer performance at any given flow rate.
Bill
BillyD screwed with this post 01-16-2013 at 03:46 PM
Old 01-16-2013, 04:19 PM   #28
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
Been using Evans in the 565 for years without issue. Granted, it could be overheating and I wouldn't know it. Ya got me there.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-18-2013, 05:05 PM   #29
R&R4adv
R&R4adv's Avatar
Oddometer: 338
On my old 640 i had a switch to turn the fan on whenever i wanted so if getting stuck in traffic or in the tight stuff i'd just switch it on to keep temps down before it got to come on by its self, has anyone done this to a 950/990
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv is online now   Reply With Quote
Old 01-18-2013, 06:33 PM   #30
zeropoint
Oddometer: 146
I put the BDCW second fan and Rally Raid thermostatic fan switch on for a long trip to Italy last summer. Turns out it was their hottest for about 10 years and stayed in the high 30s, low 40s for most of the time. Phew. I reverted to the stock fan switch half way through as the fans were coming on too much of the time for my liking. The OEM fan has a shield that helps divert the blown hot air away from you. The second fan does not and blew the air straight at my leg.....
Billy D can vouch for the heat. We bumped into each other a couple of times in the same afternoon in Tuscany after a good lunch at Volpaia. Hey Billy how goes ?
Tim
2011 990 Adventure
zeropoint is offline   Reply With Quote
Times are GMT -7.   It's 05:04 PM.
