Old 01-17-2013, 11:23 AM   #1
indr OP
Oddometer: 501
Special Snap Ring Pliers
indr screwed with this post 02-22-2015 at 09:40 PM
indr is offline   Reply With Quote
Old 01-17-2013, 11:29 AM   #2
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,955
Those are super thin, a pick and a tiny screw driver will get them out.
Old 01-17-2013, 11:47 AM   #3
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,838
place one end ion the groove, and press the ring in, proceding to the other end until it snaps into place . . . . .. think sprial . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 01-17-2013, 11:49 AM   #4
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,693
A screw driver
Plus what he said^^
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-17-2013, 11:55 AM   #5
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,902
There is a tool for every purpose. Save the screw driver for screws.
http://www.napaonline.com/Catalog/Ca...534_0293962905
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 01-17-2013, 01:32 PM   #6
gsweave
Yinz, blinkers are on.
Oddometer: 11,657
These are good.
Needle nose pliers will get you there too, as long as they aren't already f''d' up
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-17-2013, 02:56 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,666
Many years ago when I thought I would build a couple of automatics I bought this set off the Snap On truck
I ended up doing only one more transmission but over the years I have used these pliers several times. This set is now $200. SRP400A is the set #.
I like tools and when you need any of these they work great but you know what? You'll still end up doing that particular snap ring with a sharp pointy thing or a skinny screwdriver. Those are usually a thin material and not hard to bend. If you find a heavy duty one that is stiffer it's still the same thing. Pry out one end and spiral the rest out of the groove. To replace you put one end in the groove and press the rest in with your fingers (of all things), again think spiral like Bomber says.
These snap ring pliers do not remove or install the snap ring you are asking about. They do external snap rings. That internal ring you have is done with a sharp pointy thing or a small screwdriver.
Edit; Now that I think of it those rings may be used on external applications. The pliers might help if they are.
---Albert Einstein
disston screwed with this post 01-17-2013 at 03:01 PM
disston is online now   Reply With Quote
Old 01-17-2013, 04:51 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,666
Ooooh, that's nice. What is it? Where from?
---Albert Einstein
Old 01-17-2013, 05:40 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,666
It looks like three different sizes. A little less than $200 for all three I think. The one I would need is about $50. I can't really justify getting this new toy. I don't rebuild engines any where near often enough.
But I do know a guy in Maryland that lost an engine due to a not properly installed piston circlip. The metal pieces got all the way into the oil pump because he drove it home with bad noises.
---Albert Einstein
Old 01-17-2013, 05:55 PM   #10
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,902
You don't need one of those to properly install a circlip, you just need to pay attention to what you're doing.
It won't help the OP with his snap ring either.
20% Smug Mug Credit
Times are GMT -7.   It's 06:12 PM.
