Old 01-15-2013, 09:39 AM   #1
Jimm Dandy OP
Oddometer: 117
FREE ski chalet SUN VALLEY IDAHO
for 2 people for a week for a hack guru who will help my mount my sidecar to my VSTROM.. I already have the subframe and all components needed.. I just dont know JACK about hookn 1 up..thanks
Jimm Dandy is offline   Reply With Quote
Old 01-15-2013, 09:47 AM   #2
Jimm Dandy OP
Oddometer: 117
ok..WAIT.. its actually a REAALY NICE apt. above my garage 15 miles south of SV but I hope i got your attention
Old 01-15-2013, 10:03 AM   #3
ricmachado
Oddometer: 297
I want...
but I can't
ricmachado is offline   Reply With Quote
Old 01-15-2013, 11:26 AM   #4
jaydmc
Oddometer: 1,050
I can send you basic sidecar mounting instructions if you email me for them at jay@dmcsidecars.com I can also help over the phone getting it set up.
Jay G
DMC sidecars
Enumclaw WA
866-638-1793
jaydmc is offline   Reply With Quote
Old 01-15-2013, 11:42 AM   #5
SCBonneville
Oddometer: 2
Dang Jim... that's a heck of an offer... and I'd jump all over it if I 1) knew anything about mounting a hack to a V Strom... sorry, my rig is mounted on a Bonneville... easy peasy mounting on that one. 2) liked snow and snow skiing... I don't, see #3. 3) didn't actually "stove up" and my personal "molecular motion" grind to a halt, at any temps below +60 degrees... what do you mean that shorts and flip flops aren't appropriate winter wear??
I hope you get a knowledgeable taker to your offer...
Tom
SCBonneville is offline   Reply With Quote
Old 01-15-2013, 12:23 PM   #6
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,785
I'm not a guru, but as a former DL1000 guy, and with Jay's instructions, doesn't sound too hard, especially if it's one of Jay's subframes.
So . . . what kind of subframe is it?
What sidecar is it? Is it that Dnepr you were going to Las Vegas to get?
You say you have all the components--you mean the right length struts?
Got any pics?
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 01-15-2013, 01:04 PM   #7
Jimm Dandy OP
Oddometer: 117
no pics as of now.. yes its a DMC subframe and a dnepr hack.. i have 2 pieces of pipe for the struts but they are not cut to length.. have a bunch of whatever they are called thingies to connect em with.. supposedly everything that was needed but not really 100% sure..
Old 01-15-2013, 01:05 PM   #8
Jimm Dandy OP
Oddometer: 117
Jay G
DMC sidecars
Enumclaw WA
866-638-1793
thanks Jay... I may just take you up on that..
Old 01-15-2013, 06:47 PM   #9
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,785
Well, you better spread everything out on the floor and post a pic. Nobody's gonna want to make TWO trips because you didn't have all the parts. Like for instance you say you have 2 pieces of pipe. You need 4 struts. Here is a pic of a DMC kit. Is this what you have?
WUMPA
Sidecardogs.com
Old 01-16-2013, 07:32 AM   #10
jaydmc
Oddometer: 1,050
For the Dnepr there would not be the "A" arms. In stead the front lower mount would be cut off of the sidecar frame and a pinch tube type clamp welded in its place. A new lower rear pinch tube type clamp would be welded about 8 inches forward of the current location for the lower rear mount. Then we would slide in a part we call a clamp. This also has pinch tubes on the end of it set at 70 degree's. Then into the clamp a part we call a boss slides in. The end of the boss has threads for the 5/8 inch heim joints that attach to the clevis on the lower mounts on the bike.
We provide drawings as to how to cut off the front lower mount and weld in the new pinch tube type clamps.
BTW, the Ural is very similar to the Dnepr however the frame tubes are different diameters.
The "A" arms are what we use on our M72 type sidecars on the V stroms and the R1100 and up BMW GS bikes. We would also use "A" arms if we were doing a Ural or Dnepr in house.
Jay G
DMC sidecars
866-638-1793
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
Old 01-16-2013, 08:45 AM   #11
Jimm Dandy OP
Oddometer: 117
Jay
do you ski!!!!!! ???? lol... thanks
Old 01-16-2013, 08:46 AM   #12
Jimm Dandy OP
Oddometer: 117
for the record.. I do have access to full on welding shop
Old 01-16-2013, 12:08 PM   #13
jaydmc
Oddometer: 1,050
I do ski, but I use a boat and a tow line.
Jay G
DMC sidecars
Old 01-16-2013, 12:17 PM   #14
Jimm Dandy OP
Oddometer: 117
Thumb
got a very informative email from Jay.. THANKS JAY
Times are GMT -7.   It's 07:41 AM.
