Old 01-14-2013, 11:15 AM   #1
mroddis OP
Oddometer: 181
KTM and torque wrench
I debated putting this in the Garage section of ADV, but figured it's more specific to my KTM, so here it is...
I'm a relatively new 2006 950 Adventure owner and slowly gettting more and more confident maintaining her. I have been slowly building up my tool set, finding things I need along the way and trying to get a decent set together.
I've been borrowing a torque wrench, but now need to get one myself. I'm hoping people here can offer some advice on a good wrench that will cover the various torque specs needed for our beloved 950. Any tips? Tricks? Advice that you can share to a noob? I'm in Canada but close to the border to maybe some tips for both sides of the border?
I will pay for quality, but I'm also not made of money - always looking for a good deal. Ideally I would only need one (3/8 drive?) that will suffice for all my KTM wrenching needs (my sockets are 3/8 drive). I know the torque specs vary across the entire bike, so looking for something that will serve me best.
Ideas?
Thanks as always,
Matthew.
2006 KTM 950 Adventure - Black
mroddis is online now   Reply With Quote
Old 01-14-2013, 11:50 AM   #2
Orangecicle
Orangecicle's Avatar
Oddometer: 2,447
Good question. I have the same issue. I have a basic Craftsman torque wrench that does not have a ratchet head -- a "Dr. Beam" style. It does not give you enough options for positioning when working on things like spark plugs in a bike with a trellis frame. Get one with a ratchet head.
I thought about this one: http://www.sears.com/craftsman-elect...4&blockType=G4
But the reviews are not so good. It's hard to find one that covers low torque values (15 newtons or so on plugs) and the higher range as well (90 newtons on the rear axle). I hope there are some good suggestions coming.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 01-14-2013, 11:54 AM   #3
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,745
Just my humble opinion...
I think two torque wrenches are a must, no matter what bike you own: a beam-style for the lower values, and a ratchet/standard for the higher values.
For what it's worth, all of mine are Craftsman, and have served me well...
EDIT- If you absolutely needed a ratchet-style, for the lower values, you could consider one in inch/lbs, and do the conversion. However, "conversions" could be a great way to screw-up the math, and snap some parts.
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 01-14-2013, 12:06 PM   #4
el queso
toda su base
el queso's Avatar
Oddometer: 684
I have two older (USA made) Craftsman “Micro-lock” torque wrenches; a 1/2” drive in foot-pounds and a 3/8” in inch-pounds. Both have a Newton-meter scale as well, so no conversions are needed. With a 1/2-3/8 and 3/8-1/4 adapter, I can work on all my vehicles.
el queso is offline   Reply With Quote
Old 01-14-2013, 12:11 PM   #5
WARRIORPRINCEJJ
Oddometer: 9,745
Originally Posted by el queso View Post
...Both have a Newton-meter scale as well, so no conversions are needed. ...
Now that is nice.
I have an older "in/lbs" TW, but it doesn't have an N/m scale. I haven't used it in years (I believe it's stuck in the bottom of one of my rifle cleaning boxes.)
Whenever I need a wrench for the smaller values, I've just gotten used to grabbin' the beam-style...
Old 01-14-2013, 12:39 PM   #6
cdndog
cdndog's Avatar
Oddometer: 86
Canadian Tire has the 1/2" and 3/8" drive torque wrenches for 60-70% off regularly. Just watch the flyer!
cdndog is offline   Reply With Quote
Old 01-14-2013, 01:06 PM   #7
zgfiredude
Oddometer: 818
Just a word of caution, using the reducing adapters will generate "false" readings. It is technically not advised. That being said, I have tried to determine the variation, and it has not been significant in my findings.
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 01-14-2013, 01:19 PM   #8
dmn0507
dmn0507's Avatar
Oddometer: 350
For "usual" maintenance you mostly need a low-range torque wrench (6-20 Nm), might be useful to have also one that covers up to 100Nm or so (head bolts, shock bolts, sprocket etc) but you can live without if you have some experience on wrenching (and if you don't plan to remove cyl. heads)
I'm not extremely picky about torque w., so a decent quality wrench (lets call it 'good deal') is okay, invest the extra money on sockets and spanners.
dmn0507 is offline   Reply With Quote
Old 01-14-2013, 01:29 PM   #9
Schannulleke
Oddometer: 208
Torque wrenches are very personal and depend on your budget. But you will need 2 wrenches to cover a large range of torques. Look at the torque list of the bike you have.
For regular maintenance, make sure you have the total range of 6 Nm to 90 Nm covered. (90 Nm for rear wheel).
Everything below 6 Nm is just handtight with a screwdriver without lever.
For more advanced maintenance the range should go up to 150 Nm (or 180 Nm with older models).
A torque wrench is typically less accurate at the lower end of its range, so try to avoid that. It's best that you chose the torque wrenches such that they have some overlap in their respective ranges.
Schannulleke is offline   Reply With Quote
Old 01-14-2013, 02:09 PM   #10
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
I really like the "click stop" type.
I would buy the best you can afford, and if possible you can test it against a friends for consistency or better
yet find one that had recently been calibrated.
I also learned a trick from cjracer (craig) to paint mark your bolts after being torqued that way trail side you
can take a good guess at how tight by lining up the paint marks when there is no torque wrench available. This is very helpful on any bolts used in changing tubes from flat tires and chain adjustments, but I also mark everything else that gets torqued and just at a glance can see if something is working loose from vibration.
Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 01-14-2013, 03:35 PM   #11
Keith
Slabbing it
Keith's Avatar
Oddometer: 903
I saw this last night while perusing. Might just work for you.
http://www.advrider.com/forums/showt...=Torque+wrench
Random Crap
Keith is offline   Reply With Quote
Old 01-14-2013, 03:37 PM   #12
PMC
riding rider
PMC's Avatar
Oddometer: 808
I have the same set-up
works awesome and you use them way more often than you'd think if you work on a bike or six.
PMC is offline   Reply With Quote
Old 01-14-2013, 07:40 PM   #13
Deepc
Oddometer: 299
I'm looking into purchasing a torque driver. I found some on amazon that range from $50 to $200. I believe this is the ideal tool for all of the M5 screws on the engine case.
Deepc is offline   Reply With Quote
Old 01-14-2013, 10:34 PM   #14
SauceSquatch
SauceSquatch's Avatar
Oddometer: 257
You'll need two IMO. I personally own three... At the very least you need a foot pounds with a good range and a small inch pounds. I like craftsman, I own a Husky as well and have been very happy with the quality.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Old 01-15-2013, 11:03 AM   #15
mroddis OP
Oddometer: 181
Thanks for all the advice! Great to have all your opinions to confirm what I had thought - that likely 2 tools are needed to service our wonderful machines.
Thanks too for the tip of one for sale in the classified.
Love this forum
Thanks all
Matthew.
Times are GMT -7.   It's 02:29 PM.
