Old 03-15-2013, 08:06 AM   #1
coarsegoldkid OP
coarsegoldkid's Avatar
Oddometer: 605
Question on installing rivet link DID chain
Well I've got the Motion Pro all in one chain tool. I've read a few articles about how to install a chain too. One of the underlying tips for a successful install is to press the rivet on to the manufacturers rivet flare specification. Too little and it is loose but can be repressed. Too tight and you damage that link, it will be stiff. Do it over. No flare spec was provided in the new DID X-ring chain packaging. I see no flare spec on their web site.
What is the flare spec I'm told I should know to install the rivet link?
thanks in advance
coarsegoldkid is offline   Reply With Quote
Old 03-15-2013, 08:26 AM   #2
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
Using a set of calipers, measure the diameter of the already-riveted head of any of the other links in the chain.
Now, measure the diameter of the pins on the master link.
You want to get the final diameter of the head of the pin to be close to measurement #1, and of course larger than measurement #2.
Old 03-15-2013, 09:58 AM   #3
coarsegoldkid OP
Oddometer: 605
Thanks I'll measure that. I also found this 4 page description. http://www.didchain.com/chainTools.html
I don't understand the sag they spec. 3/4 inches is way off what Suzuki specs for chain slack for my bike. Maybe DID wants to get the chains and sprockets to wear out faster.
coarsegoldkid screwed with this post 03-15-2013 at 10:05 AM
Old 03-15-2013, 10:04 AM   #4
catalina38
Contrarian
Oddometer: 1,617
Here you go.
The specs are on the 3rd page of the DID install instructions
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-15-2013, 02:12 PM   #5
dmn0507
dmn0507's Avatar
Oddometer: 352
somewhere i've read that the pin should be flared till the diameter is 0.4mm bigger then the original diameter.
I flared it according to that and it seems good to me, chain has almost 40K km (almost needs to be replaced again) and the master link is okay.
Pins fits really tight in the plate and there isn't almost any force trying to push out the plate, so just a little flare is enough.
dmn0507 is offline   Reply With Quote
Old 03-15-2013, 03:08 PM   #6
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,625
I spent 100 bucks on the DID KM 500 chain tool that will break and install the rivet link, figuring it would pay for itself after a couple of chain installs. The cool thing about it, is it presses the side plate on and has a stop, so you can't screw it up. There is a clone of that great tool out there for half the DID, or less. Found it;http://www.ebay.com/itm/MOTORCYCLE-C...item5898c6369c
rbrsddn is offline   Reply With Quote
Times are GMT -7.   It's 05:47 PM.
