Old 01-13-2013, 02:20 PM   #1
wowsers OP
F8 & b there
wowsers's Avatar
Oddometer: 29
KLR650 Triple tree bearing
I own a 2008 KLR650 and the lower triple tree bearing was toast so I ordered a set from ALLBALLS racing. I noticed that the bottom seal does not fit flush against the bottom of the triple tree like the oem seal did, I installed the bearing and seal today anyway and there is a 1/8 of an inch gap between the bottom of the seal to the triple tree. Is this normal or did I get a bad seal?
Any of you guys experienced this situation with these aftermarket seals?
F8 & b there!
You know what it means don't you?
wowsers is offline   Reply With Quote
Old 01-13-2013, 05:31 PM   #2
redneckdan
Hold my beer & watch this
Oddometer: 527
Had the same problem with my wife's klr 250. I ordered a set of factory seals. When you get that far, you'll notice the top seal in the all balls kit ain't even friggin close to working properly. I was not impressed.
Fly Rods, Kids and a KLR
redneckdan is offline   Reply With Quote
Old 01-16-2013, 04:26 PM   #3
wowsers OP
F8 & b there
wowsers's Avatar
Oddometer: 29
After sending a photo of the bearing and seal assembly to ALLBALLS racing, they said that this was the way that their seal was intended to be installed so I went ahead and put all that together and everything is fine.
F8 & b there!
Times are GMT -7.   It's 01:23 PM.
