Old 01-23-2013, 08:25 PM   #16
Tim McKittrick
Oddometer: 1,717
Your oiling system may not be operating as it should- if it's not returning to the oil tank properly it will wet sump and barely run- and force great gobs of oil past the piston. Since you've had the engine out I'd first look for a pinched return line. Also inspect the frame filter screen and case screen, and make certain the pump is happy and correct.
Tim McKittrick is online now   Reply With Quote
Times are GMT -7.   It's 12:01 PM.
