Old 01-17-2013, 07:24 AM   #1
Navin OP
Navin's Avatar
Oddometer: 8,167
Monokey top mount for side bags?
Is the option even viable? I have a monokey universal plate for top box mounting on a rack. I'll be wanting to add some hard saddlebags, small ones, to the bike and wondered if these plastic plates, mounted to a steel/aluminum frame to the bike, would be strong enough to hold them. Nothing too heavy, just clothes. I see them list the rectangular tube frames for side cases but not these. I believe the monokey cases all use the same fixing points so, any opinions?
Thanks.
Navin is online now   Reply With Quote
Old 01-17-2013, 09:40 AM   #2
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,094
Sure. I have the Monolock (which is supposed to be weaker than the Monokey) mounted to an aluminum plate, and that thing is sturdy enough for what you want. You would have to make it yourself, though.
Givi does make smallish saddlebag holders, which typically mount to the same points as the top rack. The Easylock saddlebags are hybrid soft/hard, and I'm happy with them on my Dorsoduro.
High Country Herb is offline   Reply With Quote
Old 01-17-2013, 10:31 AM   #3
Navin OP
Navin's Avatar
Oddometer: 8,167
Thanks, it is for a Ninja 300 so I have to fab anything I want either way.
Old 01-17-2013, 04:43 PM   #4
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,213
If you have some sort of rack setup, you can get the Monokey mounting hardware from Twisted Throttle. Basically, you get the two posts and the "pyramid" that can be bolted to virtually anything.
Something like this, I think:
http://www.twistedthrottle.com/sw-mo...-monokey-kappa
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-17-2013, 04:52 PM   #5
Navin OP
Navin's Avatar
Oddometer: 8,167
Another good option, I missed those. Thank you.
Times are GMT -7.   It's 11:53 AM.
