Old 01-18-2013, 02:28 PM   #31
sleazy rider
Squidly Adventurer
sleazy rider's Avatar
Oddometer: 1,976
Wow, I brought mine home in the back of my Ford Focus ZX-4. Removed it myself too. Pulled the crate out as far as I could, set that end on the ground and wrestled the other end to the side and set it down. It's not that hard if you don't fear a hernia. . For the record, I'm 5'8" and 170# soaking wet with a couple rocks in my pocket.
--Tom
sleazy rider is online now   Reply With Quote
Old 01-18-2013, 06:41 PM   #32
leewildwater
rrrrRide Man rrrrRide
leewildwater's Avatar
Location: out riding my two legged horse near Bryson City NC
Oddometer: 393
Originally Posted by JimVonBaden View Post
HF has some. They are cheap, but good!
http://www.harborfreight.com/movers-dolly-93888.html
Jim
Exactly what I did. I used the one the window AC unit sits on in the winter plus one I keep a couple storage bins on. Put heavy en toward back of truck at store, slid onto dollies, rolled lighter end to tail gate the lowered down to floor.
RRRRRide man RRRRRide
leewildwater is offline   Reply With Quote
Old 01-18-2013, 07:04 PM   #33
Stkmkt1
Stkmkt1's Avatar
Oddometer: 257
Congrats on your purchase of the HF lift. I've had mine for 3 years now. Works like a champ. I did like a few others did. Forklifted it into the Avalanche at the store. When I got home, I just opened it up and tooks parts out one at a time. Eventually, it got down to man-handling the last big parts by hand. Not really a big deal.
I actually roll mine out of my shop into the driveway all the time when I'm working in my shop. Shop is a full woodshop that also is where I park my four motorcycles. Each time I roll it out or bring it back in I have to pick one end up and drag it back into the garage as the garage floor is higher than the driveway.
The thing is a beast. I also bought for around $40 on sale at HF, a wheel chock. Bolted it to the front of the lift. I just roll the bikes up on the lift and into the wheel chock. Then strap them in place. Works great.
2013 BMW 700GS, 2009 BMW 1200GS Adventure,
2009 Vstar 950, 2009 Honda Rebel,
2000 Goldwing SE, 1977 CB750A,
Needs: new garage (in planning) Need more room for more bikes.
Stkmkt1 is offline   Reply With Quote
Old 01-18-2013, 07:28 PM   #34
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,507
Another great use for the ligt:
I use it for a lot of different things, including a tire changer!
Jim
Old 01-19-2013, 09:40 PM   #35
Wirewiz
Wirewiz's Avatar
Oddometer: 27
Put your BIG BOY Pants on.....
Couldn't resist Back your delivery vehicle up to where you want it and slide one end out until it almost wants to tip out. Then slowly let one end down, then pick up the other and with your Legs slowly set it on top of a 2x4 on the floor. 2x4 will save your fingers. I do this stuff all the time in my shop by myself. It's a "can of corn". Guess I work by myself way too much. I'm in Oly if your close let me know I'll help. I have a pick me truck too.
Good luck. Wiz
Wirewiz is offline   Reply With Quote
Old 01-20-2013, 01:38 AM   #36
everycredit
everycredit's Avatar
Oddometer: 272
If you have a truck, lower the tailgate and back into your garage.
Have a second person help you make sure no one is in front of your path or going to enter your path soon.
Put the truck in first gear, rev engine to 2200 rpm, drop clutch, and punch the accelerator.
HF table in garage. If you're lucky, it may become unpacked for you.
everycredit is offline   Reply With Quote
Old 01-20-2013, 02:12 AM   #37
_cy_
Oddometer: 6,437
get a cherry picker ... get a good one that folds up, out of the way in between uses.
primary objective is not to hurt yourself, secondary is to get it unloaded.
Old 01-21-2013, 05:27 AM   #38
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,924
Ever watch the cop car scene in American Graffiti??? It could be a "hold my beer, and watch this" moment.
In all seriousness, when you need a cushion to drop something off a truck, car tires work great. Many moons ago I worked at a dealership and we got our oil in 55 gallon drums, all we did was stack 3 tires on top of one another, and roll the drum out of the truck and on to the tires. Worked like a charm.
PFFOG is offline   Reply With Quote
Old 01-24-2013, 09:49 AM   #39
Brisco
Chik'n Eater
Brisco's Avatar
Oddometer: 74
Eh?
Jeez!!!
I'm not sure why everyone is making this a bigger production than it needs to be...
HF loaded mine in the back of my son's S-10, heavy end to the back.
I got home, backed it into the garage, my 17 year old and I slid it back until one end rested on the floor, each of us got on either side and slid it out the rest of the way and set it on the floor.
I uncrated it, put the caster on by myself.
Brisco is offline   Reply With Quote
Old 01-27-2013, 06:29 PM   #40
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 97
I guess I was overthinking this. Rented a 5x9 trailer instead of a truck - lower deck, and no mileage charge too (and no extra gas). Backed it up right to the garage door - by far the most tricky part of the ordeal , uncrated the lift and just dragged it off. The bottom part of the crate served as a slide, sort of.
Thank you everybody for replies and suggestions!
MaestroPNW is offline   Reply With Quote
Old 02-03-2013, 08:31 PM   #41
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 97
Put it together today.
Managed to break (not strip, break) one of the bolts holding the caster to the frame with a 4 inch wrench... Went like butter.
Not very confidence inspiring
Now have to shorten the HF chock (this one http://www.harborfreight.com/motorcy...ock-97841.html) and mount. Without shortening, it looks like it's going to interfere with working clearance around the front of the skid plate.
Times are GMT -7.   It's 12:49 AM.
