Old 01-14-2013, 08:59 PM   #16
Maoule OP
Maoule's Avatar
Oddometer: 534
Shit, y'all are making my head hurt now OK, Ima go look at it some more...keep 'em coming But once I start drilling...
Maoule is offline   Reply With Quote
Old 01-15-2013, 06:10 AM   #17
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,579
They seem to end up level on KLR's, but I think the seat is pretty horizonal as a guide there.
I like the Pelicans totally horizonal on top,
so when I am working on the bike I have a safe place to set my chilled beverage
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is online now   Reply With Quote
Old 01-15-2013, 07:15 AM   #18
Maoule OP
Maoule's Avatar
Oddometer: 534
On the other hand, with a good slope to the cases, there is less danger of the chilled beverage becoming unchilled ;)
Old 01-15-2013, 07:25 AM   #19
Dusty
Dusty's Avatar
Oddometer: 1,300
A couple shots of my setup... I'm not tall so it was tough swinging my boots over the gobis... Its a tough decision, finding the perfect position, i could have raised them about an inch, but they work just fine. Keeps the load lower but not to low be a problem.
I don't use that top box very often, usually a dry bag with my tent, pad, and bag in it.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 01-15-2013, 07:44 AM   #20
PMC
riding rider
PMC's Avatar
Oddometer: 872
I'd keep them level with the racks you're mounting them on which will give them a little tip down in the front.
Just like the stock KTM bags are from the factory
PMC is online now   Reply With Quote
Old 01-15-2013, 08:27 AM   #21
catalina38
Contrarian
Oddometer: 1,645
Aesthetics aside, the lower and further forward the better for stability but gets in the way of the passenger and even worse is the catching and breaking your leg/foot. The higher and further back the worse stability wise but provides plenty of clearance for your legs to not get caught in them. It's a trade off. I went with narrow boxes rotated slightly and a little higher than most to ensure plenty of clearance. Here is a shot that shows my pannier placement somewhere south of Green river Utah.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 screwed with this post 01-15-2013 at 09:22 AM
catalina38 is offline   Reply With Quote
Old 01-15-2013, 11:34 AM   #22
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,496
I have Touratech standard mounting brackets and sometimes I feel that they're tilted too far forward. But if I want to tie another bag across the back they seem just right. It's not like I could do anything about the angle without a bunch of grinding and welding...
Old 01-15-2013, 12:07 PM   #23
beergut
Thumper
beergut's Avatar
Oddometer: 413
That road is beautiful
My KLR
beergut is offline   Reply With Quote
Old 01-15-2013, 01:19 PM   #24
scottrnelson
Team Orange
Oddometer: 1,496
Highway 49. Over 300 miles from end to end with the majority of it wonderful turns like that. We're spoiled in Northern California with a lot of great twisty roads.
Old 01-15-2013, 03:49 PM   #25
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
If you have not already looked, you can check out many pics of Metal Mule luggage on (gasp) BMWs in the following link from BestRest:
http://bestrest.smugmug.com/gallery/...2157&k=4r6HPHZ
Another site for reviewing luggage fitment is the caribou cases website
http://www.cariboucases.com/
The photos for both the Metal Mule and Caribou Cases show their luggage with level or a small forward inclination.
As others have mentioned, please post pics when you are done.
Cheers.
gbx2001 is offline   Reply With Quote
Old 01-15-2013, 10:45 PM   #26
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,091
Looks sportier with them tilted down in the front. Looks faster.
I like them tilted down a little, all the heavy junk rolls to the front.
Just wear your ball cap on straight.
"Son, you can't do both"
Old 01-17-2013, 10:35 AM   #27
Maoule OP
Maoule's Avatar
Oddometer: 534
Here you go
I decided to split the difference between the angle of the tail rack and passenger seat. The height of the front of the cases is at the bottom of the seat.
Lid catches made from vinyl coated 1/16" cable from Home Depot, made loops with homemade crimps from 1/4" copper tu
bing covered with heat shrink. One end is riveted tight, the other a little loose to be able remove and open the lid completely.
The Happy Trails attaching pucks. I undersized the drill holes in the cases by 1mm to help with water tightness.
Overall, it was a fairly simple install. The right side rack didn't line up well with the mounting holes and was tweaked out at the bottom; I employed my rubber swing press to fix that. The upper mounting knobs are really big so I'll see if I can make something a little more sleek. I am also going to counter sink some thick washers and use flathead sockets screws to replace the lower puck mounting screws. The overall mounting seems pretty secure, but we'll see what the road has to say One last thing...I didn't focus on them, but if you look close, you'll see the fastgun locks I'm using; I had to do a little dremeling to accommodate the diameter of both pieces of the lock.
Maoule screwed with this post 01-17-2013 at 10:36 AM Reason: pic size
Old 01-17-2013, 03:04 PM   #28
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,071
Thumb
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 01-17-2013, 03:12 PM   #29
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,988
Lookin good mate, 990R colours my fave.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 01-17-2013, 05:10 PM   #30
Maoule OP
Maoule's Avatar
Oddometer: 534
Thank you very much.
Another issue has presented itself: when I started stacking gear about to see how everything's gonna fit, I noticed the turn signals are liable to get covered easily. Any thoughts on this?
Times are GMT -7.   It's 08:14 AM.
