Go Back   ADVrider > Riding > Mapping & Navigation
Old 01-13-2013, 09:37 AM   #1
RibRoy OP
RibRoy
Oddometer: 70
Garmin BaseCamp
Hi,
Just bought a Zumo660 and using Garmin BaceCamp on my PC for planning routes.
BaseCamp show the map in a wrong heigth/width ratio. I find this very disturbing. I tried to contact Garmin suppurt, but no answer. Anybody that know of a fix? Thanks
RibRoy is offline   Reply With Quote
Old 01-13-2013, 09:45 AM   #2
bkg123
Oddometer: 293
Im guessing your looking at it in the 3D view, as in your viewing it from an angle. On my Mac if you click in the center of the compass at the bottom it goes to top down view. In the View menu you can switch from 2D to 3D
bkg123 is offline   Reply With Quote
Old 01-13-2013, 09:48 AM   #3
RibRoy OP
RibRoy
Oddometer: 70
Originally Posted by bkg123 View Post
Im guessing your looking at it in the 3D view, as in your viewing it from an angle. On my Mac if you click in the center of the compass at the bottom it goes to top down view. Mine always opens in this view.
Hi, I'm aware of the difference in 2 and 3D, But its still wrong (although better) also i 2D
Old 01-14-2013, 03:07 AM   #4
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,496
could you give a little more I go on what this means?
dunno.....
Old 01-14-2013, 03:55 AM   #5
dlh62c
Oddometer: 1,603
A computer screen shot would help.
In BC under the 'View' tab you can swap the map and data views. Did you try that?
daryl
Old 01-14-2013, 06:51 AM   #6
RibRoy OP
RibRoy
Oddometer: 70
Hi, This is a pic of my community on googlemaps and from BaseCamp. As you see, there is a big difference between them.
I also tried to swap map/data
RibRoy screwed with this post 01-14-2013 at 06:58 AM
Old 01-14-2013, 07:34 AM   #7
ramz
Professional Trail Rider
Oddometer: 2,038
Try googling "garmin maps wrong aspect ratio".
First link:
http://gpsinformation.org/forum/view...hp?f=13&t=7707
ramz is offline   Reply With Quote
Old 01-14-2013, 07:36 AM   #8
byways
byways
byways's Avatar
Oddometer: 2,283
Can you elaborate on the "difference" that is troubling? Does Basecamp not depict roads, placenames, landmarks, etc. correctly? Squinting at the images, I see some landforms depicted somewhat differently, but it appears all the necessary information is there.
byways is offline   Reply With Quote
Old 01-14-2013, 07:53 AM   #9
250senuf
250senuf's Avatar
Oddometer: 2,448
Which one is right compared to a paper topo map? Google Maps probably has a preferred screen resolution, how does your screen fit with that?
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 01-14-2013, 08:11 AM   #10
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 671
People have been bitching about this on the Garmin forums since day one. It's also evident in the newest versions of MapSource. The further North the area, the more distorted the map view. Garmin is very aware of it and has chosen to ignore it. IIRC, it has something to do with the way BaseCamp and the last two or three versions of MapSource render the maps.
This post in the "Windows_BaseCamp" forum may help. Linky. There's some good information in the thread referenced earlier on in the thread as well.
SW
The Weather in my Backyard
Steve W screwed with this post 01-14-2013 at 08:20 AM
Steve W is offline   Reply With Quote
Old 01-16-2013, 09:01 AM   #11
RibRoy OP
RibRoy
Oddometer: 70
Hi, Its no problem when you make routes i areas with a lot of roads, villages etc. The problem is in remote areas when you are zoomed in, and you need to compare shapes of rivers, lakes etc from a correct map.
Seems I'm not the only one bothered by this, so I hope Garmin will make a fix.
Times are GMT -7.   It's 12:24 AM.
