Old 01-18-2013, 02:50 PM   #1
Two Moto Kiwis OP
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,958
Scotts Damper Magic Settings For 950 SE?
Good afternoon Ocers
Have been searching for info, seems to be a lot of too and fro but no definitive setting(s) or recommended setting(s).
Was there any general consensus amongst the SE crowd about good general settings or set up?
I have been tinkering with it but not having had a Scotts before I am in new territory.
Cheers all.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 01-18-2013, 06:32 PM   #2
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,988
11 clicks in from full soft
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-18-2013, 06:54 PM   #3
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,744
+1... then adjust a click or two in either direction to personal taste.
traveltoad is offline   Reply With Quote
Old 01-18-2013, 08:59 PM   #4
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,958
Ok will set that as a start point, the sweep control is at 6 oclock allowing full swing damping, also any recommended start point for the high speed given they cross over.
We are only RTWing on road, gravel road and some small amount of softer stuff we found on Baja today ... hence my questions.
Thanks all.
Old 01-19-2013, 08:50 AM   #5
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,663
On my ADV, I increased the main/right knob until the shake/swim on gravel stopped.
One of the best upgrades that I have installed.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is online now   Reply With Quote
Old 01-19-2013, 09:33 AM   #6
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Laugh Each Magician Creates His Own Magic
The settings vary from rider to rider, and road to road, and even temperature as the oil thickens in the cold
I have my sweep screws set (3 o'clock?) so the damper isn't restricting turning at full-lock so slow, tight maneuvering isn't damped. This is how they are shipped
Scotts has about 3 full turns on the main(right) adjuster, I find that 2 turns out is a good starting point for pavement. By pulling the black plastic pointer off the knob you can reposition it so it is easy to adjust on the fly. Once I hit the gravel I turn it out about 1/2 turn to increase damping, and in gnarly stuff (esp at speed as in Baja) I turn the knob out more, occasionally to full damping. When you get back onto terra firma turn it back down to your base setting.
On the 950 Adv I run it sub-mounted on the BRP/Scotts upper triple clamp, and have the pointer set so it starts at about 2 o'clock (where it runs into the handlebar clamp) and the "sweet spot" for gravel at about 6 o'clock, and the full damping at 10/11 o'clock. The KLR doesn't require as much damping (I have 2 Scotts dampers) as the Adv.
Contrary to myth deceleration head-shake isn't totally fixed, and tire pressures/suspension setup (or, rather, lack thereof) will continue to introduce it. The damper keeps the oscillating energy from quickly turning into a tank-slapper as an undamped bike would.
Have fun & eat a ton of tacos pescados for me, all washed down by Clara Pacifico- I miss Baja!!! (6 times the full length of the peninsula for me)
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 01-19-2013, 02:02 PM   #7
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,958
Thanks guys, I have been slowly tuning it in for our use, understand differing factors have huge results just wanted to start somewhere valid ...no point in reinventing there wheel eh.
Times are GMT -7.   It's 09:40 PM.
