Old 01-14-2013, 09:32 AM   #1
vospertw OP
Adventures on the Cheap
vospertw's Avatar
Oddometer: 767
Grip Glue Cleaner?
All,
I installed the factory heated grip kit on my Versys a couple weeks ago and used standard grip glue - seemed to hold ok but did a ride yesterday with the heaters on high for about 1.5 hrs and noticed that my throttle grip was rotating on the throttle sleeve. The factory kit has the heater element in the grip so I need to reuse it and wondering if anyone has a recommendation for a cleaner spray/solution to help clean the old glue out of the grip before reinstalling. My biggest concern is finding something that will get rid of the old glue but not be detrimental to the rubber grip.
I plan to use Koso heated grip glue this time - never used it before but it's available through Parts Unlimited - supposed to be good for almost 300 degrees. Thanks in advance.
Todd Vosper
'07 DR650SE
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin."
- Samuel Adams
vospertw is offline   Reply With Quote
Old 01-14-2013, 11:12 AM   #2
WoodButcher
WoodButcher's Avatar
Oddometer: 2,108
From inside the grip, i've used wd40 then soap and water to get ride of the wd40. As I remember, I used hairspray instead of grip glue. However, i am sure I also safety wired the grips which guaranteed they didn't slip.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 01-14-2013, 11:23 AM   #3
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,407
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 01-15-2013, 07:44 PM   #4
vospertw OP
vospertw's Avatar
Oddometer: 767
Thanks all. I still have the original grips so maybe I'll use them as guinea pigs to see what works best. I did think about safety wire but they are pretty stiff grips and I'm not sure I could get enough pressure on them to hold well without cutting into the grip - which might cause more problems; internal wiring and all.
Todd Vosper
'07 DR650SE
- Samuel Adams
Old 01-16-2013, 04:05 AM   #5
greer
Oddometer: 3,836
Grip glue cleaner
How about that Goof-Off stuff:
http://www.goofoffstainremover.com/w...n/glue-residue
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-16-2013, 05:10 AM   #6
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,556
I found lighter fluid (naptha) works well to remove some types of adhesives without attacking rubber and leaves no residue. Goof-off and WD-40 are also good options (I think both have some naptha in them). Lately, I have found WD-40 very useful for cleaning bare aluminum and softening glues. Lighter fluid also works well as an assembly lubricant for rubber parts. Try some on a q-tip first to make sure the rubber does not swell or dissolve. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 01-16-2013, 07:35 AM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,722
Careful with the "Goof Off" it does eat some plastics.
Have tools, will travel!
Old 01-16-2013, 11:40 AM   #8
kubiak
Oddometer: 4,829
i use acetone but its really strong stuff so watch out!
Old 01-16-2013, 11:50 AM   #9
alansz400
alansz400's Avatar
Oddometer: 1,002
I use brake cleaner in a spray can from the auto parts store to clean everything. It works great. Spray it on a rag and dab the glue with it. It shouldn't hurt the grip. I have cleaned dirty grey pro taper grips with it and had no problems. Safety wire the new grips on. Twist the wire until you see it just starting to sinking into the grip. Do that in 3 places and the grip will not move even with no glue.
alansz400 is offline   Reply With Quote
Old 01-16-2013, 01:39 PM   #10
vospertw OP
vospertw's Avatar
Oddometer: 767
Thanks all! Some good suggestions. I have most of those solvents at home so will try a couple on the old grips and see what works. Luckily, I followed the Kawi instructions which, for the throttle grip, said use a "thin" coating of glue so hopefully it won't be too much work. Hate having the poor bike on the disabled list for something so simple.
Todd Vosper
'07 DR650SE
- Samuel Adams
Old 01-17-2013, 06:46 PM   #11
SRG
SRG
SRG's Avatar
Oddometer: 1,319
3M General Purpose Adhesive Remover is a good solvent that won't damage paint, has not damaged any plastics I've used it on and dries quickly leaving no residue.
SRG is offline   Reply With Quote
Old 01-21-2013, 08:08 PM   #12
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 1,077
removing old grips
hey guys, I hope I'm not too far off topic with this question:
I have an old set of bars and a new set. I'm too cheap to buy a new set of grips... any ideas how I can get the LHS grip off so that I can re-use it on the new bars?
Young-Gun is online now   Reply With Quote
Times are GMT -7.   It's 10:07 PM.
