01-14-2013, 10:21 AM
#1 |
Oddometer: 188
Anybody use shrink wrap to hold spare tube on front fender?
Got this idea based on how secure things are when I have to take the shrink wrap off things. I have read lots of posts about fender bags with a warning to check them often as they can come loose. Has anybody used shrink wrap to help hold it on? Seems like it would work but maybe there are some downsides I haven't thought about.
01-14-2013, 10:26 AM
#2 |
Deputy Cultural Attaché
Never heard of it being done, but that does not mean it cannot be a workable solution.
With the low expense of attempting it, why not give it a go?
Successfully surviving motorcycling since 1976. |
01-14-2013, 11:24 AM
#3 |
Oddometer: 188
It may look kind of "ghetto" but I will try it out in combination with a fender bag in the spring. It will free up lots of space in the tool tube to move the 21" tube somewhere else.
01-15-2013, 02:37 PM
#4 | |
Anatomically Correct
Oddometer: 2,568
Light shade will provide near ideal lighting. Thanks.
Searching for the immaculate contraption |
01-15-2013, 04:55 PM
#5 |
Oddometer: 979
In front of Starbucks.
Roads? Where we're going we don't need roads. -Doc Brown |
01-15-2013, 05:00 PM
#6 |
not dead yet
Oddometer: 26,994
As the underside of the fender isn't flat, won't this create a space for debris to collect, and/or a reduction in clearance between fender and tire? Or am I misunderestimating how you plan to wrap the wrap around the fender.
Advanced pancreatic cancer diagnosed 04/2010. 95% mortality within 2 years but NOT DEAD YET. Been thru & still doing all sorts of treatments. Gonna keep doing what I'm doing until I can't any more. |
01-15-2013, 07:11 PM
#7 |
Oddometer: 64
If the shrinkwrap doesn't work, maybe a big hose clamp....that should look "real nice Clark".
01-15-2013, 07:32 PM
#8 | |
Oddometer: 1,039
Are you going to carry a roll of shrink wrap so that you can redo the job with the old punctured tube, after you fixed the flat with the spare tube? Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
01-15-2013, 08:42 PM
#9 |
Lost ADVR
Oddometer: 559
Use old tube as rubberband/bungee!
ChildsPlay Riding ChildsPlay Racing Of all the roads you take, Make sure a few of them are dirt. |
01-16-2013, 01:03 PM
#10 |
Oddometer: 853
Fenderbags work, you could always bolt it to the front fender for extra support.
2003 xt600e 118.000km on stock motor. 1986 xt350 94.000km |
01-16-2013, 01:13 PM
#11 |
Are those Pelicans?
Oddometer: 2,135
The UV rays pisses with the integrity of the rubba.
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
01-16-2013, 01:17 PM
#12 |
Unsprung Weight
Oddometer: 1,104
Shrink wrap doesn't do well in the sun for very long. UV will break it down.
+1 on bolting it to the fender. Get a cheapie plastic kitchen cutting board and cut it to fit the bottom of your bag. Using bolts and "fender" washers, fasten it thru the cutting board, bag and fender with some nylock nuts to finish it off. FWIW, I have not yet lost a fender bag that is held on by it's little straps. YMMV.
1991 Honda XR628R 1978 Yamaha XT500 1965 Hodaka Ace 90 |
01-17-2013, 07:04 PM
#13 | |
Oddometer: 1,876
Ride 365 LLC Braaaap! |
01-17-2013, 08:12 PM
#14 |
Oddometer: 188
One guy likes to meet at the starbucks before rides, but don't have a GS.
There is probably a good reason I haven't seen it in hundreds of ride pics here on advrider. There would be a big space for crap to get caught up between the fender and wrap. The fender bag is probably held down well enough with straps as I plan to carve a notch into the fender to keep the straps from wandering. Maybe just keep the patch kit and spoons in a separate place.... Just in case. Thanks for the feedback. |
01-17-2013, 09:00 PM
#15 |
Oddometer: 537
Why not just use some sort reuseable ziptie?
97 Suzuki DR650 97 Ural Sportsman 2WD 98 Honda XR250R 85 Yamaha BIG Wheel 200 www.drriders.com |
