Old 01-15-2013, 05:27 PM   #1
domains OP
domains's Avatar
Oddometer: 162
XR650L hotcam
Im a licensed mechanic( im a second generation know it all)
I set cam .15 intake .20 exhaust, stock cam is 10mm intake .12mm exhaust
but now I hear it rattling more now
after cam brakein can i set back to stock?
Its a new motor... piston crank all new, everything's new
domains screwed with this post 01-15-2013 at 05:33 PM
domains is offline   Reply With Quote
Old 01-15-2013, 05:55 PM   #2
mcma111
mcma111's Avatar
Oddometer: 7,965
How many miles on the new motor??
Did you confirm oil flow to the top end??
If Hot Cam says .15 and .20 then that's the spec.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-15-2013, 05:58 PM   #3
mcma111
mcma111's Avatar
Oddometer: 7,965
BTW...
This belongs in the Thumper section
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-15-2013, 06:19 PM   #4
domains OP
domains's Avatar
Oddometer: 162
Thumper might of helped one piston but one or 8 pistons kinda the same no? lots of oil flow
Why is the settings almost double with hotcams?
megacycles settings just as high?
i think its just because the hotcams are not polished thats why they want low rpm brakeins
whats your thoughts?
after brake in low idle set to stock?
Old 01-15-2013, 07:15 PM   #5
mcma111
mcma111's Avatar
Oddometer: 7,965
My Mega Cycle cam has .004 and .007 specs.
I don't know about the Hot Cam other than more than a few folks that have installed them in their XRL's have regretted it. Some have had good luck.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-15-2013, 07:49 PM   #6
domains OP
domains's Avatar
Oddometer: 162
Mega cycles are polished?
I had the urge to 300grid wet sand paper them but thought il just let idle 20 mins like specs
but i know my stock cam didn't rattle as much
brand new rockers less then 2 hours on them so i know its because .15 or .20 is loose
lots of oil pressure
didnt ride bike yet... just let it idle 10 mins cool down 10 more mins and checked valve clearance no change
Old 01-15-2013, 08:03 PM   #7
domains OP
domains's Avatar
Oddometer: 162
I bet the trick is just polish the hot cam and you got yourself a mega cycle
without spines
Old 01-16-2013, 07:58 AM   #8
elsalvadorklr
Oddometer: 3,954
dude no
good luck...pot metal versus high quality treated steel...
the polishing is not the difference
do not deviate from what hotcams says, for tolerances, keep them loose and check often...if you start seaing that you git whacky valve lash specs then well start thinking about a replacement cam and hopefully not rockers...
enjoy it as the performance for $$$ value is high since all you do is plop one in with a new gasket...all other performance cams REQUIRE hard faced rockers that are treated to tolerate the HARD AS HELL CAMSHAFTS...
something to think about
christian
elsalvadorklr is offline   Reply With Quote
Old 01-16-2013, 11:34 AM   #9
kubiak
Oddometer: 4,136
its been awhile but dont you keep the rpms up when breaking in a cam? did hotcams say to let it idle?
Old 01-16-2013, 11:48 AM   #10
elsalvadorklr
Oddometer: 3,954
word, something like 3krpms steady? lubed up?
Old 01-16-2013, 11:53 AM   #11
mcma111
mcma111's Avatar
Oddometer: 7,965
CW says 2000 RPM for 20 minutes. Of course I never did any break in with all of the Mega Cycles cams over the years and I've NEVER had a problem with their products.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-16-2013, 11:55 AM   #12
elsalvadorklr
Oddometer: 3,954
for the hotcam or our cams?
anywhoo
Old 01-16-2013, 12:20 PM   #13
mcma111
mcma111's Avatar
Oddometer: 7,965
CW's cam
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-16-2013, 12:32 PM   #14
domains OP
domains's Avatar
Oddometer: 162
The surface of the hotcam is rough, like they sprayed them for rust protection
guess il leave them loose for now
thx for help
Maybe the bad luck people had with hot cams it too much lube when installing... like over use of thick STP that could plug the oil holes on cam lobes
domains screwed with this post 01-16-2013 at 12:39 PM
Old 01-16-2013, 12:55 PM   #15
elsalvadorklr
Oddometer: 3,954
nope, thats a coating they put on the factory to help breakin
after say 200miles or so youll see the nice shiny metal
same with our cw cam, they come coated then clean off
again
leave them loose forever...,not just now...lastly the reason for those lash specs are because of the ramp angles, etc of the lobes, they need more space
others can explain this better...
for example cws cam recommend a TIGHT .10mm on both sides...
Times are GMT -7.   It's 10:29 AM.
